Notasoulstinger Notasoulstinger is offline
Car: 2019 Kia Stinger GT1 AWD
Default Need help please JB4 keeps cutting me out off boost - 03-20-2022, 08:59 PM
So I am new to all this. I believe I am having either fuel mixing issues or over boosting issues because on both map 2 3 and 4 I go into limp mode and thrown back to map 0 once I get I believe at 20 psi. I have logs I just donít know where to upload them, is there a place that I can email them through. It gives me a option to send through email on the app but I donít know the address. sorry if I sound clueless but itís because I am lol. Thanks In advance to whoever see this.
Keister Keister is offline
Car: Kia Stinger GT1
Default 03-21-2022, 05:22 AM
The email function in the app is so logs can be sent to your own address, then if you post them here to the forum they can be evaluated.
Also, the default "mail" app on your phone (I'm speaking iphone specifically) must be setup in order for this function to work in the jb4 app.
Also, also, it helps them evaluate issues if you list everything done to the car. Plugs, gap, intakes, fuel wires, etc, etc.
2018 Stinger GT1. JB4, Intakes, BMS FMIC, Denso@22
Default 03-21-2022, 07:46 AM
Man all that Info really helps, so should I create a new thread then? Or throw it into this one.
DanielJW DanielJW is offline
Car: 2022 Stinger GT2
Default 03-21-2022, 01:10 PM
Throw it in this one. Do you know how to log properly? Safe area, sport mode, 30 mph, shift into 3rd gear manually, wide open throttle, shift at 5600 rpm’s or so, and keep logging until 80 mph or more. Obviously, if you have problems you can post what you have.
Default 03-21-2022, 01:21 PM
How to use JB4 mobile:
Default My Issue :( - 03-21-2022, 07:16 PM
I am in desperate need of some guidance I have a 2019 kia stinger GT1 AWD. Currently rocking K&N intakes with 1 step colder Denso spark plugs gapped to 0.022. I have been running comfortably on map 1 and 2 and even 3 for about a couple of weeks now since I have 93 easily available where I am at. I however started running into problems when I tried to run on map 4 with an E-30 Mix. I know for a fact that I mixed the wrong fuel because I stupidly use a calculator to calculate for the mix but forgot to take in consideration that the pumps are never fully E85. Newbie mistake. The ones by me were reading E-60 and now E-70 (since its warmer). So maybe that can be the reason for my issue. I am experiencing Limp mode in maps 2, 3 and 4. I would launch the car and it would pull but then towards the top end it would just fall flat on its face. But oddly enough I tried it from like a 40 roll and saw no issues. It seems like I may be over boosting because it looks like it happens once I get around 20 psi. I am hopping its just the mix and I might just have to drain the tank and try again but would still like for some one to look at my logs and give me some much needed feedback. Also its saying that my logs are to big to attached them, and i have no idea what the work around is for that.
2019 Kia Stinger GT1 AWD, K&N Intakes, Tork Muffler Delete, Denso Plugs 0.22, and JB4 Tune
Default 03-21-2022, 07:24 PM
Fuel pressure is the issue here. Lower the E85 mix and drop down a map as needed... The best long term fix for this issue is CPI.
Default 03-22-2022, 10:36 AM
Ok sounds great really appreciate the information. Do you have any advice when it comes to mixing E-30? Also, should I even run map 4 at all? I don't want to hurt the car and I don't have any fuel mods, only intake and plugs. Also, I want to confirm that I don't need E30 on the map 3 right? As long as I have 93 I should be fine? Reason why I am asking because I thought If I was running a high ethanol mix on map 2 or 3 that it would adjust itself but I was still going into limp mode, is that normal? Again thank you!
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 03-22-2022, 11:55 AM
Advice for mixing E is don't guess. Get the sensor, or test it at the gas station before you mix it.
Below is the guidance for maps. Stay away from Map 4 with just E, Best bet is Map 2 or 3. You do need race gas or E30 with Map 3.
Map 0: JB4 disabled
Map 1: 4psi over stock peak tapering to 2.5psi at high RPM. Default performance map suitable for all 91+ octane fuels.
Map 2: 5psi over stock tapering to 4psi at high RPM. Suggested for 93+ octane fuel.
Map 3: 6psi stock tapering to 5psi at high RPM. Suggested for high quality fuel including unleaded race gas, ethanol mixtures up to 30%, or high quality octane booster like Torco or Boostane.
