hkninja's Avatar
hkninja hkninja is offline
Car: 535i 6MT
Default Using MHD to flash BB flash back to stock? - 07-02-2015, 06:50 AM
I'm currently running BB custom flash but I want to change to MHD. Is it necessary to use BB flash back to stock first? or I could just use the MHD to flash over BB flash?
2008 535i 6MT * JB4 G5 ISO * Luke performance flash * E40 * BMS 100% Meth * AR meowless ** * ETS FMIC * BMS OCC * BMS DCI * ER chargepipe * HKS bov * CDV deleted * Ksport coilovers * UUC short shift kit * AC schnitzer rear spolier *
Default 07-02-2015, 07:00 AM
I would like to know also, I just asked on the 34th page of the mhd thread. Very interested.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 07-02-2015, 07:07 AM
You can just flash right over top of the bb flash
hkninja's Avatar
Car: 535i 6MT
Default 07-02-2015, 07:12 AM
Man! That's good to know. When I flash over top of the BB flash by using the MHD, how long will it take for the first time?
Do we loose the ability to flash back to stock at that point? So if we flash back to stock is this going to flash back to day 1 of mhd therefore flash back to BB? Seems like this would be the case, so to get back to stock (hopefully never) we would have to MND back to day 1 then BB back to stock bin? Sounds correct?
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-02-2015, 07:57 AM
If you use the backup ECU it will take your BB as the stock for your ECU/VIN and as long as the file stored in the MHD folder, flashing back to stock will flash back that file, if you use the flash back to stock directly it will flash the OEM appropriate stock flash like stock IJE0S ...etc
Car: 2010 135i 6MT
Default 07-02-2015, 07:59 AM
I forget the initial flash timelines, I think it's like 37min for d-can cars, and 20 or so for k-line. After that it's very fast.
Nope. MHD does not need to backup your stock flash because it can regenerate them with the actual Daten files (same way a BMW dealer would return you to stock). It is a true "return to stock" map.
danzio2020 danzio2020 is offline
Car: E92 335i 6MT
Default 07-02-2015, 01:24 PM
Does anyone know if the flasher module has to be purchased in order to return a vehicle to stock from a BB flash?
Car: 2013 Genesis Coupe
Default 07-02-2015, 08:25 PM
Bump I'm in the process of trying to do this. I have read my stock dme with the bb software and wanting to see if I change the extension to .bin I can go head and flashback to stock using mhd?
lfelunden's Avatar
lfelunden lfelunden is offline
Car: 335i e92
Default 07-03-2015, 02:45 AM
So, you can not read with a tool and write the same file with a different tool, unless you know how to tune, then it's possible to do this. But for a newstarter in that area, read and write with the same tool(MHD flasher etc.)
Default 07-03-2015, 03:13 AM
Unfortunately last time I tried to flash back to stock with BB my dme went into recovery mode. A member on here said that I would just need to change my stock file to .bin to flash back to stock using mhd.
Rushan's Avatar
Car: 335i E92 2009
Default 07-03-2015, 03:51 AM
You can use the MHD to flash back your stock file and the easiest way is only to let MHD flash back the appropriate stock flash, just connect the MHD flasher and select flash back to stock, it will flash your ECU to stock without the need for your stock file if you want completely stock flash.
lfelunden's Avatar
Car: 335i e92
Default 07-03-2015, 04:38 AM
Mail me the file that messed up your DME. Salg@morepower.dk
Default 07-03-2015, 07:38 PM
How does mhd know what your stock file even is? Does it have a preset dme file?
OK I'll email you my file, I don't have inpatient or Winkfp or whatever that program is
lfelunden's Avatar
Car: 335i e92
If you have inpa working and installed I can flash your car back with no issues
Car: E92 335i 6MT
Default 07-03-2015, 05:13 AM
Using Winkfp I am assuming?
boost junkie boost junkie is offline
Car: bmw
Default 07-03-2015, 06:02 AM
MHD desperately needs a FAQ.
Odan.be Odan.be is offline
Car: BMW 335I 2007
Default 07-06-2015, 07:26 AM
Does mhd flasher also have the option to do the "wastegate retrofit" to eliminate the lag that bmw introduced with their "rattlefix" . And revert back to pre 29.2 wastegate behaviour?
Also i have a tuned ecu from a local tuner. So i don't have the oem files anymore , can mhd flash my car back’to oem settings without going to bmw?
dbkaplun dbkaplun is offline
Car: 2007 335xi
Default 08-27-2015, 07:30 PM
I too am interested in this question. Any word on this, MHD?
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 08-27-2015, 11:02 PM
So what happens to the original stock .BIN file?
How are you going to get that back if you're flashing on top of another flash?
I know MHD backs up your original stock .BIN file before flashing as back up
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 08-31-2015, 06:07 AM
The wastegate rattle fix enables you to adjust between the two behavior (open /close at idle and position for low load deceleration).
Without a backup (or with the backup file removed from the MHD folder), we read the factory firmware number from the DME, then deduce the proper, updated firmware and flash that updated software.
