(#51)
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 03-10-2017, 04:22 PM
Originally Posted by 535_BiTurbo
how much do these units run?
How difficult is the turbo swap?
Im thinking of finding some used units and sending them off to Pure or going with some Alpina or N63tu units and swapping them out.
N63 Stg1 -
http://www.pureturbos.com/store/bmw-...de-turbos.html
N63 Stg2 -
http://www.pureturbos.com/store/bmw-...rbos-1133.html
Alpina and N63tu both have smaller wheels, and flow less than our upgrades.
Morebs4me Morebs4me is offline
Car: 2013 550i m-sport
Default 03-13-2017, 09:55 AM
How does it compare to m5 stock turbo?
Default 03-13-2017, 01:47 PM
Larger than M5 stock turbo.
Default 03-14-2017, 05:39 PM
Are you gonna try higher psi? I'm curious what it can handle with the meth. My meth system is in the mail.
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 03-22-2017, 04:10 PM
The stage 1 are larger than stock m5? So how much more fuel does the n63 have?
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo 440rwhp street bike
1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
87 fox ls1 h/c/I 4l60e
BusaR8 BusaR8 is offline
Car: 335, CLS, Busa
Default 03-27-2017, 03:05 PM
Need a set!
JP Work 6466 Gen 2 Kit 335 e90
m5james's Avatar
m5james m5james is offline
Default 10-17-2017, 04:21 PM
Originally Posted by BMRDude
I am currently running 24 psi on stock turbos so I would hope the Pure Stage 1 is good for a few more than 25. I am currently waiting for better charge pipe options from BMS before moving further.
What JB4 settings are you running to reach 25psi? While a different vehicle, anything above 21psi in my X5M and it falls on its face with overboost errors. Terry said the X5M already comes with 3.5 bar TMAP sensors, I'm already running the "F-series Engine Type" settings so I'm at a loss here.
'08 BMW 535xiT - MHD 1+, BMS DCI, RB/Mishimoto, VRSF 7"
byebyev8 byebyev8 is offline
Car: 2007 335i coupe
Default 10-19-2017, 06:27 PM
How's the motor holding up at these power levels? Strongly considering getting rid of my 335 for one of these if I can reliably make 600whp.
BMRDude BMRDude is offline
Car: 2012 550ix
Default 10-20-2017, 08:12 PM
M5, I run between 23.5 and 24 psi withe the right fuel. Haven’t tried higher cause I am starting to run lean with trims maxed out. All map 6 no special settings. Just ramping the boost up to 4000, leveling out thru 5500, then tailing down a bit to redline.
Using FOL at 90. I get a drivetrain error but this error does not reduce power so I just ignore it and clear it later. I presume this is a high fuel pressure warning.
I run new TMAP sensors, one step cooler plugs gapped to 0.022.
I may try to go higher boost now that weather has cooled.
Car: 2012 550ix
Default 10-20-2017, 08:30 PM
Byebye. My N63 has been great. Bought it new in 2012 so I had the customer service updates but I never experienced any problems. I have seen a number of N63s opened up and every one of them had a bunch of sludge build up due to oil failure. Made for lots of replacement long blocks and valve seals. BMW did oil changes at 15,000 miles. This was way too long for an engine with top mount turbos. They might have gotten away with it if they were using Amsoil or royal purple. They were using Castrol. I have always done my oil changes at 5000, so no problems.
In 2014 they lowered oil change intervals down to 10000 miles and changed to a synthetic from Chevron labeled as BMW OIL.
m5james's Avatar
Default 10-23-2017, 08:30 PM
I'd like to see a screenshot of your map 6 settings before you go.
Thanks for your input over the years. What are you getting next?
Car: 2012 550ix
Default Map 6 settings - 10-24-2017, 08:12 PM
Current settings. Map 6 is additive, not absolute.
J. Dub J. Dub is offline
Default 12-14-2017, 12:15 AM
Originally Posted by Mike_L
A few questions.
1. What MAF housings and intakes are those?
2. Is that car AWD? That would make it more special.
3. 6 speed or 8 speed?
One more.
4. Is this even possible with a TU until Terry makes a JB4 for it? I can't imagine owning another BMW out of warranty after what the last one cost me, and all the F10 LCIs that are covered have the N63N.
Exactly my thoughts Mike. I like how no one addressed your questions. /s
Default 12-14-2017, 10:08 AM
No idea.
It's not, as you can see it on a 2wd dyno in the pic in post #1.
8 spd
Yes it's more possible with a TU. The JB4 has even better tuning capabilities with the newer TU engines.
Default 12-14-2017, 10:10 AM
No idea.
8 spd
Nice
HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default 06-10-2019, 03:19 PM
Any updates on how big power N63TUs are holding up? Loving my 50i with BM3 and JB4 in map 1. I have 3.5 bar maps ready to go in. Also interested in Pure turbos, but not much info on how these motors hold up...
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 06-10-2019, 04:06 PM
This thread for non TU motor
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Default 06-10-2019, 04:08 PM
Whoops haha. I'm interested in non TU as well. Internals are mostly the same...
M335's Avatar
Car: 2011 E90 335i
Default 06-10-2019, 04:24 PM
Nope, different heads with camshaft and injectors.
Default 06-10-2019, 04:49 PM
I'm more interested in how the pistons and rods hold up. Cams don't break with more power.
M335's Avatar
Car: 2011 E90 335i
Default 06-10-2019, 05:00 PM
On TU motors rods & pistons are the same as on s63tu/m5
Default 06-10-2019, 05:26 PM
Sweet. Thanks for the info. I'll have to see how they're holding up.
Bejhtia_23 Bejhtia_23 is offline
BMW F80/E71 N63
Car: 2012 BMW X6 50I N63
Default High Boost N63 - 08-08-2019, 06:27 PM
Guys I have one question, How are youíll doing for the transmission??! I see some are doing 24-25 and even higher boost. Iím currently stuck on 17-18 with pure stge2 + meth, etc. Full back end flash and separate meth controller, it feels strong but I havenít been able to go beyond 17-18 on boost without throwing high torque error codes from TCU. Can someone please advise? Maybe Iím missing something!
