Default 07-04-2017, 05:26 PM
The metal pipe sitting on the exhaust side of the engine just bakes. For the pressure testing we simply connected a vacuum gauge at the turbo and tested 4 intakes at around 24psi. Stock, BMS, AFE, and Inj. The factory piping around the inlet is really good, no reason to replace that.
If you have a port injection kit and reinstall the BMS filter mount you can wind up with the intake popping out of the factory inlet piece though. So with port injection added be sure NOT to use the intake bracket and instead just zip-tie it to the fuel rail.
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 07-05-2017, 04:22 AM
Originally Posted by houtan
This would be great, but I think something with the maf needs to be rescaled. Which I believe can be done in mhd, but not sure.
If the maf scaling doesnt need to be rescaled for the injen intake why would it need to be scaled for a shorter intake with the same diameter?
The air coming in at 4 inches from the filter will be the same if the intake if 50 ft or 10 inches, right?
So if the 3 inches diameter doesnt effect the maf scaling, maybe someone could make a maf wire extention and adapter and slap it on a pure inlet (E series n55) and see what happenes
I, for one would be happy to get the clean n54 short intake look on the n55
All of that plastic in the engine bay makes it feel like a honda
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
houtan houtan is offline
Default 07-05-2017, 09:02 AM
What you say makes sense to me. But I guess we won't know until someone actually tries it.
Suckadeez's Avatar
Suckadeez Suckadeez is offline
Car: 2011 335xi
Default 07-05-2017, 12:44 PM
I remember looking inside my injen intake and right where you would insert the maf across from the bottom of the maf they had another circular steel tube. about 1 1/4 inches round and maybe 2 inches long. never consider what it might have been for till now.
2011 335xi e92
deep sea blue metallic
Mods: ps2; cobb fmic; vrsf ⬇️pipe; phoenix racing cp; injen cai; pure inlet; fuel it stage 2 lpfp w/ sensor; jb4 w/mhd e85 bef; meth 90/10 do3 and do7 nozzles. n20 tmap. Alpina flash. Fuel it port injection e50
orteeze orteeze is offline
Car: 08' 335i
Default 07-05-2017, 12:45 PM
Like this??
http://www.n54tech.com/forums/showpo...&postcount=508
E90 LCI M Sport
Default 07-07-2017, 05:32 PM
Originally Posted by orteeze
Sort of. But that is running no maf. We are talking about a short intake with the maf.
