Nanometer Nanometer is online now
Car: 335i, 2009
Default N54 Log Check - 01-18-2018, 12:46 AM
I feel like I have the car pretty close to being dialed in to where I like it. Please see log.
Observations and Concerns:
Fuel system looks very happy overall. Running 91 with 50/50 Meth CM10 Map 5.
Boost overboosts in shifts, might be normal since I am on stiock DV's.
Trims were maxing out a little bit prior to Meth turning on, so I have since upped the FOL a few points.
Is Average ignition okay? Timing drops on a couple cylinders. Maybe car will learn down over time?
Thoughts on surprisingly slow Methanol build?
Why is Boost slow to build too?
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Default 01-18-2018, 11:19 AM
Looks pretty stable but meth scaling is incorrect. Set it to 60.
Car: 335i, 2009
Default 01-18-2018, 11:44 AM
Thanks for the input! Any thoughts on the slow methanol build? I had it at 60 initially, and I was hoping that lowering it would help, obviously didn't make a difference. Do you think there's wiggle room to boost higher? More additive?
BMS Stage 1
Default 01-19-2018, 09:21 AM
You'll need to upload a log with meth scaling set properly.
If it's slow to build, it's usually air or a leak.
You have a couple timing corrections so you'll need to keep an eye on those if you raise boost.
Car: 335i, 2009
Default 01-19-2018, 12:10 PM
Okay thanks for the help. I think I can take it from here. Boost will stay the same. I obviously would benefit from a gallon of E85 to clean that up!
BMS Stage 1
Default 01-20-2018, 07:18 PM
