Stoolz Stoolz is offline
Car: 11 135i
Default Battery Flattened - 01-30-2017, 11:45 PM
I'm fbo N55, i found my car in the garage this afternoon with an electric motor sound running and my battery is flat now.
I've noticed this motor noise before but it's gone away after unlocking and locking the car.
I think there is an issue with doing the OCC mod if you dont leave the plug connected on the removed part, mine is still plugged in tho.
Any ideas?
Sound is coming from near my turbo?
Water pump or something?
Every time I lock the car it starts up about 10 seconds later.
Cheers,
Anthony
Default 01-31-2017, 11:18 AM
Not sure on that one...maybe somebody else can chime in?
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 01-31-2017, 11:54 AM
I had that same issue after I installed the OCC two years ago. The solution was to re-route the power source to the JB4.
I think I re-wired the JB4 power source to one of the blue wires coming out the boost solenoid plug (blue patch). Anyhow, I'm not sure of that because that happen a long time ago. I need to look at my car's DME box so I'll let you know later today.
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
Car: 11 135i
Default 01-31-2017, 12:52 PM
Cheers,
I'm running meth as well so i guess the meth controller supply gets relocated as well?
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-31-2017, 01:14 PM
hey Stoolz, is it a light beep? or an actual mechanical sound? like a pump or something bigger?
i think that what caused my battery to die too
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Car: 11 135i
Default 01-31-2017, 03:04 PM
It clicks a couple times then winds up like a small electric motor. Sound coming from turbo area I'm sure its the water pump.
Have OCC and heater is plugged in.
Default 01-31-2017, 03:11 PM
You can relocate the 12v power wire from constant to switched as a test for this. Emailed a photo of it.
Car: 11 135i
Default 01-31-2017, 03:34 PM
Ok thanks a million!
Just did the wiring swap.
IM FIXED!
Sam J Sam J is offline
Car: Bmw 135i E82
Default 02-01-2017, 05:20 AM
Could someone send me the wiring swap to? I am planning to install an occ on my 135in55 2011. Currently my jb4 is connected to red 12v cable. I should change this and should I change the meth controller also then?
Car: 11 135i
Default 02-01-2017, 01:23 PM
Image is also in this thread.
I'm not sure everybody needs to do this tho, only some vehicles.
Usually leaving the heater part plugged in does the job.
I think you see how it goes first.
http://www.n54tech.com/forums/showthread.php?t=31842
Car: Bmw 135i E82
Default 02-01-2017, 03:35 PM
Very strange, i own a E82 so I will first try the normal install. Then we will see what happens
BTW do I have to add wire to get it to the blue one? Or kan I just use the stock jb4 cables?
Car: 11 135i
Default 02-01-2017, 06:02 PM
You need to extend it.
Car: Bmw 135i E82
Default 02-02-2017, 04:17 AM
How if I may ask ;-)
