(#6701)
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 05-22-2013, 11:06 AM
DCT here but i think i need to start playing with settings... Mostly because it's fun to break things
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-23-2013, 11:09 AM
Have you tried resetting adaptations?
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 05-23-2013, 11:14 AM
Originally Posted by ///ADMAN
Yeah, I'm surprised. My car didn't seem to like the 20D at all. Don't know if it was the HEX or the elevation or the E85 or MAP6 or what.
Too many factors. It was like it was surging or missing ever so slightly at lower RPM. That went away once you got on it.
I also didn't like the UserB=5. The car was acting very weird in SPORT-SPORT mode.
I think this is probably better running straight D-AUTO. But, I never drive that on DCT.
Anyone else with 335is comments???
reload the firmware, make sure ur battery is not weak, and restore default settings when asked. that fixed my problems. then play with the settings.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-23-2013, 12:36 PM
Lol
PhilV's Avatar
PhilV PhilV is offline
Car: 335is DCT
Default 05-23-2013, 02:35 PM
I have been running 20D for 3 days now. 2012 335is DCT. FMIC, DCI, CP and 93 gas only. MY car has never ran smoother or stronger! I have future values at 0 for DCT. I find that on just 93 map 6 is the way to go, and when I run 4 gal E85 mix map 5 is the strongest. I really need to get my *** installed soon so I can get dialed in. I did change my map 6 boost targets to what ADMAN posted up and it kicks @@s in my car. I am thinking my next move (once *** are in) is to get the backend flash Terry just developed for the 335is
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 05-23-2013, 02:41 PM
+1 exactly the same symptoms and experience.
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-23-2013, 03:20 PM
What's the benefit of the back end flash on the iS?
My trans is still shifting too hard in DS compared to stock. And i mean in normal driving, not WOT
Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default 05-23-2013, 07:31 PM
Is the userb=5 only for DTV guys? Or can step auto 6speeds use it too?
Default 05-23-2013, 07:59 PM
It's just a feature we tossed in for testing. Steptronic guys can try it too. Once we get some addl feedback/logs of downshifts with it we may make further improvements.
Car: 07 E90 335i
Default 05-23-2013, 09:03 PM
Dtc** stupid phone. I'll try it this weekend and throw some logs for ya
riki18 riki18 is offline
Car: BMW E92 335i
Default 05-24-2013, 04:02 AM
You will love BMS flash for DCT. Believe me, what he did last night is amazing. DCT shifts twice fast than before. You do not even recognize when it changes gears. My logs are like Michelangelo`s drawings
Craig Craig is offline
Car: 2007 335i Coupe
Default 05-24-2013, 10:20 AM
I just upgraded from firmware 18 to ---> 20D. The car is running fine and I immediately noticed that early tip in punch.....reminiscent of the JB4! :-)
No driveability issues at all.
Space Gray, 6MT, Sport and Premium Pkg., JB4 G5 ISO, VRSF 7" FMIC, BMW Performance Exhaust, BMS DCI - OCC - CDV - and Clutch Stop, M3 Spoiler, Clear Bra, 20% Tint
mrwoodwork mrwoodwork is offline
Default G5_iso_21 - 05-24-2013, 10:28 AM
Terry, when did you sneak that one in? What can we expect from this, as I fall into the stock turbo (for now), add +50 group.
2007 BMW e92 335i Sport Package - JB4-G5-ISO - BMS Down ***** - BMS dci - BMS Trunk Meth kit - Cpe Charge Pipe w/ Tial BOV - BMS Cowl Filters - Walbro 450 LPFP - VRSPEED Intercooler - Turbo Back Exhaust - - Billet Wheel RB's w/ Clipped Turbine - 3.5 Bar Sensor - Wavetrac LSD - MHD BMS E85 Flash
Default 05-24-2013, 11:02 AM
Try it out. Only change is with the higher PWM targeting / limiter.
Randomaccess335's Avatar
Randomaccess335 Randomaccess335 is offline
Car: 07 335BAi
Default 05-24-2013, 11:17 AM
I updated to hex 21 from 20D, while on 20D my meth solenoid went bad so I switched to map 7. Today I noticed my meth pump is turning on as if I was on map 3 and I'm 99% sure it wasn't on 20D. I didn't change any settings I only updated firmware. I'm out of the house now and will check my settings when I get home.
Just wondering if anyone has this issue or is meth enacted on all maps now?
R
JB4-G5 ISO w/fsb..
ER charge pipe..
BMS E85 back end flash..
Forged DV's..
5" ETS FMIC..
Gutted Stock DP's..
No sec cats..
Custom MMP inlets...
BMS Trunk Mount Meth Kit SS lines 2 nozzles CM10&7..
Walbro 255 inline The SteveAZ edition
M6 Reps, Custome Tips, Lux Angel Eyes 4..
All Wrapped in a Sparkling Graphite E92.....
ET 11.910@117.29***60' 1.851***
Full weight On 19" street tires..
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 05-24-2013, 11:41 AM
Make sure your Future UseB isn't set to 1
Default 05-24-2013, 01:01 PM
Meth has been flowing on map 7 for months. ISO 10 or 11 maybe?
torres335i torres335i is offline
Default 05-24-2013, 01:05 PM
so using map7 will also add meth beside map3??
Car: 07 335BAi
Default 05-24-2013, 01:28 PM
After Terry's response both have meth but map 3 you can set additive and have fail safe active. Map 7 is set boost and no fail safe.
Or something like that
R
JB4-G5 ISO w/fsb..
ER charge pipe..
Forged DV's..
5" ETS FMIC..
Gutted Stock DP's..
No sec cats..
stashtrey's Avatar
stashtrey stashtrey is offline
Car: 2008 BMW 335xi Sedan
Default 05-24-2013, 04:52 PM
I have an 08 335xi with 6AT steptronic.
Running 20D.
Any advantage for my setup to go to hex 21?
I'm confused on DCT...is this same as 6AT step? I have no paddles....just shifter that goes from D to DS to M. Have alpina flash.
Any help appreciated.
robc1976's Avatar
robc1976 robc1976 is offline
Default 05-25-2013, 11:28 AM
Terry would I have any benefit to ISO 21 or 22 since I have RB'S and not stock turbos? Will this firmware be okay with N20 sensor interface you emailed me with the original ISO 20 test?
Default 05-25-2013, 12:15 PM
RB turbos don't generally rattle much and also operate lower in the PWM range so the latest changes after 20D won't make much difference for you. All firmware is OK with the 3.5bar after whatever number we added it in.
robc1976's Avatar
Default 05-26-2013, 06:22 PM
Default wastegate position governs low throttle behavior so play with that if you want to smooth out low throttle. The BMS flash improves overall fueling when using E85, as well as raises advance set points and trans line pressure for 335is DCT cars. This is all WOT stuff and completely unrelated to the low throttle stuff changed in 19, 20D, 21, 22, etc. It's $725.
flash is well worth it!
ashmostro's Avatar
Car: 2013 335is DCT
Default 05-26-2013, 07:10 PM
Most noticeable benefit from it in your experience?
sfvalley335i sfvalley335i is offline
Car: 335
Default 05-26-2013, 07:36 PM
In my car shifting became easier and smoother 6mt. Can run more e85 without going lean... loverall less issues with e85
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
greensto
