(#26)
Default 11-18-2015, 09:23 AM
Map 6 may work but its untested on the hex file you got. Let hear from Terry.
As I said the file comparison tool shows they are the same file. So if map6 did not work, then would not work on the version we posted. Maybe you emailed him the file before we had verified map6 was working properly and thus the warning.
Universal_Remonster Universal_Remonster is offline
Car: MK7 GTI
Default 11-18-2015, 03:45 PM
Thanks for the info. I'll try using Map 6 on my current firmware and see if I notice any difference as I've only run Map 1 thus far. I'll also correspond with George over email and post my final conclusions here so that I don't keep making this thread grow.
Duzambon Duzambon is offline
Car: 320i activeflex E100, JB4 stage 2, K&n intake
Default JB1 GRoup diferences - 10-24-2016, 03:55 AM
I just go a JB1 but I'm concern to install it on my Audi TT. I requested group II, however nothing came together saying that JB1 is specific for group II cars.
How do I know if this is the correct group model for my car?
Default 10-24-2016, 07:49 AM
The Group 1, 2 and 3 are the identical unit kept separate for statistics so what you have will work on the TT.
H17YD_L's Avatar
H17YD_L H17YD_L is offline
Car: M135i
Default 02-02-2017, 10:19 AM
George,
I sent you an email regarding some issues on my FL S3, wondering if you have received it or not?
Default 02-02-2017, 10:29 AM
Originally Posted by H17YD_L
George,
Hi, can you please send it again. george@burgertuning.com . I cannot recall the email.
H17YD_L's Avatar
Car: M135i
Default 02-02-2017, 10:55 AM
Just sent it again George, thanks
marcomk1 marcomk1 is offline
Car: MK7 GTI
Default 10-15-2017, 06:59 AM
*** WARNING *** The firmware and map guide below applies to the Stage1 system only. NOT the JB4 system. Uploading Stage1 firmware to the JB4 will likely require you to mail the JB4 control board back in to be reflashed. Don't upload Stage1 firmware to your JB4 system.
What firmware should be uploaded to the JB4 ? I have the upgraded LHD rev1.
Default 10-15-2017, 09:35 AM
Good question, I don't know if we've setup a JB4 thread here with firmware. If we haven't we should! George?
Default 10-17-2017, 05:44 AM
At this point there isn't a need to upload newer firmware. We nearly done working on some changes that improve part throttle smoothness and will be putting it up in the next week or so.
Lcwai Lcwai is offline
Car: Mini jcw f56
Default 10-17-2017, 07:26 AM
hi bro
volkswagen passat cc B8 2.0 (220hp)
which group i need to install ? group 1 or group 2 ?
Default 10-18-2017, 03:11 AM
Originally Posted by Lcwai
hi bro
The Group 2 unit is the one that should work if the car is fitted with the black engine cover. If it is still the grey top engine we do not have a unit that supports it. To be certain you can email me george@burgertuning.com a picture of the engine.
Ants_in_eyes_johnson Ants_in_eyes_johnson is offline
Car: Volkswagen
Default logging - 05-11-2019, 01:08 PM
Anyone know the correct way to log? i feel like im missing something simple. I started a log then drove the recommended way but no graph came up only some excel sheet which ill attach.
File Type: csv 190511_1531.csv (752 Bytes, 53 views)
Default 05-12-2019, 05:08 AM
It will only log above a certain amount of load so that might be at play.
Car: Volkswagen
Default 05-12-2019, 07:03 AM
wellllll... ****, i put her through what felt like a good test. Drove as if i was on a track again. lol the car felt amazing! just wish i had the log to adjust it for a little more. that just gives me another excuse to do it again
