romnation romnation is offline
Car: 2009 135i
Default What's the highest percentage of E85 I can run without cold start problems? - 10-25-2018, 10:24 AM
What's the highest percentage of E85 I can run without cold start problems in winter? I'm in Chicago, so we could definitely see 0F temps, or even possibly single digit negatives in the thick of winter. What is a safe number to run where i won't have issues? Will 30% be okay?
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 10-25-2018, 10:43 AM
Pretty sure the only limit is your ability to tune it correctly to run whatever fuel % you want. Fuel tables can be adjusted to run full e85 in the cold with no issue.
07 335i e92 - money pit
fnne99 fnne99 is offline
Car: 2008 335xi
Default 10-25-2018, 11:28 AM
When we had our e92, I ran e30-e35 for years in Denver in the middle of the winter when temps routinely got down to single digits or below zero with no starting issues. Maybe a long crank once in awhile and rough initial idle occasionally but no real problems. This was with just the jb4 and also the jb4+tune.
Maybe I was lucky...
BMWSwede BMWSwede is offline
Car: 2007 BMW E91 335Xi
Default 10-25-2018, 02:15 PM
I live in nothern Sweden an we have -22F or even lower in winter.
And I have no problem with E40. Running E85 flash
2007 E91 335Xi M-Sport MT
FBO W In/outlets
Custom BEF
Stock turbo @ 23psi
E40
440 AWHP
Default 10-25-2018, 03:10 PM
We run straight E85 down to 40F without issue. May idle a bit rough for the first 30 seconds but never fails to start.
hi rpm's Avatar
hi rpm hi rpm is offline
Car: 2013 335i xDrive Coupe
Default 10-25-2018, 03:14 PM
I ran 30% last winter with no problem, single digits a few times I think. I've already had some hesitation at 50% below 50ish, but it starts.
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 10-26-2018, 06:03 AM
I stop running a mix in winter just because I don't want to freeze my ass off standing at the pump swiping a card twice and dealing with all that.
Car: 2007 e90 335i
Default 10-26-2018, 11:23 PM
There is a huge difference for cold start when your comparing e40 to full E85. I run 100% full E85 in my s2000 and if it’s in the 40,s it starts and runs like crap for the first minute or so. If I put even 1 or 2 gallons of 91 octane in it lowering it to about e70 it starts and runs like normal.
2007 e90 335i
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 11-05-2018, 05:09 PM
With the tune set property, 90% ethanol can start at about 6*F.
This was a buddy with 87% ethanol in Colorado when we first tested the cold start tables. Not sure if backend flashes have them.
https://youtu.be/mr1YRRLYP28
Ron Vogel Ron Vogel is offline
Car: E61 535Xi
Default 11-05-2018, 08:10 PM
Compression is a factor too. On our motors should start pretty low. I had a GTP on full e85...and it would crank and crank trying to start under 40F. I am in Chicagoland, so I wouldnt try more than e40. those occassional -20f days are a bitch
hi rpm's Avatar
Default 11-10-2018, 11:31 AM
FYI after overnight low of about 15F, dash reading 23F, it took three tries to start without dying this morning. 50% E.
Car: E61 535Xi
Default 11-12-2018, 12:25 AM
Running e40...started fine. Boost is off the charts though...
Default 11-12-2018, 12:54 AM
I kept full e85 in my car for an entire Chicago winter, car never didn’t start.
