Jluppens Jluppens is offline
Car: 2020 Kia Stinger GT2
Default 2020 GT2 Map1 log - 04-04-2022, 08:01 PM
This is my first attempt at a log with Map1 with my new JB4. Any feedback would be great ly appreciated!
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 04-05-2022, 09:41 AM
Log looks good. The only weird thing I see is that the JB didn't kick in until 63 mph. That's where ECU psi and boost started to separate. Never seen that before.
Default 04-05-2022, 09:50 AM
Interesting. Any theory on why it took the JB4 so long to kick in?
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 04-05-2022, 10:33 AM
Not really except that it's a new install and it might have taken it a second or two to start intercepting the signal and get them to the ECU. Most certainly isolated and I bet it could never be replicated.
Darrin S.
2019 AWD GT2, Sxth ECU/TCU, JB4, Meth, CPI, MBRP, HFC's, Agency intakes, Agency FMIC, HKS Plugs 10.96 @ 124 mph
Default 04-05-2022, 12:34 PM
Looks like its due to warmup protection.
Default 04-05-2022, 07:24 PM
Very possible, car was not warmed up quite as much as it probably should have. I ran another log in similar conditions today.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 04-06-2022, 06:13 AM
Log looks perfectly normal.
You can go Map 2 if you want.
Default 04-06-2022, 05:09 PM
Here are a couple of Map 2 logs from today.
DanielJW DanielJW is offline
Car: 2022 Stinger GT2
Default 04-06-2022, 05:23 PM
The look normal.
Default 04-07-2022, 11:09 AM
Agreed but try to stay WOT when logging.
Default 04-26-2022, 08:38 PM
Just added 5 gallons of E-85 and the rest with 91 octane. I ran another log using Map 3. Wondering how it looks. Thanks!
Default 04-27-2022, 05:22 AM
Not bad, but not great. Your loosing a lot of boost shifting at redline. Shift manually at 5600, bit less in 1st and 2nd. Have you reset your learned timing corrections? Negative off for 10 min, reconnect, don’t log until .8 disappears in ign 2-6. Takes about 15 min of driving around. Put it on your phone app to view live. If you don’t see .8 across 2-6 it did not work correctly.
Default 04-28-2022, 08:47 PM
I pulled the negative for 10 minutes. Now I get 0.8 across ign 2-6 when giving it gas and drops back to zeros on coasting. Shortly thereafter I saw a bunch of 5.3 show up across ign 2-6 and I check the codes shortly thereafter. Got a laundry list of codes but I could not find a single one in any code lookup. Looked like a bunch of jibberish. When I got home, I rescanned the codes and did not give any codes. Not sure what that was about.
Default 04-28-2022, 09:45 PM
That’s normal on the .8 and when driving to see it spike a little with what I call higher torque low rpm is normal. If it’s happening all the time it’s it’s basically saying your fuel is bad. Why you got a bunch of codes is weird. I keep 2 cylinders, one on each side all the time.
