(#826)
Default 08-14-2020, 05:23 PM
Originally Posted by Nez136
Terry i sent you a log a little bit ago.
While Im logging whats a safe IAT to look for at wot? Mine are sky rocketed in the RS.
Pretty sure map 5 is a little much with just 5 gallons of e85.
Send logs to me rather.
The RS weak point is the water to air cooling system. IAT sky rockets. If timing is not looking good you can up the E85 content a gallon at a time to full tank ratio.
2021 VW Golf 8 R
steel234's Avatar
steel234 steel234 is offline
Car: S4 B9
Default 08-15-2020, 03:34 AM
Anyone have good settings for Map6 with upgrade turbo? I drive usually with RON 98 (~AKI 93) + some E. There ist PureTurbos P700 inside
8W5 CWGD ||@BMS
5F CJSA || Full Stock
A/H Z18XER || @EDS
"What we dealing with here is a total lack of respect to the law" (c) TP 1994
1SQ5SoCal 1SQ5SoCal is offline
Car: 2019 Audi SQ5
Default 08-15-2020, 07:25 PM
Have been enjoying my JB4 on my SQ5. Curious, I recently added a catted DP and now am getting the following code:
5C36
I have always gotten 8176, but it only seems to appear on the JB4 app and not my OBDeleven. Anything I should be aware of with the 5C36?
Default 08-15-2020, 09:59 PM
5C36
We dont have a translation for that one. Its DTC 23606 but dont get a hit on it at all.
2021 VW Golf 8 R
scottycs scottycs is offline
Car: 09 335i
Default 08-16-2020, 07:28 PM
Is this the latest firmware?
Stable (JB4_AUDI_SENT_B9_S4_7_T1.hex)
Default 08-16-2020, 08:02 PM
Yes.
2021 VW Golf 8 R
Goeddgr Goeddgr is offline
Car: B9 SQ5
Default 08-22-2020, 06:44 AM
Hoping someone can help!
Tried to install the JB4 on my B9 SQ5 last night. Believe I got all of the sensors hooked up correctly. George confirmed the locations were correct. Did not get the mobile app to connect but went for a quick drive anyway as I believe the JB4 automatically sets Map 1. After getting above 2500-3500 RPM the car threw a driveline malfunction code- contact service. I limped it home and disconnected the JB4 sensors and reconnected the factory settings. Drove car- was fine. Sent George a few emails with pictures- which he did respond to that night. Suggested I leave off the Fuel Sensor and the BCM. Even then I still cannot connect to app and I do not want to go drive again without being able to see the app and make changes to map.
The App seems to “connect” to the JB4, but failed during the handshake(after 20 seconds or so) saying there is a “hardware connection issue”. I have taken the mobile connect piece off the of the JB4, reconnected, restarted phone, unplugged everything from JB4 and reconnected, reset Bluetooth settings- NOTHING will get through JB4 to connect to the app.
At this point I am EXTREMELY frustrated. I don’t know if this thing works at all, and I have no ability to change any settings even if it did. All I know at this point is however it was connected the first go around did not go well and put the car in limp mode- which I was worried about from the beginning.
B9 SQ5- 1,200 miles
iPhone 11Max on latest iOS
OBD temporarily run around door - connected to JB4 properly
Ground connected under nut on driver side fender
What haven’t I tried? What do I do next? I am about ready to pack it up and send it back. Could I have gotten a dud?
M.D. M.D. is offline
Car: Audi RS5
Default 09-02-2020, 07:17 PM
Just installed the JB4 on my '19 RS5 and it's working great. Noticeable difference on Map 3. My car is stock and always has 93 octane but I don't want to push harder without a FMIC.
No CELs or issues but checked codes anyway today and I got "85E3 No Description Found". Any idea what it is or what to do about it? Google didn't help. I cleared it but it came back after next start up.
Default 09-02-2020, 07:58 PM
Drop George@burgertuning.com an email if you need help.
Default 09-02-2020, 08:15 PM
It is a EVAP code. We see them now and then and dont think its tune related. Maybe double check to see if your gas cap is on properly.
85E3 34275 Evap Pressure sensor Implausable signal
2021 VW Golf 8 R
MrSkimo's Avatar
MrSkimo MrSkimo is offline
Car: 2018 Audi S5 B9
Default 09-04-2020, 04:23 PM
George just helped me out with advice on maps at different fuel levels. I am having to mix VP Fuels MS109 as I only have 90 AKI octane available, and no ethanol. I'm set on that.
