(#226)
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 06-10-2014, 09:31 AM
Originally Posted by Bme30
Any one wanna comment on how the new LSD performes. I know there has been a few reviews but more are always better
Looking forward to getting mine installed.
Finished the install today and went for a drive. Diving normally the car is as quiet as it was before and no vibration at higher speed so I was happy about that. The rear feels more heavy/planted in the back end going over uneven roads which surprised me....less "tail wagging". Well yes there is definetely more traction. I drove the whole time with DTC off and on a couple of the "greasy" roads where it would normally spin all through second did DSC intervene. I need to up my boost limit in second from 12psi and try again on some good roads. I tried a few mild first gear launches and seemed way better but still some controlled spinning. I did notice the small clunk from the diff when sitting still with brakes on and going from reverse to drive. From drive to neutral and back to drive there is no noise.....need to go and make sure the axle bolts are still tight ...cheers.
335i FBO,Meth,MHD,XHP3,LSD,GCLites 11.83@124.88
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Seavita Seavita is offline
Car: BMW 335 CSI
Default 06-10-2014, 10:13 AM
I need a small bolted and if this means a new list let's start it please.
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 06-10-2014, 10:31 AM
Same here. Just a bit of clunk from stand still to the first gear. Other than that this is one of the best mod i d ever done with a great price. No tale waggle on wot and hard first gear turn with a great control under slipping....u simly will grin after grin from the fact that this car has unlimited potential. With my new inline along with this lsd, i am back again. Kw is next.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
trebila's Avatar
trebila trebila is offline
Default 06-10-2014, 12:24 PM
few pics of the new small diff' bearings FAG 801298 TR1P - T29:
blown07's Avatar
Car: 335xi, 335i
Default 06-11-2014, 12:38 PM
Originally Posted by MFactory
Around a tank of gas, then flush it with new oil
Is the "break in period" (say 400km) just a consideration when to replace the oil or is it necessary to take it easy on the diff during this period?
Kaleo's Avatar
Kaleo Kaleo is offline
Car: BMW 135i
Default 06-11-2014, 04:57 PM
My LSD arrived today
Kaleo
BMW 135i n54
BMS JB4, BMS Flash, BMS Meth, RB, Alpina flash, Down pipe, BMS Chargepipe, BMS Low Temp, AFE intake, AgencyPower Intercooler, Forge DV.
trebila's Avatar
Default 06-12-2014, 01:01 AM
me too.
MFactory MFactory is offline
Car: BMW E92 M3
Default 06-12-2014, 05:17 AM
It's not 100% necessary, but is recommended
Hujan Hujan is offline
Car: E89 Z4 35i
Default 06-15-2014, 10:03 AM
Hey MFactory!
I have a 2010 Z4 35i w/ DCT and am very interested in your LSD. Any idea whether you plan to offer one for this car, and if so, when it will be available?
trebila's Avatar
Default 06-15-2014, 11:20 AM
I've planned to install the rear M3 E93 anti roll bar with the LSD, in the meantime.
Original E88 rear sway bar: 12mm
M3 E93 one: 23.6mm
Kaleo's Avatar
Car: BMW 135i
Default 06-15-2014, 02:15 PM
What is the best oil to replace with the LSD? Motul 300 gear?
Kaleo
BMW 135i n54
Car: BMW E92 M3
Default 06-15-2014, 09:43 PM
Welded/DCT solutions are still under development.
Best oil to use is what you have had previous experience with, or what is recommended in your oem service manual. NO special fluid is required.
Car: E89 Z4 35i
Default 06-17-2014, 12:25 PM
Excellent. Glad to hear it. Do you have an approximate timetable? Also, do you expect the price of the DCT units to be roughly the same as the MT/AT ones?
I'd prefer your LSD to the others on the market (unless it will take a long time to come on the market and cost roughly the same as the ones that already are).
Kaleo's Avatar
Car: BMW 135i
Default 06-17-2014, 05:30 PM
MFactory,
What should be the torque on the bolts of the diff?
Kaleo
BMW 135i n54
Car: BMW E92 M3
Default 06-18-2014, 12:28 AM
Pricing should be similar, yes. Is still a couple months out though, as we have quite a big backlog on the machines.
Bolts should be torqued to what is recommended in the oem service manual (I believe is around 110lb, but I could be wrong. I'm not in the office at the moment to check)
Car: BMW E92 M3
Default 06-18-2014, 12:29 AM
sy2639 sy2639 is offline
Car: 2007 BMW 335i
Default 06-18-2014, 10:49 AM
Do you offer a selective snap ring shim kit for these? Or know where to get one? I found one here but it seems a little steep.
http://www.autotech.com/mm5/merchant...=N-472-100-20K
E92 - JB4 G5, BB Flash, RB Turbos, BMS Meth, BMS DP, BMS DCI, ACT Race Clutch
Car: BMW E92 M3
Default 06-18-2014, 10:57 AM
The shims are very hard to find and/or are very expensive.
When we do our builds, we custom make our own shims (like most of the other BMW Diff Specialists)
blown07's Avatar
Car: 335xi, 335i
Default 06-21-2014, 05:46 AM
Just did the diff oil change after about 500km break in. Was surprised to see the amount of shinny metal suspended in the fluid but no real particals that were not suspended. I can def see the importance of this first flush. I had drilled and tapped a 1/8" npt plug in the bottom of diff when I had everything apart and this really makes changing the oil easy and helps to get all the crap out of there. Will likely put in a 1/8" magnetic plug ala Harley primary case. Really happy with this mod btw...thanks Mfactory for a great deal !
Car: BMW E92 M3
Default 06-27-2014, 10:32 AM
Welded Diff Pre-Buy now posted: http://www.n54tech.com/forums/showthread.php?t=25599
trebila's Avatar
Default 07-22-2014, 04:03 AM
Mfactory
My LSD is being fitted today.
Do I have to flush the LSD oil in 400-500 kms ?
najin23's Avatar
Car: 335i CDV
Default 07-22-2014, 05:22 AM
don't bother. MFactory even said that their lsd is lifetime oil, basically you don't even need to break in nor flush fluid, unless you are heavily beating on it.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Car: BMW E92 M3
Default 07-22-2014, 06:43 AM
Although not 100% necessary with the Helical LSD, we do recommend changing the fluid after around 500 miles for the best performance
najin23's Avatar
Car: 335i CDV
Default 07-22-2014, 07:35 AM
alright...
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
trebila's Avatar
Default 07-23-2014, 05:52 AM
do someone know the oil quantity for a small diff ?
I'm pretty surprised my garage put only 1 liter of 75w90 OEM oil...
