(#251)
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-14-2019, 06:02 AM
This should be tested more!
the SMFW looks great
Where are the guys who installed them? We need to reviews and real life opinions
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" DP / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
houtan houtan is offline
Default 01-14-2019, 11:56 AM
+1. Have not seen one review.
MethodologysN54 MethodologysN54 is offline
-Methodology-
Car: 2013 BMW 335si (Convertable)
Default 01-15-2019, 11:30 PM
count me in i would love to be on the list for a m4 flywheel. did this list get made yet? am i too late? or
Methodolgy
MFactory MFactory is offline
Car: BMW E92 M3
Default 01-16-2019, 01:28 AM
We have the flywheels in stock and ready to ship. No list required
MFactory / YCW Engineering (LSD's, Gears, Flywheels, Clutches, Driveshafts, Axles) - www.teammfactory.com
YCW Suspension (Mid-Range Coilovers) - www.ycwsuspension.com
SWIFT Springs Europe (Exclusive Distributor) - www.swiftspringseurope.com
SWIFT Springs Asia (Exclusive Distributor) - www.swiftspringsasia.com
moss's Avatar
moss moss is offline
Car: 2012 335iS
Default 02-10-2019, 10:12 PM
Any reviews out?
PK4YOU PK4YOU is offline
Default 04-22-2019, 11:50 PM
I'm going to buy m4 2015 f82 flywheel p\t 21202283829 to my 335is, will this fit to my car?
JMVela's Avatar
JMVela JMVela is offline
Car: 335is
Default 05-07-2019, 07:39 AM
Yes it will.
2012 335is DCT 719.9 WHP MMPs BB turbos 93 oct pump gas + Meth. Trebila tuned.
Default 06-29-2019, 12:37 PM
Based on the pictures in the original post and from what I have heard from others, the stock non M dct flywheel looks similar to the M4 flywheel if the weight was removed. Has anyone tried to remove the weight from the non M flywheel and reinstall to see if it works the same as the M4 flywheel?
Default 06-29-2019, 02:39 PM
I have problem with 335is dct clutch it slips on 580nm it is stock 335is clutch 103k mileage, i'm going to install m5 f10 dct clutch pack maybe someone already tried this and knows if this will resolve slipping problem. Ps my car is 335i e90 single turbo, with dct swaped transmission
Default 06-29-2019, 03:34 PM
You should double check on realism.com, but Iím pretty sure itís the exact same clutch pack. You should be able to hold that much torque without issue on stick clutch pack. Maybe yours is just worn out?
Exclamation 06-30-2019, 03:10 AM
As i heared differance is in quantity of clutch pack plates between m5 f10 dct and 335is dct, but i don't know actually, someone knows exaclty what is differance?
katsooba's Avatar
Car: 135i N55 DCT
Default 01-18-2020, 01:39 AM
any new reviews on the SMFW vs the M4 DMFW?
Default 01-18-2020, 04:56 PM
From what I understand the m factory has a lot more chatter. I ended up going with a used m2/3/4 flywheel from ebay. Sliiightest amount of chatter at idle that I believe would be complete gone if I raised the idle slightly via MHD but it doesn’t bother me at all. Drives like stock. In 7th gear in auto mode when the engine is cold sometimes I hear the chatter at 1500 rpm. But when warm that goes away. Not sure of the long term impacts between the two, but I think it’s safe to say there are zero impacts with the dmfw.
Most importantly, No more phantom misfires. This is on 99 octane using boostane to bump up the crappy California 91 octane, DI only, PS2: https://***********/u/houtan/acn-rev13h?log=0&data=4-16. That’s weird, datazap is blocked for some reason. Replace the ********* with datazap dot me
BeGooD69 BeGooD69 is offline
Default 02-01-2020, 11:16 PM
Have a M4 dct flywheel for sell if anyone is interested.
Asking price is $600 shipped within CONUS. Pm me.
Needed a 8 bolts, and the m4 is 6 bolts. I had to get the mfactory one.
