(#576)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD Update v0.71 - 02-08-2017, 02:48 AM
- added "Transmission temperature" log/gauges channel on AT and DCT
- updated all DME error code descriptions, fixed missing English translations
- fixed "generate Bin" function on DME replaced since 2016
- minor bug fixes
Alpha Twins's Avatar
Alpha Twins Alpha Twins is offline
Car: E92-335i-N55-2011
Default 02-08-2017, 12:36 PM
Is the transmission temp on MHD APP ? or also on the Jb4 Mobile app ?
Where can i find the download ?
E92 335i 2011 N55 | JB4 G5 ISO | M Performance Exhaust | BMS ** | Wagner evo 2 comp Intercooler | BMS catchcan | BMS Chargepipe | MHD FLASH
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 02-08-2017, 12:48 PM
It's obviously not going to be the JB4 app. Go to the playstore on your device and update the MHD app.
E90 N55 RWD 6MT MHD Speedtech EFR7670 MFactory LSD
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 02-16-2017, 03:14 AM
Just had a quick question regarding the pump bef and the e85 bef. I'm going to be flashing here in a few days and i'm somewhat unsure of which one to use, as i'm always straddling 40-50%+ e85, usually somewhere in between. I know the pump bef says 'around 40%', while the e85 says 40%+.
Should I just flash the pump bef, log, then go from there if need be? What's the difference between the two - more aggressive timing? Apologies for the newb question hah. Much appreciated.
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF **, VRSF 7in. FMIC,
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default xdf update - 02-16-2017, 06:32 AM
The xdf file has now the 4 tables for fuel enrichment at startup:
AT and MT are setup identically. But there are 2 versions for VVT and Throttled operations. I'd really like some feedback from heavy ethanol users, to understand the difference between VVT / Throttled operations.
Good bye low temp long cranks!
Default 02-16-2017, 06:46 AM
Hah, must of forgot much of this thread, as I just found the answers more or less throughout the thread
Will try the pump bef first, log a couple then post them in support. If things look good I'll give the e85 bef a try, etc etc.
Default 02-16-2017, 07:09 AM
ghtyr's Avatar
ghtyr ghtyr is offline
Car: 2011 BMW 335i xDrive 6mt
Default 02-16-2017, 12:04 PM
Any way to do full "hold DTC button" off at startup for an xDrive? I remember jb4 has an option to do a push of the button at startup, but not for xDrive.
2011 E92 335i xDrive N55 6MT PWG
PS2, Pure Inlet, GFB DV+, BMS Intake, ********* **, ER CP, Dinan Exhaust, CM10 + CM5 Dual nozzle BMS Meth (99.99%), JB4 ISO 5.14, Pump BEF MHD
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-16-2017, 12:47 PM
I would use and prefer this option if available.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Ichiban Ichiban is offline
Car: 135i DCT
Default 02-16-2017, 01:21 PM
I have problems with my car having a low temp long crank, the weather on the east coast is just terrible this year. I thought for a second it was my HPFP going out but after several pulls and continuous driving I see no signs of a limp mode or reduced power. Is this part of the tunes?
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 02-16-2017, 02:39 PM
Martial, any chance you tell us what the rows, columns, and values represent? (for the fuel start tables) Thanks!
2011 E92 N55 xDrive 6MT
Pure Stg 2 | DV+ | Pure inlet | MHD/JB4
Stage 2 lpfp | BMS Intake | Shifteck 4-inch "expansion chamber" | MXP catback
VRSF 7" FMIC | ECS 2-piece rotors
255/40-18 square | 8.5x18 ET35
Fortune Auto MSC-1 coilovers 8k/10k
Default 02-17-2017, 03:14 PM
Skimming through this entire thread once again there's a question that I have - once I load the BEF and update to the latest ISO firmware, I thought I remembered reading that due to the firmware - maps 1,2,7 have different boost targets? If this the case, and if so what are the updated values? Thanks
Car: 2011 e92 335i
Default 02-17-2017, 03:17 PM
If 2/2 is selected it will change the boost targets to be similar to N20 TMAP targets. Since I have a N20 TMAP I do not know what it will set it to. I recall map 1 now being 15 psi.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
1slowN55 1slowN55 is offline
Default 02-22-2017, 05:07 AM
Hey Terry,
Is it possible to add a race gas flash for those of us who occasionally throw ms109 or 100octane in the car?
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Lindi95's Avatar
Lindi95 Lindi95 is offline
Lindi95
Car: 335xi N55 2011
Default 02-22-2017, 05:05 PM
Any updates on two step and burble intensity? Those two would be fun to have.
sparky_phantom sparky_phantom is offline
Car: 2011 BMW 135i DCT
Default 02-22-2017, 06:07 PM
I second this, also for idle raising for the chatter on a single mass flywheel.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 02-23-2017, 09:04 AM
For now, the e30 OTS tune has not been updated with tuned values for cranking, I don't think that's necessary. Do you let long cranks using ethanol mix or pump gas?
It's all in tuner pro. Use F2 to get infos. X is RPM, Y temp in C, table is fuel enrichment %.
Default 02-23-2017, 10:18 AM
For now, the e30 OTS tune has not been updated with tuned values for cranking, I don't think that's necessary. Do you let long cranks using ethanol mix or pump gas?.
There's a few of us that have noticed the long cranks in cold weather with Ethanol blends.
Default 02-23-2017, 10:22 AM
Yup I have had that too. Didn't know if that was normal or not. First time really running E85 Blend. Only at start of day. Starts up almost instantly all other times throughout the day.
Soflo_335xi Soflo_335xi is offline
Car: 2011 335i Xdrive Sedan
Default 02-23-2017, 05:50 PM
Still waiting for the rolling anti lag possibilities
Default 02-23-2017, 06:28 PM
2/23/17 JB4 MHD N55 Map Release
1) Adjusted load to eliminate a potential misfire problem on higher boost cars
2) Combined USA and EU files so EU vehicles no longer need a dedicated file
Car: 135i DCT
Default 02-23-2017, 09:40 PM
Long cranks on pump gas.
lllN54lll's Avatar
lllN54lll lllN54lll is offline
Car: 335i N54
Smile 02-24-2017, 12:07 AM
Note for next beta BEF
(16 13 7 193 479) Leak diagnosis pump is not installed in EU cars.
3224 DMTL heating
321B DMTL solenoid
3227 DMTL pump
Weehe Weehe is offline
Default 02-24-2017, 06:43 AM
Probably your HPFP then. I had the same problem.
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 02-24-2017, 08:03 AM
3224 DMTL heating
321B DMTL solenoid
3227 DMTL pump
i think this is what is causing my check engine light to come up under 7th gear accelerations
i am getting contant 2906 codes only under dct 7th gear highway accelerations
60mph 7th gear on 2200 rpm
push the pedal
check engine - reduced power
this started happening ONLY after the BEF flash on my EU car.
i will try the new BEF flash over the weekend with the EU parameters and see if it fixes it.
never had 2906 before the BEF
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
