Z-8 Z-8 is offline
Car: 135
Default Clutch life? - 05-19-2013, 05:15 PM
Any thoughts?
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 05-19-2013, 09:11 PM
If you're referring to the stock clutch, mine lasted about 3 years. Granted I chose to replace it after getting slight signs of slippage because of the increased hp but the stock held well with about 22-30 laps on the 'Ring and Hockenheim and at times normal 90-100 mph cruising on the autobahn over that period.
Currently have a ACT Stage 1 clutch rated to 450 HP.
Z-8 Z-8 is offline
Car: 135
Default 05-30-2013, 05:56 PM
Mine lasted 2 years, but that equated to 40K miles. The dealer said it is not a warranty item but is covered under the maintenance plan as long as the mechanic says it is normal wear and tear and not abuse. I wasn't thrilled about the dealer deciding if the item is covered since they get a higher labor rate if it is not covered. Luckily(?) the mechanic called it normal wear and tear and BMW paid $2750 for a new clutch.
The price is not a typo.
40K miles seems pretty weak for a high hp clutch. I was lucky it quit before 50K. Those with a manual transmission and no clutch replacement in the first 50K might want to consider buying a third party warranty that covers the clutch. Even if the warranty costs $3K it would surely pay for itself in the medium run.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 06-01-2013, 04:07 PM
Originally Posted by Z-8
Any thoughts?
Tends to be much shorter at the dragstrip.
Lifestyler's Avatar
Lifestyler Lifestyler is offline
Default 06-03-2013, 09:26 AM
i use the spec stage 3+ with singlemass steel flywheel !
the OME clutch dosent hold my cobb stage2+ fmic agresssiv map !
135i n54 FBO!
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 06-03-2013, 09:46 AM
Clutch life is 100% situational.
Depends on:
-Driving habits
-driving abilities
-Clutch type
-Mods done
-Probably more stuff
You could get 100k miles out of your clutch but I will get 9k out of mine. It all depends on key factors.
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar **'s SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 06-04-2013, 10:52 AM
I have 103k on my car now. Its been Burger Tuned with E85 since 65k. So thats about 40k miles on the stock clutch and it is just now starting to slip on me. I think for a stock item that was designed to hold 275 ftlbs at the wheels that fact that it made it this long holding 450+ ftlbs at the wheels is amazing. I think I will end up going Single Mass Steel with a Spec 3+ or Dual Mass with a Spec 3+ ... I haven't decided. I'd like to ride in a SMFW car first before pulling the trigger.
2008 335i stock
NetEagle NetEagle is offline
HPFP Stress Tester (6th)
Car: '11 N55 E92
Default 06-04-2013, 11:37 AM
Originally Posted by mrbillytalent
... but I will get 9k out of mine. It all depends on key factors.
LOL, if someone only gets 9k out of a clutch, they must be confusing the clutch pedal with the foot rest
'11 335i LMB, 6M, M-Sport, 35% tint, Stone-X, BMW Performance Exhaust, Shadow Grills, CF competition spoiler, CDV, aFe Stage 2 Intake, cp-e CP, Lamin-X "Tint" Head-Fog-Tail Film, Schroth Rallye 4 Harnesses, debadged, CAN Tool, Vortex 260M 18" Track Wheels with BFG R1 (245/265), Hawk DTC-70/HP Plus pads.
RIP '08 135i -- Lemoned Out
