(#7801)
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 10-15-2013, 01:00 PM
ISO 27.5 Notes
1) Additional mid throttle changes.
2) Corrected a bug for those running the 3.5 bar MAP sensor.
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 10-15-2013, 06:21 PM
Ok so I am about to sound like a damned fanboy, but HOLY MOTHERFRICKEN SQUIRREL NUTS I LOVE THIS ISO!
:D
Rattle is completely GONE. Same 10/12 settings. Throttle is smoooooth. Oscillations are all but gone - I have to intentionally be rough with the throttle to upset the ride. What's more, the exhaust note is quieter, probably because the wastegates are closed more often. This allows me to turn the CANflaps back off again which I have to turn on previously because of my new *** which made everything loud as hell.
I am totally amazed and totally satisfied! GREAT JOB Terry!!!!!
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE **'s + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
rwalker rwalker is offline
Default 10-15-2013, 07:47 PM
I rescind my previous endorsement of 27.2 as "best firmware yet". 27.5 (with JB flash) FTW.
Tmos's Avatar
Tmos Tmos is offline
Car: BMW 135i _ JB 4rd
Default 10-16-2013, 01:39 AM
Updated Pump flash + 27.5 = brilliantly smooth with loads of power up top & by far best to date. Thanks for your relentless effort Terry!!
2009 E82 135i MT | JB4 G5 ISO * TREBILA Performance Custom flash * cp-e CP / Forge Performance DVs * BMS DCI * WAGNER FMIC * Xcede Performance *** * ***** Mids * BMS OCC * BMS Thermostat * BMS CDV * BMS Clutch Stop * RB PCV
Grease Monkey's Avatar
Grease Monkey Grease Monkey is offline
Car: 335i xdrive
Default 10-16-2013, 07:55 AM
I'll update this evening (hopefully) and let everyone know how it works on a non-flashed car. To give the best picture, which map would be best to run the update on, map 2 or 5 for 93 octane only?
'09 335 xdrive: JB4 G5 ISO - BMS Pump Flash - E30 / BMS DCI / VRSF ** / VRSF FMIC / BMS CP / BMS CDV / BMS Clutch Stop / ZHP Shift Knob
'07 Mustang GT/CS vert: Intake / Tune / Straight ***** / Strut Brace
'67 Jacobsen Tractor: Yardwork Toy...
Grip&Go Grip&Go is offline
Car: 135
Default +1 - 10-16-2013, 07:58 AM
+1
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 10-16-2013, 08:00 AM
Non flash, probably Map 5....Terry?
EDIT:
I'm running the BMS Flash and I switched from Map 5 to Map 2 on Terry's suggestion and did not like it. Back on Map 5
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
Default 10-16-2013, 08:21 AM
For pump gas I personally prefer the fixed boost maps. 1 or 2. But many run and love map 5 on pump fuel. Try both and see what works best for your needs.
Car: 335i xdrive
Default 10-16-2013, 09:00 AM
Before upgrading my ********* I ran map 5 since it seemed to give slightly better performance, though Map 1 had great consistency and feel. The shop who installed the ********* recommended Map 2, and I love the feel. Just wanted to know if Map 5 held any irresistible benefit, but I do enjoy the set it and forget it nature of Map 2.
The few times I am able to mix in E85 I always run Map 5 though, I just wish I had closer access to the stuff. To be continued when I update this evening, thanks Terry!
Default 10-16-2013, 09:34 AM
It reads codes from the DME. They are not removed unless you delete them (or auto clear finds them and removes them).
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 10-16-2013, 11:03 AM
What kind of mid throttle changes were made on 27.5??
stevew145's Avatar
stevew145 stevew145 is offline
Car: 2008 135i
Default 10-16-2013, 01:47 PM
Updated to 27.5 this afternoon. Didn't really notice much but it does feel a little smoother driving around town.
I did have an issue though. Around block 350 my meth pump kicked in! Started spraying meth into my chargepipe. I hopped out of the car and pulled the quick connect on the red wire on the pump. The update continued, and upon connecting the pump back up, everything was normal. Obviously when i started the car it ran poorly for a minute, but a few revs burned it all off. After that everything was normal.
It may have been due to a previous error on my behalf though. On my first attempt to flash the software today, I opened the door (wasn't thinking) around 75% through the flash, turning the ignition off and losing connection to the jb4 causing an error saying there was no firmware on the jb4. I retried the flash and this is when the pump turned on. It was probably due to my own stupid fault. Just remember to sit still during flash!
Myrder Myrder is offline
Car: 2010 335i
Default 10-16-2013, 01:51 PM
Terry,
Anyway to enable Trims on the gas gauge. Like what is done for boost or IATs and so on?
Would be nice to see if we are maxing trims on the fly, allowing for monitoring E85 mixes.
Just a thought.
335i LMB E92 6MT MSport Logic7
laurean bmw 135i n54's Avatar
laurean bmw 135i n54 laurean bmw 135i n54 is offline
Car: bmw 135i n54
Default 10-16-2013, 04:30 PM
hello I have a question good guys choose the map 7 and after a career in the March 3 I switched to Map 4 which will be the problem?????? and I do not read any failure
Default 10-16-2013, 04:32 PM
Originally Posted by Myrder
Terry,
Just a thought.
Just monitor AFR. If trims are an issue AFR will lean out.
Car: bmw 135i n54
Default 10-16-2013, 04:43 PM
ok and what is the solution for that map is not changed? what would be the problem of afr terry Might be clearer that I struggle to understand language will thank you very much
Car: 2010 335i
Default 10-16-2013, 04:47 PM
sounds good. thanks Terry!
DAY DAY is offline
Car: BMW 135i
Default 10-16-2013, 09:28 PM
N54 135i with JB4 G5.
Muffler delete, BMS ********* *********, BMS DCI, 91oct. Safe to run map 2?
Default 10-17-2013, 05:53 AM
yes no problem
threethirtyfive threethirtyfive is offline
Car: 335i e90
Default 10-17-2013, 03:44 PM
The constant ninja deletes are super annoying man. There is no good active feedback from others running the same ISO in a random thread I post in the help section.
I'm not coming in here asking some dumb ass question, the new ISO 27.5 gave me a 29DC for no plausible reason so I provided feedback.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default 10-17-2013, 04:25 PM
I did post in the wrong section sorry Terry!
ashmostro's Avatar
Car: 2013 335is DCT
Default 10-18-2013, 04:04 AM
I tend to agree that sometimes the deletes are a bit heavy handed and feel outside of the spirit of the rule. I get why they are necessary but as in the example above, valuable developmental feedback about a beta software is lost to the public.
Just some candid feedback. You know we all appreciate so much what you do here and offline for us.
Rob S. Rob S. is offline
Car: E92 335i M-Sport
Default 10-18-2013, 04:48 AM
Somehow my posts from yesterday are deleted (regarding map 7 for Aral 102 octane)?
At the first page i see that for map 7 you need 100 octane or higher.
Since the German Aral is 102 octane i can use map 7 on my 335i with only mods JB4 G5 ISO + DCI, right? Or is +100 octane in the USA different then +100 octane in Europe??
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 10-18-2013, 05:34 AM
They were deleted because support questions aren't meant for this thread... Anyway I'm pretty sure you need to change ********* as well in order to run map 7. Emailing Terry or posting in the support section is your best option.
But in my opinion, switch out the stock *** for ***** less and you get a whole different car!
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 10-18-2013, 05:47 AM
Its not the same octane number for number. I don't remember the actual conversion but IIRC European 100 is equal to USA 93.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