Map 4: Up to 7psi over stock. For use with unleaded race fuel and/or E85 mixtures up to 30%.
Map 5: Up to 7psi over stock but without top end taper. For unleaded race fuel use and bolt on modifications. May not be suitable for E85 mixtures due to high fuel pressure dropping. If using this map on E85 you should be experienced at reading your own logs and evaluating ignition advance and fuel pressure.
Default 03-22-2022, 03:27 PM
Log map2 on an E30 mix and lets see how fuel pressure holds up. If it's OK you can try map3.
Default 03-23-2022, 06:56 AM
I will do just that. I'm going to drain the tank completely just to make sure, and hopefully fill up correctly this time, then I'll test and log it on both map 2 and 3 like you said. I appreciate the breakdown of the maps because I wasn't really sure what was needed for each.
Default Update - 03-28-2022, 05:55 PM
So i recently I went testing again, and found the map 2 was running some what normal although i might of felt it breaking up towards the top end not completely sure. But I was running into the same issue with map 3 where It would cut me out of boost entirely. I thought I mixed it perfect this time when it came to creating the E30 mix, even tested it too, so its safe to safe im going to leave that alone and most likely look into weight reduction. Anyways here are a couple of logs from that night, again just want some feedback on how things are looking. Thanks in advance!
Default 03-29-2022, 10:32 AM
Rail pressure crashed on map 3 and kicked you to map 0.
Lower ethanol content, lower boost, or add CPI kit.
Default 04-04-2022, 10:17 AM
figure that was it again. I cant seem to get the mix right which is frustrating so I am just going to stick to Map 2 on 93 for now, but I am highly interested in the CPI kit. Can anyone please walk me through the specifics of what that's really all about. I see they have and add on kit and a full kit. Which one do I need? and also how easy is the install. Again thank you all!
Default 04-04-2022, 10:27 AM
Also do I need to be running any support mods for it as well, like a ********
Default 04-04-2022, 11:48 AM
If you already have a Fuel-IT sensor you only need the CPI add on. It's just a fuel injector that mounts in an 1/8" NPT bung allowing the JB4 to inject more fuel to supplement the weak high pressure pump. You'll be able to run up to 50% E85 with it and max out power on the factory turbos.
Default 04-04-2022, 01:36 PM
Ahh ok. So another question, If I get the fuel it censor does that allow it to automatically adjust for E30 or does it just allow me to read my fueling more accurate?
Car: Evo VIII
Default 04-04-2022, 02:45 PM
Both!
Default 04-04-2022, 04:01 PM
Really then it’s a must. But just to be clear, if I mix the wrong fuel would the tune adjust automatically to what I’m running up until E30 or will it just give me the fuel readings to make the changes myself to either add more 93 or 85
Default 04-06-2022, 09:02 PM
So I’m going to pull the trigger on the censor which should solve all my issues but a side question, can I run map 4 on E-30 with my current setup or is that only for actual race fuel?
Default 04-07-2022, 11:10 AM
Yes but always best to upload a log for verification.
Default 04-16-2022, 12:15 PM
Hey guys, so I have just received my fuel it ethanol censor kit in the mail today. However it did not come with any instructions at all. Just a plastic bag. I was planning on taking it into a shop to get it installed with a set of ********* I bought recently anyways, but just wanted to know if they are needed or is the install pretty streamline, and if not where do I go for that information? And as always thank you!
Car: Evo VIII
Default 04-28-2022, 02:38 PM
Right here brotha! https://www.n54tech.com/instructions...FF_install.pdf
Default Help Please it still happening! - 04-28-2022, 06:49 PM
So I recently installed the flex fuel it kit and attempted to run map 3. I am still getting the same issue where the JB4 cuts off boost and throws me into map 0 even though I know now that i am running a perfect mix of e30. Which leads be to believe something else is causing this. It like the ecu and the JB4 are fighting each other and its annoying because i really want to run map 3 and 4 and I just wont let me. I attached the log within this reply, please take a look and tell me what is wrong please and as always thank you.
StungGolfer82 StungGolfer82 is offline
Car: Ď21 stinger GT
Default New to jb4 - 04-28-2022, 09:27 PM
Running 93oct in map 2. Car has denso plugs/AEM intakes/******* midpipes/factory after. I have no idea what Iím doing but I did a log and things donít seem right. Attaching here. Pls help
