(#376)
ricecrackers101 ricecrackers101 is offline
Car: 335xi
Default 05-21-2016, 01:42 PM
Originally Posted by weebles
You're running 19 psi on pump gas? I can't even get close to that with just pump (94 e10) I drop all my timing around 17 psi on pump. I'm running 70 additive on map 3 right now and the car is an absolute monster, loving it so far.
are you using petro ultra 94? how much boost do your logs show with meth? does it taper way down towards redline like it does with stock turbos or does it hold boost to redline.
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 06-16-2016, 11:39 PM
I'm really interested in these pure stge 2 turbos!!!! Eill u accept trade in the stock turbos? Since now i'm using hybrid turbos which my friend bought, don't even know what brand. Looking at the pure turbos, makes me want to try it out! Mine is rhd
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 06-17-2016, 08:58 AM
Yes, we accept stock turbos for the core exchange. That's the normal procedure. You can email info@pureturbos.com with more questions if you wish. Thanks
icechilli icechilli is offline
Car: BMW 1M Coupe
Default 06-27-2016, 07:04 AM
Are there any difference between the turbos on the LHD and RHD n54 turbos?
And will you guys be developing a Stage 3 setup?
jrmy23's Avatar
jrmy23 jrmy23 is offline
Car: 2009 BMW 335i Sedan
Default 08-06-2016, 02:42 PM
Any of my Purestage2 family have there n54s out with no issues? I have a misfire that i cant seem to get rid of, so i been going to map4 for the longest. i dont see much news on these anymore other then the M5.
FBO N54, DOC 6466 Boostbox MHD, EOS intake manifold w/PI, Fuel-it stage 3, Xhp stage3, Zebra Cake coils, etc etc.....
Default Pure Stg2 - 08-06-2016, 07:44 PM
A misfire is not turbo related. It will usually be one of the following in order of most common: spark plug, ignition coil, tuning or cylinder compression related.
We haven't posted N54 Stg2 updates recently. Yet we have consistently been selling numerous sets of N54 PURE Stg2. We have been informed our N54 turbos are much more reliable than some of the other options available. We have been hearing it a lot lately, and many shops have "switched over" to PURE. Which is great news! We consistently see lots of dyno results popping up. Many on IG and FB. We are a busy shop without social media staff, we have lots of new upgrades and projects happening. Some being N54 related
If you have a misfire, post a log in the support section so BMS can help you sort it out. Which plug and gap are you running?
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 08-07-2016, 04:35 AM
You guys should make a stage 1 for N54. I would buy them.
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.58@121.67
335i FBO,Meth,MHD,XHP3,LSD, 12.1@118, Now with GCLites
lightning lightning is offline
Car: BMW 1M Coupe
Default 08-12-2016, 01:07 AM
Hey there,
N54 here with Pure Stage 2s. Mine have been running great, about 10,000kms on the clock :D V reliable!!!
I had some smoking initially at 3000kms, and it turned out to be a faulty injector. Smoking stopped completely when the injector was changed. so I'd suggest that you go through the standard procedure that all of us do when we get misfires, which is to check your spark plugs, ignition coils, and injectors.
It would be very very rare for a turbo to cause you to have misfires, and as Pure has mentioned do post your logs onto the help section so that the good people here can advise you accordingly. We are blessed to have the ability to log our engines so use it to your advantage :D
Default 08-12-2016, 08:58 AM
It's coming soon
08_335i 08_335i is offline
Car: 2008 335i
Default 08-12-2016, 10:33 AM
There's like a 1% chance your misfire is caused by turbos, and the only way they would cause it is if you were running to much boost which would then lead back to tune related or hardware related, not turbo related. I'd be checking the usuals as stated above, plugs, coils, and injectors.
Cloud9Blue Cloud9Blue is offline
Car: 09 E92 335i
Default 08-12-2016, 11:39 AM
It's coming soon
yes please...
09 BMW E92 335i: EFR 7670 / Motiv / AP Racing / Wavetrac / TC Kline [Full Modlist]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
jrmy23's Avatar
Default 08-12-2016, 12:15 PM
I wasn't saying the turbos were the cause of my misfire, my turbos are excellent!!! I have a front 02 sensor that went to crap, which is giving me a 2C9D (Lambda probe heating in front of catalytic converter 2, input signal) which is making me run lean. My afr2 is reading 20.0 which is kicking me to map 4. I have the ngk 5992's gapped at .22. Once i get this 02 sensor il send some logs!
jasonnevis jasonnevis is offline
Default 08-13-2016, 10:44 PM
Hi Pure,
Can you tell me if you will have stage 3 turbo's being released soon. I want to upgrade my turbo's, but want max power!
bigjoe53's Avatar
bigjoe53 bigjoe53 is offline
Car: 2008 E90 335xi
Default 10-23-2017, 10:53 AM
It's coming soon
Pure, any word on the progress for the stage 1 setup?
NYC ALIVE
E90 335xi FBO,JB4 5g, Borla exhaust, VRSF Cats, KW V3, Apex PS7 wheels, Smoking Turbos.....
Bullitt1841's Avatar
Default 10-23-2017, 10:59 AM
It's been around for a couple years now, but not listed on their website. If you Google search it, there are several vendors' sites that it pops up on.
