(#26)
Bushidopupil's Avatar
Bushidopupil Bushidopupil is offline
Car: 2011 CTS-V Coupe
Default 04-21-2018, 03:22 PM
Terry,
Do you run the factory engine oil in your M cars?
Default 04-21-2018, 05:39 PM
Normally yes. Sometimes Mobile 1 0-40.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-21-2018, 09:57 PM
+1
Same here unless I take my cars to the track, and in that case I like to use Pennzoil ultra platinum 0w-40.
Mods: Stock for now
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 04-28-2018, 06:25 PM
If using 100% e85, how often would u change your oil?
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018” gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020”, stock everything else, 374.9 rwkw Mainline Dyno Aus
Default 05-06-2018, 07:42 PM
Terry,
Any update on your F90? Should be arriving soon correct?
sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 05-10-2018, 04:00 PM
Looks like the BMS F90 has landed
2018 BMW M550i
BMS JB4 & DME bef
1/4 mile 10.9 @ 125
Default 05-10-2018, 04:43 PM
Yes it's going to be a busy week. Customer also dropped off a C63 AMG we've been wanting to make a JB4 for.
Default 05-10-2018, 05:14 PM
Awesome, looking forward to what they pick up from just the JB4!!
Default 05-10-2018, 07:14 PM
That one should be quick, I think you'll like the car. I already got a few inquiries on Instagram just by stating that were working on one!
Default 05-10-2018, 08:17 PM
Took a short drive in it. Pretty sweet car. Tucked it away in the garage until I can wrap up the C63 but poking around under the hood, I can see the TMAP sensors are super easy to reach. Always good news.
Default 05-10-2018, 08:44 PM
Attachment 74295
Attachment 74294
Woah!!! That is beautiful, can't wait to see it in person.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 05-11-2018, 09:33 AM
Awesome!
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 05-11-2018, 03:23 PM
Nice!!
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Default 05-12-2018, 06:21 PM
Stoked! Great color choice!!
Default 05-12-2018, 06:27 PM
Making good progress on the CANbus programming but haven't been able to do many WOT pulls.
Interestingly before I even started working on the car yesterday it sputtered and stalled out at low speed, like it ran out of gas but had plenty. I coasted home down the street, read the codes with a BavTech, high fuel pressure system low. Turned car off and back on again, and it came back to life. When the motor stalls out it shifts itself in to neutral which is pretty handy. Anyway put it in the garage and I've been working on it via the OBDII port ever since. About done and then I'll try to get some 100% stock baseline dragy tests. If it craps out again back to the dealer for a new fuel pump I guess. It has around 75miles on it so if something isn't right from the factory this is normally when it gives out.
Default 05-12-2018, 06:32 PM
Wow! Interesting to see how that plays out. Hopefully a very quick/easy fix.
Default 05-12-2018, 06:42 PM
Super annoying considering it's all stock. But glad something came up now before I started taking it apart to install parts! Just hope I don't get stranded with it lol.
onfire onfire is offline
Car: X5 50i F15
Default 05-13-2018, 10:42 AM
High pressure code has hit a lot of new M5’s. You program needs to be updated to 530 or higher. Should have been done at the dealer before you picked it up. Slackers. It will continue to happen until reprogrammed.
Default 05-13-2018, 10:54 AM
Good thing that the issue has been discovered and corrected on other vehicles.
Default 05-13-2018, 06:58 PM
Makes sense. Took the wife and kid out for a drive today and car stalled out on the freeway, lol. Luckily after I coasted through traffic to the shoulder I was able to get it restarted and home to switch for another car.
Got CANbus up and running and have some good data. If anyone has an F90, enjoys R&D type stuff, and wants to start having some fun just email me.
Default 05-13-2018, 09:47 PM
No way, that's not good at all. After waiting all this time and having this happen WTF. Glad you guys are safe, that must have been scary man.
Car: 335i, 2009
Default 05-14-2018, 08:47 AM
Bring it back to Bob Smith asap! Shame it isn't running right.Wish I could help with the F90, that I don't have...! Good luck with getting this issued resolved asap.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Default 05-14-2018, 05:06 PM
It's back over there. Hopefully a quick fix and I can get back to work.
TTM5 TTM5 is offline
Car: M5
Smile 05-16-2018, 05:52 PM
Well that’s just wheelspin waiting to happen, f10 m5 all over again....
Default 05-16-2018, 09:14 PM
Didn't make much progress on the C63 tuning. A rat in my driveway chewed through an o2 sensor, lol. I was able to get the CANbus going though and spec out the harness.
