bstone1989's Avatar
bstone1989 bstone1989 is offline
Car: 2002 Z06
Default 1st gear useless? Use 2nd gear from a launch up to a 40 roll?? - 04-19-2013, 08:34 AM
It seems all guys are launching in second and also doing rolls up to 40 mph in second for best results. Any reason to ever use first in a race??
enrita's Avatar
enrita enrita is offline
Default 04-19-2013, 09:03 AM
yeah 2 gear is the best.
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
b1aze's Avatar
b1aze b1aze is offline
135i is in my sights...
Car: 2011 WRX STI
Default 04-19-2013, 10:23 AM
DONT launch in 2nd gear if you have a manual. It will be hell for the clutch and i have already seen at least 1 thread where someone was doing it non-regularly and his clutch is completely toast at like 60k miles.
bstone1989's Avatar
Car: 2002 Z06
Default 04-19-2013, 11:34 AM
I am automatic with the alpina b3 flash
2012 550i M-Sport
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 04-19-2013, 12:14 PM
If I can get 60K out of my clutch I'd be pretty happy.
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 04-19-2013, 12:41 PM
A lot of 1/4mi times are achieved using 2nd gear launches....
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar **'s SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 04-19-2013, 01:51 PM
I know there's a lot of info on launching in 2nd with the 6spd auto. What about the 8spd uato in the F30?
EDIT: I have an F30 now even though my "Car" still shows my E92 but I don't have a "Your Profile" tab in my user CP for some reason co can't change it. ???
NewHotness NewHotness is offline
Default 04-20-2013, 01:03 AM
I too have been struggling with the profile edit for some time. Worked out the URL format and guessed it to be this once you are in the usercp:
http://www.n54tech.com/forums/profil...do=editprofile
Works for me ... Yay
albertc albertc is offline
Default 04-20-2013, 07:31 AM
Over 95k miles on my factory clutch , although it is slipping from time to time
JB4 G5, DCI, **, IC, Del Cats, Walbro LPFP, Meth
bstone1989's Avatar
Car: 2002 Z06
Default 05-15-2013, 12:57 PM
anymore opinions? maybe from some street/drag racers?
2012 550i M-Sport
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 05-15-2013, 01:44 PM
Originally Posted by bstone1989
1st gear useless?
Its only good for going up hills or towing something on a 6AT
2012 E89 Z4 sDrive35i M Sport MT
2011 E92 335is w/DCT
2007 E92 335i 6AT
bstone1989's Avatar
Car: 2002 Z06
Default 05-15-2013, 01:55 PM
Just so weird to me, when I had my z06 I talked to all kinds of guys that raced with crazy amounts of power and never heard of anyone racing out of second gear
2012 550i M-Sport
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 05-15-2013, 03:51 PM
Probably because they were not boosted engines. No naturally aspired engines....except diesels.... make max torque below 3k rpm.
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default 05-15-2013, 04:01 PM
im not a fan of the 2nd gear launch because of not knowing which clutch pak in the auto is being used. i too use to race my 2000 vet auto and never crossed my mine to use 2nd gear. i also had drag radials on it cutting a 1.6x 60ft time...to me just sheer torque multiplication dictates using 1st gear, but with the 335 one wheel to carry the load, 2nd gear would def. work...again i dont know bmws trans inner workings but in my vet it would truly shorten the life of it
rays 335i's Avatar
Car: 07 335 coupe
Default 05-15-2013, 04:07 PM
i s this because of the torque of the 335 u are refering to? i failed to mention i also had 150 shot and 3500 stall converter, which im sure far exceeds the 335 hp and torque.
deltalima0's Avatar
deltalima0 deltalima0 is offline
Car: 07 BMW 335
Default 05-15-2013, 04:18 PM
I still do 1st gear launches 6AT and I pull down high 11sec runs or 12.0 somethings consistently. For some reason my 2nd gear launch bogs or spools slowly and I can never achieve better than a 2.0 or worse 60.
1st gear launch I can get 1.8 or low 1.9s regularly, every now and then I pull off a 1.7.
Not sure what is up with 2nd gear launch for me though.
Any thoughts for 2nd gear bog or slow spool?
Cobb PTF tuned FBO.
Vroom's Avatar
Car: 335i 318ti
Default 05-15-2013, 04:31 PM
Are you AT of 6MT?
Car: 2009 335i AT
Cool 05-15-2013, 08:33 PM
and far exceeded the 335's traction also.
bstone1989's Avatar
Car: 2002 Z06
Default 05-16-2013, 07:04 AM
Are you AT of 6MT?
AT
2012 550i M-Sport
shaunlsone shaunlsone is offline
Car: 09 e92 335i sport
Default 07-27-2013, 10:53 PM
Cobb PTF tuned FBO.
I always read that 2nd is best and thats what I use at the track but 1st seems
to take off harder but on any roll race it makes no difference so I dont know.
when I was stock I was geting better 60ft times no I cant get under a 2.0 and I hit a 187 60ft
stock I ran last night and got a 2.0 60ft and ran a 12.8@ 110 in very humid 90+ s fla temps mods are jb4g5iso and dci with 30% e85
deltalima0's Avatar
Car: 07 BMW 335
Default 07-28-2013, 12:05 AM
I know what they say and believe me I have tried but 1st gear is what gets me in the 11's, 2nd gear bogs i may have a slight boost leak just cant seem to find it. My best time is 11.87 @ 119.3 I am looking for where I saved that slip.
Car: 2009 335i AT
Cool 07-28-2013, 10:44 AM
If you wan to edit your signature do this:
http://www.n54tech.com/forums/profil...=editsignature
jb's335's Avatar
jb's335 jb's335 is offline
Boost addict
Car: 08 e92 335i AW
Default 07-29-2013, 12:04 AM
I got 107K out of my stock clutch, tuned for 104K and FBO for at least 70K miles. I also drive the car like I stole it on a daily basis as well as autocrosses, road racing, and drag strip runs, are all a weekend routine .
2008 AW e92 335i
zeel zeel is offline
Car: AW e92 335i
Default 07-29-2013, 04:26 AM
On street tires, I like the second gear launch. If I was on DR or Slicks, I'd probably use first.
11.76@124 (123.9) fbo + e60 mix + street tires + stock exhaust. no meth.
Vertigo's Avatar
Vertigo Vertigo is offline
Car: AW 335i
Default 07-29-2013, 07:32 AM
LOL 108K on the stock clutch here. I just finished installing the Spec 2+ yesterday over the weekend. I am loving it!
2008 335i stock
