steeve13m steeve13m is offline
Car: 13 M5 DCT
Default F10 M5-How to pass USB extension cable through firewall for JB4 direct OTG connection - 03-13-2018, 08:02 PM
I am trying to pass a USB 10ft extension OTG cable through the firewall to direct connect JB4 unit to an Android phone and bypass the intermittent/unstable JB4 mobile bluetooth module option....
Anyone know how to pass the firewall for a large plug....the USB head is too large to pass in the opening highlighted in pic attached.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Car: 335i, 2009
Default 03-14-2018, 05:02 PM
Does the grommet come out, and allow you to push the cable through the grommet and then through the firewall?
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default 03-14-2018, 05:44 PM
On the DCT vehicles there is a fabric cover that can be torn off, and there is a hole underneath. Here's a photo of our 2015 M5.
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Car: 13 M5 DCT
Default 03-15-2018, 08:52 AM
Nice this worked!
Now when I connect the USB to TYPE C connector Samsung Android phone....JB4 Mobile connects fine but doesnt charge phone....any way to get the OTG connection to also charge phone?
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 03-15-2018, 01:18 PM
That's great for the driver side, but ideally need a pathway on the passenger side as most folks keep the JB4 there and I end up running the wire outside through the door/window.
Would be nice to run it inside and open the glove compartment when needed.
Jon @ BMS's Avatar
Administrator
Default 03-16-2018, 10:36 AM
Not that I am aware of, sorry. Perhaps with a splitter but I'm not sure of that.
I used a generic USB extension for this and ran the wire inside, coiling it in the small net in the passenger footwell, but you could easily run it into the glove box as well if desired.
Default 03-16-2018, 10:49 AM
That's a good approach.. still runs through the hole on the driver side firewall... crosses the engine bay... then crosses again (probably need a good 6-9 feet of cable).
Too bad that orifice in my car is stuffed with multiple meth lines among other things!
Car: 13 M5 DCT
Default 03-16-2018, 12:50 PM
I discovered there are two holes one small at the bottom and one larger one on top on drivers side.....i used the top one
Default 03-16-2018, 05:34 PM
Not worried about the holes... I have enough of them (have made several myself). I just never considered running it from the pass side behind the engine bay heat-shied, into the driver footwell and then back to the pass footwell.
