(#3976)
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-16-2017, 10:57 AM
hey DMAC!
that did the trick
seems to switch tabs rather nicely
just one questions, is it supposed to do it in a kind of a sweepy motion left to right?
some say even a bit laggy when switching screens but i know that is not the case, not so smooth transitions.
but good enough for me! back to the car the tablet goes!
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
chadillac2000's Avatar
Car: 2008 535i
Default 01-16-2017, 10:58 AM
Originally Posted by harkes
Repost once you know how the F-series is put together
I retract my previous statements and apologies to all! For some reason thought I was in the E-Series JB4 thread.
poteroa poteroa is offline
Car: 335i e93
Default rev1 kit - 01-18-2017, 08:53 AM
I got an old rev1 kit last week from ebay that has not been used for years, well thats what the seller told me.. He took the whole thing out when He sold the car long ago, and its been just lying around.
Been reading a lot of posts here, and seems it might have the "old firmware version" in it as I can not connect to it at all. I have the android app version, but even one guy from same BMW club could not connect to it with iPhone.
Does someone have the firmware update to that? (mini BLE I think, Have not opened it yet).
I know its a little awkward to use, like remove/install when using the app, but I really would like to get this working, as I paid for it.
I have been spending hours now to figure this out, and seems this is the only explanation why it does not connect..
Can anyone PM me the update file?
Ridergas Ridergas is offline
Car: BMW M135i F21
Default 01-18-2017, 09:07 AM
Android 6.0.1
Interface version A118
connection type Bluetooth rev3
Engine type N55 Fséries PWG
Phone Samsung Galaxy S6
Update 8b.hex ( version 9.hex the gear display don't work)
On the gear ratio display when I drive, it stops at 6 while I have 8 gears and in gear reverse it displays 7
maX5 maX5 is offline
Car: E90 335
Default 01-21-2017, 11:42 PM
Is there a way to control the exhaust valves to open/close via the bluetooth app ?
Car: 335i e93
Default Ethanol sensor support - 01-24-2017, 01:40 AM
Android 4.4.3
Interface version A122
connection type OTG
Engine type N54
Phone Samsung Galaxy S2 Plus
Update 32_5 G5 ISO
Is the app compatible showing ethanol content without bluetooth interface, with OTG?
I want to use common 13577394 Continental sensor to get ethanol content directly to Andoid app JB4 Mobile, (50-150Hz signal converted to 0-5v to pin 15 of JB4), correct?
Does the app support it directly, or is the bluetooth required add-on?
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 01-24-2017, 08:34 PM
Rev 1 kits are no longer supported due to outdated hardware, software, and some issues we had out of them. I offered a replacement program a year or so ago for original owners. There is a link to the firmware somewhere in this thread.
Originally Posted by Ridergas
Android 6.0.1
Not an app issue. If you have FUA set to 51, that messes with gear output to speed up the CAN bus. Tested it manually, and the app will allow gears all the way up to 10 if the JB4 outputs it.
Not at this time as that is a JB4 firmware limitation.
Android 4.4.3
connection type OTG
Engine type N54
Update 32_5 G5 ISO
Yes it will display E Content through OTG or BT in JB4 Mobile as long as you have a sensor and analyzer installed properly (including wiring it to the JB4). You will need our analyzer from here: http://www.fuel-it.biz/bluetooth-ethanol-analyzer/
Car: 335i e93
Default 01-24-2017, 10:09 PM
So it means that rev 1 kit does not work even with updated firmware anymore?
Originally Posted by Yes it will display E Content through OTG or BT in JB4 Mobile as long as you have a sensor and analyzer installed properly (including wiring it to the JB4). You will need our analyzer from here: [URL="http://www.fuel-it.biz/bluetooth-ethanol-analyzer/"
http://www.fuel-it.biz/bluetooth-ethanol-analyzer/[/URL]
Thank you, so all it needs is that analyzer that converts the signal to 0-5v which displays the content with 0v = 0% 5v = 100% content.
Car: 2008 135i
Default 01-29-2017, 12:31 AM
It should technically work.
Correct.
Car: 2008 135i
Default 01-29-2017, 12:34 AM
Looks like I've finally found a fix for the Android bug where the gauges would stop working. Testing has been positive over the past few days so expect a public release in the next couple days. This bug was an absolute PAIN to track down and is related to the crappy way Android handles backgrounded applications when the activity is killed, but not the process.
