LaCross LaCross is offline
Car: 2010 135i
Default BOV or throttle problem? - 08-22-2015, 04:27 PM
2010 135i 81k miles, fbo, jb4 w/nls and BE flash
Titek chargepipe w/ HKS bov
Having an issue where when i left off the throttle at high rpm my BOV is VERY delayed, almost a whole second or so. Only happens at WOT and high rpm.
Any ideas?
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 08-22-2015, 06:31 PM
Any issues hitting target? If not then theres probably an internal issue with the bov. You would get throttle body codes and limp mode if the TB was bad.
Boost'n e92's Avatar
Boost'n e92 Boost'n e92 is offline
Car: 2007 335i e92
Default 08-22-2015, 06:56 PM
Try contacting hks and see if they have a rebuild kit, the spring might be toast
2007 335i e92 space grey, a/t, fbo, mfactory lsd and boost addictions diff lock down, bmw pe mod, xHP stage 3, mmp stage 3, inlets and outlets and eos pi, custom tuned by pure evil estimated 620whp on e50 23psi. Current 1/4 mi 11.9 @116 on stock turbos.
Suspension: Koni yellows eibach lowering springs
Wheels: iforged Daytona 19x9.5f 19x10r
Drop a gear and disappear.
Car: 2010 135i
Default 08-22-2015, 07:34 PM
Is it possible that there is a delay between when I get off the throttle and when the throttle plate closes? I think I read something about that once
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 08-24-2015, 09:03 PM
Where you located?
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 08-24-2015, 10:05 PM
I noticed when I'm higher up on the rpm , I don't hear the hks bov vent at all between shifts .. With my old tial, I would hear to vent everytime between shifts.
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 08-25-2015, 08:37 AM
No. Not a second or half a second
Car: 2010 135i
Default 08-25-2015, 09:03 AM
I'm in central Jersey 08830. And the reason I ask is because the "sound" per say is very similar to when I wot shift. It's almost as if the car thinks I'm going to wot shift, realizes I didn't, and then the bov goes off.
Anything except wot@high rpm, the valve goes off normally
///Mposter's Avatar
///Mposter ///Mposter is offline
Default 08-25-2015, 09:23 AM
Are you manual transmission? I have noticed that if I shift in a lower gear for the first time, and then let off the throttle , the BOV sounds is pronounced. The next shift continuing through will anticipate me doing the same thing and keep the throttle plate open and less if no sound is heard when shifting.
My theory is that the pressing of the clutch pedal signals to keep it open to reduce back pressure on the turbo to reduce flutter.
Try this, go WOT an then let off without pressing in the clutch and I bet you get your loud sound you are looking for.
