tks535i tks535i is offline
Car: 08 535i 6spd
Default BMS Charge Pipe Install in E60 with Dynamic Drive - 09-20-2019, 04:19 AM
So I got a BMS charge pipe with Tial BOV but the dynamic drive fluid reservoir on my E60 seems to be in the way. Anyone have any suggestion on how I can get this installed? Why is the dynamic drive reservoir so much larger? Can I swap out a standard reservoir? If not my only other option is to relocate it. I could possibly move it over towards the engine on the other side of charge pipe.
Dayton, Ohio
2008 E60 535i 6speed Sport Suspension
JB4, MHD BEF, DCI, D0wnp1pes, 7" VRSF FMIC, CP and BOV, H20/Meth Injection, Stage 2 LPFP, OCC
Car: 2003 Forester
Default 09-23-2019, 04:35 AM
You sure it will work with the smaller reservoir? Chargepipes usually need to be E60 specific. I know my BMS chargepipe wouldn't fit without some major surgery so I sold it and went with Evolution Racewerks.
Car: 08 535i 6spd
Default 09-23-2019, 06:45 AM
After sucking the fluid out of the reservoir I found out there is some sort of valve system in it so swapping the smaller reservoir is out of question. I am currently working on a relocation bracket that mounts the reservoir about 3 inches forward and 1 inch outward. I will post pictures when it is completed!
Dayton, Ohio
Bbelstad's Avatar
Bbelstad Bbelstad is offline
Car: 08 E60 535i
Default 10-02-2019, 06:49 AM
Hi. I'm new the the group and am now curious about the charge pipe install. Was going to order the BMS CP with Tial BOV today however concerned it may not fit an 08 535i. Only 535i E60 specific pipe listed on the BMS CP page is for one using OEM diverter valves. But the one with a tial BV is a dropdown screen option.
Anyone know if it'll fit?
This may be the wrong place in the forum to ask but figured since you've got one too you'd know.
Thanks much!
JB4, BMS DCI and trying to buy more goodies once I know it's the correct size
Car: 08 535i 6spd
Default 10-02-2019, 07:14 AM
Thanks much!
I just got my BMS pipe and tial BOV install finished last night! I had to move the power steering reservoir about 3 inches forward and 2 inches outward. I made a simple bracket with 1/8" steel plate. Still a tight fit but it is working. I attached the cardboard template I made it with for an idea.
Dayton, Ohio
Bbelstad's Avatar
Car: 08 E60 535i
Thumbs up 10-02-2019, 05:37 PM
@ tks535i. Your the man. Knowing this info now, I'll machine a simple aluminum plate tomorrow and order the CP and BOV from Burger tonight.
Before I forget. Hows the Tial BOV and BMS CP working Vs. the OEM DV's and CP? Feel any diff? Did you use the original CP o-ring or does the new combo come with a +1 ring?
As far as the relocate goes, I'll upload finished pics so you can see your handy work spread to the masses! Surprised no one makes a simple plate to move the reservoir knowing it wont fit with it in the way. Oh well. It'll be nice to make my first part for the car instead of buying one. It'll give me breathing room with my wife when I say "I didn't spend a dime, made it myself" lol.
Once I get the CP/BOV on, I need to log some 3rd gear pulls. Everything feels good/borderline great at this point but..... I hear boost bleeding at about 11-12 PSI when accelerating coming out of my diverter valves (I did the $3 diverter mod so I can hear them vent to atmosphere). Everything else I can touch has been tested or replaced so should have a better boost to target ratio once this work is done. I'll post a log before and after to see if I should make tuning changes as I'm new and not sure what adjustments to start with. I'd say I have a general idea but that's how things get worse haha.
Thanks again!!
Car: 08 535i 6spd
Default 10-03-2019, 04:08 AM
I didnt notice a difference but my DVs didnt leak like yours. I went with CP and BOV so I can install WMI.
Couple more things you should know about the relocation. I had to trim the original reservoir bracket, I bent in a support on the strut tower with a hammer, I removed and replaced one hose clamp on the reservoir, and I cut off a portion of the heater core hose support bracket that is located under the charge pipe near the front of car. Also I have installed a FMIC with piping from turbo outlets to CP and I think the BMS CP inlet is a little lower than factory so without the adjustable piping you might have issues getting the hoses to line up.
Dayton, Ohio
Bbelstad's Avatar
Car: 08 E60 535i
Default 10-03-2019, 06:21 AM
Thanks tks535I! Very much appreciated. Hate to have to change the intercooler outlet piping but was planning on upgrading to a more dependable and efficient intercooler anyways so I'll prob do this.
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
Ripper61 Ripper61 is offline
Car: 2010 535i M-sport
Default 10-04-2019, 02:21 PM
+1 for Evolution Raceworks 535i N54 ********
2010 535i M-sport, SAT, BMS DCI & OCC, RB Ones, inlets & PCV, VRSF ****, ER FMIC & CP, Tial Q BOV 1/4" hose, N20 TMAP, PR Stage 2 LPFP, Motiv pro-tuned w/MHD, OE M6 167's, 467hp/477tq w/E30
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-06-2019, 07:58 AM
I also used to run the IER charge pipe with no issues. My reservoir was not in the way, I did move the reservoir forward to hang off just the front most bolt on the original mounting bracket and that was enough room.