Herc Herc is offline
Car: F20 125i
Default 01-29-2017, 01:35 AM
Hello!
Recently I installed the beta on a Huawei 6 android
Much better BT connectivity. Before to connect, I may needed 2 or more attempts.
Gauges for temps on the N20 still not functional. Is rather strange because when first installed it i could see one of them. Got an update and they stop working. I could seen them with another famous obd program and had verified for true or false values from the so called secret menu. JB4 was bought before Christmas am guessing all are up to date.
I have not install the EWG positaps yet because i havent understand if the engine should be turn on running and proceed with the positaps update.
Great work so far!
Car: 2008 135i
Default 01-29-2017, 01:40 AM
Originally Posted by Herc
Hello!
Great work so far!
Not all engine types support all the temp outputs *through the JB4* at this time. You'll need to check if your engine type and firmware support the various temp outputs. For more help regarding that, please email Jon (jon@burgertuning.com).
Car: F20 125i
Default 01-29-2017, 04:28 AM
Will do in about week. Got rear ended by a cab driver and the car is going tomorrow to an authorize shop for repair and various services so had it uninstall.
Car: 335i e93
Default 01-30-2017, 08:25 AM
Sorry to bother you with this question about the old kit, but I can not find that firmware anywhere.. I am still struggling with this old rev1 kit. Can you please help.
Car: 2008 135i
Default 02-02-2017, 11:21 AM
You can give this a try. https://dl.dropboxusercontent.com/u/...T_20140409.bin
Not 100% sure that is the correct firmware though as I haven't seen the project for those units since they were discontinued/replaced a few years ago.
Firmware update info for that unit can be viewed here: https://github.com/RedBearLab/BLEMin...wareUpdate.pdf
Car: 2008 135i
Default 02-02-2017, 11:30 AM
New Android beta is up with a test fix for the "stuck interface/gauges" bug.
Car: 335i e93
Thumbs up 02-02-2017, 09:58 PM
Thank you!!! I give it a try.
Excellent, A122 Beta did not have the 0-60, so is it back in this new beta version?
enrita's Avatar
enrita enrita is offline
Default 02-03-2017, 06:31 AM
How do u change com port in the jb4 android app? I have a new android and says com port not available
Car: 335i e93
Default 02-03-2017, 10:50 AM
There is no way to change it, it means that application can not see the cable you connected to with your phone.
1. Check with the OTG cable that you can see flash drive in it (recognizes it)
- If it does, OTG cable is working.
- If it doesn´t, your phone / OS does not support "USB HOST MODE" or the cable is bad.
2. If flash drive is recognized, you need a driver support for ftdi chip, you can get it from play store, its free. just search for ftdi driver.
Hope you get it working..
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 02-04-2017, 07:18 AM
Is the save config and load config buttons only working in the beta version?
Cause I just loaded the app again from the App Store and the load config button is missing. iOS iPhone 6s.
puppywhirl puppywhirl is offline
Car: M235xi
Default 02-05-2017, 04:42 PM
Device: iPhone 6
OS: 10.1.2 iOS
Engine type: N55 F Series
App build: ios 6828
Kit Revision: REV3
JB4 Firmware Version: ewg 9
Problem experienced: JB4 will update firmware and change maps, MAP is the only thing that will display in live gages. Sometimes gear and iAT will display but its never correct.
Car: M235xi
Default 02-05-2017, 09:58 PM
Originally Posted by puppywhirl
Device: iPhone 6
OS: 10.1.2 iOS
App build: ios 6828
Kit Revision: REV3
I FIGURED IT OUT!
It was my P3 Vent Gauge. I was using it for oil temp really...Does JB4 do oil temp? Maybe I can mount a small tablet or something.
Anthony235's Avatar
Car: m235i
Default 02-06-2017, 09:43 AM
I FIGURED IT OUT!
Jb4 does oil temp with the BT connect.
Anthony235's Avatar
Car: m235i
Default 02-07-2017, 09:15 AM
Anyone?
Car: 2008 135i
Default 02-11-2017, 11:24 AM
Not yet. My testing with it hasn't been satisfactory yet.
Seems like an issue with the graphics in the release IPA. I'll get a new build uploaded tonight.
Again, for a *much* faster response email me: support@jb4connectkit.com