I am curious though, what process you all follow on changing fuels? I couldn't find any detailed guidelines/suggestions. Not sure if the fuel sensor (for WMI) allows you to leave a little fuel in the tank when switching, and then just drive the extra out of the lines? Will the JB4 safely accommodate that if you are in an aggressive map?
I had previously considered an APR map and I know that they have a really intense Fuel Guide. I don't really want to drain my tank, but I will if I have to. I'm doing some testing right now on 93 with an ABT tune. And I want to try 96, and then run 100 or 103 in a race on Sunday and Monday
APR Fuel Guide Fuel Guide - APR
2018 S5 B9
AWE Intake
JB4
APR Intercooler
RedStar exhaust
Last edited by MrSkimo; 09-04-2020 at 04:23 PM.. Reason: Added link to APR Fuel Guide
steel234's Avatar
Car: S4 B9
Default 09-06-2020, 03:31 PM
I fill up and drive some kilometers with lower map, then I switch to higher map. APR Guide is a little overcarefull. Engines have lambda regulation, knocking regulation, if you dont drive with WOT from a fuel station it would be ok.
JB4 switch to a valet map / Map0 if there is something suspicious. I drive with Pure700 and set my bost a little to high to BIAS etc, so I was returned always to Map 0 immediatelly by shifting at higher Rpms before I found the right configuration.
8W5 CWGD ||@BMS
A/H Z18XER || @EDS
Broobrou Broobrou is offline
Car: Stinger
Default 09-07-2020, 06:06 AM
Hey everyone,
I'm running into some issues updating the firmware. The app tries to update the JB4 over and over until it finally quits do to too many failed attempts.
I've attached screenshots of the firmware version and the pop up that keeps...popping up.
I also can't use the firmware it was shipped with because the update removed it early in the process. Phone's wifi was off and placed inches from the JB4.
Anyone know how to get this running?
Default 09-07-2020, 06:34 AM
Originally Posted by Broobrou
Hey everyone,
Try increasing the timeout value to 30 and see what it does.
2021 VW Golf 8 R
Car: Stinger
Default 09-07-2020, 06:37 AM
I've tried with both 25 and 30 second limits. It still fails multiple times until finally quitting on me.
Default 09-07-2020, 06:43 AM
Double check the phone is not connected to any other bluetooth device like media inside caf, smart watches etc
2021 VW Golf 8 R
Car: Stinger
Default 09-07-2020, 07:46 AM
Okay, this time I let the phone connect to the car then purposefully disconnected them from each other.
I tried again and now it's failing while in the 100s (writing block screen). Earlier it would go through the entire 328 blocks before failing.
I also verified that while it's loading nothin else is connected to the phone.
It failed five attempts again.
Default 09-07-2020, 08:19 AM
Drop me a email george@burgertuning.com. We will need to arrange to change the master chip on the circuit board which is a easy fix.
2021 VW Golf 8 R
Car: Stinger
Default 09-07-2020, 08:23 AM
I actually emailed you earlier today before posting here.
Email address matches my user name here. When you get a chance to read it just let me know what I need to do.
Thanks.
Car: Stinger
Default 09-07-2020, 09:31 AM
I sent you another email, George.
For future reference, are the JB4s shipped with the most recent firmware?
Nez136 Nez136 is offline
Car: Audi S4
Default 09-17-2020, 05:08 PM
Her George, so far everything is running great with map 5 in my RS5.
Every so often the unit sets itself back to map 0. No codes or anything just back to stock. Then I click it to 5 and it’s good for a week or so. Never happened in my S4, I did update to latest firmware when I installed in the RS.
Let me know if you can help.
Default 09-17-2020, 07:39 PM
Every so often the unit sets itself back to map 0. No codes or anything just back to stock. Then I click it to 5 and its good for a week or so. Never happened in my S4, I did update to latest firmware when I installed in the RS.
Hi, check to see what the last safety value is. This will indicate the reason. Relatively easy to sort out thereafter.
2021 VW Golf 8 R
Car: Audi S4
Default 09-18-2020, 05:29 AM
Last safety says 1
Boost saftey says 25
Default 09-18-2020, 05:34 AM
Last safety says 1
You hitting the 25 and its map switching. Set to 27 and it should sort it.
2021 VW Golf 8 R
Car: Audi S4
Default 09-18-2020, 06:23 AM
Roger, thanks buddy
