(#6726)
Default 05-27-2013, 12:19 PM
Removed maybe 40 posts. If you guys want to post/share logs, discuss bugs, etc, use the support section. This thread is only for general questions.
enrita's Avatar
enrita enrita is offline
Default 05-27-2013, 02:04 PM
Originally Posted by joselarajan87
i dont even know where to start.. whats the easies way of doing this?
check iso 22 thread
Default 05-28-2013, 09:11 AM
Added ISO_22 to the first post with a few notes. Remember, the new adjustments are OPTIONAL.
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 05-28-2013, 09:27 AM
Great idea, thanks Terry can't wait to try it!
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 05-28-2013, 09:49 AM
Man I just updated to 20D few days ago and now 22 is out. What exactly changed in 22? I am stock only have DCI's. Would I see a huge difference in 22? One thing I noticed in 20D, is when the car shifts gears, they are bit hard.
gliding_soles's Avatar
gliding_soles gliding_soles is offline
Car: 2010 335I X-Drive M-Sport Lemans Blue
Default 05-28-2013, 10:05 AM
Originally Posted by stashtrey
I have an 08 335xi with 6AT steptronic.
Running 20D.
Any advantage for my setup to go to hex 21?
I'm confused on DCT...is this same as 6AT step? I have no paddles....just shifter that goes from D to DS to M. Have alpina flash.
Any help appreciated.
DCT = Double Clutch Transmission. You dont have that..
Too many acronyms here...
GS
2013 335is, Gen 5 ISO, DCI
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-28-2013, 11:18 AM
Out of curiosity what are the throttle position ranges for menu 12 vs. 10 now?
And if I read your notes correctly, 12 is lower throttle position than 10, right?
joseraptor335i joseraptor335i is offline
Default 05-28-2013, 03:05 PM
Hello, I'm new here, I have the update to iso_19, in my car I have not installed the sensor 3.5map
I have to upgrade to iso_22?
thank you very much and greetings
DV135i's Avatar
DV135i DV135i is offline
Default 05-28-2013, 03:31 PM
I have a dumb question....I installed the 2step relay today and was wondering if installing the NLS wiring is needed for it to work properly? When I go WOT the car cuts out 4k like it it hit a wall. When I'm sitting in first gear and rev at a it doesn't cut at the designated rpm.
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR **'s~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
buskeyl's Avatar
buskeyl buskeyl is offline
Car: 201 535i M sport
Default 05-28-2013, 04:10 PM
So i have no clue about two step relay, but just to cover it, you arent possibly on the rev limited map are you?
___________________________
  • 2010 535i M-Sport, Sport Package, Premium Package, Comfort Access, Cold Weather Package, Active Xeon, JB4 PNP, DCI
  • 2004 Volvo S60R
  • 1995 Chevy Tahoe - 230K miles, still plugging away
  • 1987 Mazda MX-6 GT 4WS - RIP
cwarren's Avatar
cwarren cwarren is offline
Car: 08 335
Default 05-28-2013, 04:24 PM
heard of this before cant remember the fix though.
its a setting issue if i remember right .
PTF COBB E50+METH /RR550 TURBOS/ CUSTOM PRE CP/INTAKES / HFS4 / ER FMIC /MF LSD /M3 CONTROL ARMS/ BMS **/STEVE AZ LPFP/POWER FLEX BLACK /SPEC2+/KWV2/
stashtrey's Avatar
stashtrey stashtrey is offline
Car: 2008 BMW 335xi Sedan
Default 05-28-2013, 04:26 PM
Haha. yeah. The DTC vs DCT thing is easy to start a tail spin of confusion. Thanks for clearing that up. I did use the Google as I should have before posting. Cheers!
s142nv s142nv is offline
Default 05-28-2013, 05:11 PM
Updates are always optional.
DV135i's Avatar
Default 05-28-2013, 05:12 PM
nope not on the rev limited map
Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default 05-28-2013, 06:27 PM
So don't take this the wrong way, but am I the only one who's tired of all the shenanigans related to trying to mitigate wastegate rattle with different firmware revisions?! I mean, I have wastegate rattle yes, but I I also have a chattering flywheel and straightpipe exhaust so as retarded as the wastegate rattle is I really don't give a flip about it. I just wan't whatever firmware is going to PERFORM best. Perhaps that focus isn't lost, but I have to imagine that some of these changes to quiet the wastegates are at the expense of other parameters affecting performance so I just hope at some point there's a firmware version released called "ISO wastegates-loud-as-hell" that doesn't pay any attention to the sounds and only to the power delivery, throttle response, and part-throttle smoothness I remember from the G5 integrated days.
2009 135i 6MT Jet Black, FBO+
tofu tofu is offline
Car: 335i e92
Default 05-28-2013, 08:41 PM
it's adjustable... what's the problem?
cb224 cb224 is offline
Default 05-28-2013, 10:04 PM
Haha!! That's too funny!!
///ADMAN ///ADMAN is offline
Car: 2013 BMW 335is
Default 05-28-2013, 11:45 PM
2013 BMW 335is Convertible
piele_bps's Avatar
piele_bps piele_bps is offline
Car: BMW 335i Sedan
Default 05-29-2013, 12:08 AM
What is too funny? The man is right!
2007 E90 335i.
JB4 G4.
FBO+METH.
piele_bps's Avatar
Car: BMW 335i Sedan
Default 05-29-2013, 12:11 AM
+1
2007 E90 335i.
JB4 G4.
FBO+METH.
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 05-29-2013, 08:58 AM
im running 20d, will i see any benefits from upgrading to 22? i have a 6spd m/t
terry, in which flash did u play with the pwm?
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Default 05-29-2013, 09:04 AM
The idea behind making both user adjustable is to give you the flexibility to mask rattle while setting low throttle behavior to your liking.
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 05-29-2013, 10:39 AM
how much are you paying fir the new firmware
Car: 07 e92 M/T
Default 05-29-2013, 10:43 AM
+1
Jnat Jnat is offline
Car: 09 335xi
Default 05-29-2013, 04:29 PM
I love it, one of my favorite saying is "yes, cars do make noise"!
