bmweurotuning's Avatar
bmweurotuning bmweurotuning is offline
Car: Bmw 335i ST
Default 335i stock turbo @19.5psi dyno - 07-19-2018, 08:23 PM
video here:
https://youtu.be/moJOt_o_qXY
mods:
JB4,dci's,Bef, @19.5 psi -------NO MHD----
Outside Temp was 102F
YOUTUBE CHANNEL:https://www.youtube.com/channel/UCQi...u2MWT7P2ZYus5g
ONLINE STORE :http://bmweurotuning.org/store
YOTUBE VIDS: http://bmweurotuning.org/videos
HOT VIDS:
WEBSITE: http://www.bmweurotuning.org
FACEBOOK GROUP: https://www.facebook.com/groups/657429951109356/
INSTAGRAM : https://www.instagram.com/bmweurotuning
For more info on jb4 products for your turbocharged bmw click here:
http://www.burgertuning.com/
jordan313 jordan313 is offline
Default 07-19-2018, 08:44 PM
nice bro
Alpine1 Alpine1 is offline
Car: 2009 135i alpine white
Default 07-19-2018, 09:00 PM
Dern. Great job.
Default 07-19-2018, 11:13 PM
Nice #s
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: Bmw 335i ST
Default 07-19-2018, 11:50 PM
Originally Posted by Dave @ Fuel-it!
Nice #s
nice numbers w horrible out temp
Ballistic Ballistic is offline
Car: BMW 335i N54
Default 07-20-2018, 03:15 AM
Resolution is so low; Can't read anything. What's it saying?
Riceball777 Riceball777 is offline
Car: 2007 e90 335i
Default 07-20-2018, 03:34 AM
What fuel is this on?
2007 e90 335i
pure stgae 2 DD turbos, rb inlets, bms 4 bar map sensor
Jb4 with mhd hybrid e85 back end flash, vrsf down pipe vrsf 7" intercooler, vrsf charge pipe with tial bov and afe intake. Fuel it stage 2 pump and fuel line/ethanol content kit.
spec stage 2+ clutch with new oem dmfw
Car: Bmw 335i ST
Default 07-20-2018, 09:34 AM
e30 mix @19.5psi
Car: Bmw 335i ST
Default 07-20-2018, 09:35 AM
ill try to get a better pic from owner
keninger keninger is offline
Car: 335i E92
Default 07-22-2018, 07:23 AM
What numbers was it making? Sorry can't really make it out of the picture due to low quality. E30 mix with 91 or 93?
Car: 2008 E93
Default 07-22-2018, 10:56 AM
Thats a LOT of torque to get that thing moving
Car: 2008 E93
Default 07-22-2018, 10:57 AM
91 or 93 wouldnt matter? Still E30 either way.
Car: 2008 E93
Default 07-22-2018, 11:32 AM
Originally Posted by bmweurotuning
video here:
mods:
HOT VIDS:
Can you post a better pic of the dyno sheet ?
Car: Bmw 335i ST
Default 07-22-2018, 11:37 AM
pic n vid can be found here:
https://www.instagram.com/p/BlRP1Oll...=bmweurotuning
Car: Bmw 335i ST
Default 07-22-2018, 11:42 AM
the car is a 2009 bmw 335i 6 speed manual
mods : Jb4,Dci's, Bms BEF, Running e40, New 335is clutch.
3 pulls were made @102f outside temp... after 1 hr run car on dyno again and the outcome was 420hp, 520tq. @ 19.5 psi. i will post new dyno data sheet after couple mods coming up.. it should be around 540hp @22psi. 5xxtq.
freddyamazin freddyamazin is offline
Car: e92 335i
Default 07-23-2018, 02:39 AM
Im assuming you meant 440whp, 120whp off 3 psi would be insane
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 07-24-2018, 09:55 AM
I expect this is all crank horse power.
You wouldn't get 500whp from stock turbos on a proper dyno.
Car: Bmw 335i ST
Default 07-24-2018, 10:01 AM
this is not crank horse power is to the wheels and yes you can go over 500 on stock turbos if you know how to build your car and have a professional tuner that knows what he is doing!
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 07-24-2018, 06:48 PM
I have heard 500whp is possible on stockers but they will live a short life. I say no way to 540WHP regardless of any magical tune.
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.58@121.67
335i FBO,Meth,MHD,XHP3,LSD, 12.1@118, Now with GCLites
Car: Bmw 335i ST
Default 07-24-2018, 07:01 PM
its not only about the tune. you also have to have proper fuel such as upgraded fuel pump Lpfp and add port injection on your hpf side + adjust other components w jb4 as needed based on logs.... and yes it its possible 540hp on a cold day lets say weather temps 65F.. @22psi on a fbo 335i ... keep on mind anything more than 22 its not reccomended since turbos dont make any more pwr...
blown07's Avatar
Car: 335xi, 335i
Default 07-25-2018, 11:35 AM
How much boost are you hoping to see at redline to make 540WHP?
Car: Bmw 335i ST
Default 07-25-2018, 11:50 AM
you dont redline on stock turbos , after 6krpm stock turbos dont make more pwr. i can achieve 540whp at 21psi w proper fuel pi, meth e85 ...
Car: Bmw 335i ST
Default 07-25-2018, 11:54 AM
and your answer is at redine 10psi
socaln54 socaln54 is offline
Car: 535i
Default 07-25-2018, 03:33 PM
what exactly do you recommend to achieve 500rwhp on stock turbos, planning on swapping mine for a brand new stock set
Car: Bmw 335i ST
Default 07-25-2018, 03:37 PM
Besides all bolt ons, you will need port injection, and a stage 3 low pressure fuel pump, along w a good tuner who can fine tune boost target. At certain rpms etc.. Also make sure all your spark plugs are up to date ign coils, get colder plugs. Step 2. At least .
