Help with no boost logs attached -
04-11-2022, 02:56 PM
Sup friends,
I recently wired on my DP fix and removed it. After this I got an issue where I'm getting no boost at all. Exhaust sounds louder as if the wastegates are all the way open. I removed my jb4 completely and flashed the dme back to stock and the issue remained. I wired my jb4 back on and took some logs. There's no sound of the turbos even spooling. Any ideas of what this could be? Could it be DME related?
I attached a log. ECU PSI and Boost values pretty much stay at 0 for the whole run.
I don't think it's a boost leak since Im not even getting any spooling noises and it pretty much happened over night. Chargepipe and intercooler connections are tight.
Getting a 2DED and a 30FF code
Mods: DP, relocated inlets, jb4, wagner IC
