(#751)
RoB9 RoB9 is offline
Car: Audi S5
Default 04-21-2020, 05:53 PM
Does Map 0 still log or does it totally disable everything?
kanemari kanemari is offline
Car: Audi S4 B9
Default 04-21-2020, 05:54 PM
Originally Posted by Aus1
You manage to work this out? Just installed on SQ. There is a rubber plug just above the brake pedal. Let me know if you need some photos
only just saw your post. I had given up on this, but would be great to see photos as I just had my annual service last week and would like to get rid of the wire in the door well.
Default 04-21-2020, 06:13 PM
It still logs.
2021 VW Golf 8 R
steel234's Avatar
steel234 steel234 is offline
Car: S4 B9
Default 04-27-2020, 11:08 AM
Hi Guys,
A friend of me said it should be possible to drive with jb4 and with *** replacement without fault codes... maybe ist working for bimmer, i didnt saw this Option in a settings.
Or im wrong and there is one "no ***" map?
8W5 CWGD ||@BMS
5F CJSA || Full Stock
A/H Z18XER || @EDS
"What we dealing with here is a total lack of respect to the law" (c) TP 1994
Default 04-27-2020, 07:18 PM
Originally Posted by steel234
Hi Guys,
This is blocked due to legal reasons.
2021 VW Golf 8 R
Cherk947 Cherk947 is offline
Car: 2017 Infiniti Q60 RS 400
Default 04-30-2020, 04:54 PM
Moved from an Infiniti Q60 Red Sport to 2020 SQ5. Got my JB4 today and after an hour install I took it out for its first run. After the engine warmed up, man this thing runs. I thought the car was fast before but it is a huge improvement. Cannot wait to see how much I like it over the next few days.
evilcupcakes evilcupcakes is offline
Car: 2018 Audi rs5
Default 05-02-2020, 03:42 PM
It’s been awhile since I checked in here, I just updated my firmware and wanted to verify that map 3 is fine for 93 octane. Can you run map 4 on 93 octane or do you need a booster?
My car is a 2018 rs5
Default 05-02-2020, 05:01 PM
George @ Burger said map 3 for 93. Just installed it really wakes the car up.
Default 05-02-2020, 06:39 PM
Originally Posted by evilcupcakes
Itís been awhile since I checked in here, I just updated my firmware and wanted to verify that map 3 is fine for 93 octane. Can you run map 4 on 93 octane or do you need a booster?
You good with map 3 on 93.
On RS5 it doesnt seem to manage with 93 due to higher intake temps due to the water charge cooler.
2021 VW Golf 8 R
Car: 2018 Audi rs5
Default 05-03-2020, 06:47 AM
So for map 4 what do you recommend? What brand and or how much is needed to safely use it. Like I said Iím running 93. Also any links to see what gains were made with the JB4 now that itís been out awhile? As a heads up I recently took my car in for service and everything was good.
Default 05-03-2020, 12:20 PM
For map 4 you need to do a mix of E85, around 5 gal and the rest 93 or get the octane up to around 96 or so blending some race fuel.
2021 VW Golf 8 R
Default 05-09-2020, 07:07 PM
I understand that other tuners can permanently turn off the auto start/stop which is super annoying and sometimes dangerous. Is this something the JB4 can be setup to do?
Default 05-09-2020, 08:04 PM
Not a feature we offer currently. Maybe down the road.
Default 05-09-2020, 08:12 PM
Would be a popular one I think. Any future plans in the works @Terry?
NetJunkie NetJunkie is offline
Car: B9 RS5
Default 05-28-2020, 08:13 AM
What are people seeing for a stock B9 RS5 w/ the JB4 using 93 octane? Assume Map 3? What about mixing fuel and running Map 4? Thanks!
Default 05-28-2020, 09:48 PM
I mustve email you a graph.
Couple of performance metric here too. https://www.audizine.com/forum/showt...art-a-database
2021 VW Golf 8 R
B9S4Chris B9S4Chris is offline
Car: b9 s4
Default 06-02-2020, 02:37 PM
Hello,
Getting a test pipe installed , how would i clear CEL im outside of the US.
Also can the b9 s4 run map 4 with 93/94 octane. My friend is running it with nothing else but jb4. I havent seen his logs, but his car pulls more than mine.
Thanks,
chris
Default 06-02-2020, 03:11 PM
Originally Posted by B9S4Chris
Hello,
Thanks,
chris
In the WMI section there is a option for passive delete that needs to be clicked.
I would run logs in map 4 and we can see how things look.
2021 VW Golf 8 R
Car: B9 RS5
Default 06-02-2020, 08:52 PM
Just ordered my JB4 for my RS5. Any tips from others that I might need since there isnít a direct RS5 guide?
Default 06-03-2020, 10:33 AM
Only the one boost sensor is slightly in a different location on the pre throttle charge pipe. Its the one that says multicoloured below.
2021 VW Golf 8 R
Car: B9 RS5
Default 06-10-2020, 11:36 AM
Do people leave their JB4s installed when they go to the dealer for simple things like oil changes or recalls? Want to keep the warranty so rather not have any questions come up but also don't want to uninstall/install every time. About to walk out and put mine on the RS5!
jb4_newb jb4_newb is offline
Car: 2018 S5 Sportback
Default 06-15-2020, 12:01 PM
I ran my car on the drag strip yesterday and on runs 3 and 4 got errors. it didnt show me codes at the time but now the jb4 says i have the code: 8203 No Description Found. anyone have any idea what that is?
Default 06-15-2020, 12:57 PM
Email in the logs and details to George for help. george@burgertuning.com
Default 06-15-2020, 01:31 PM
I did yesterday so waiting to hear back. I also scheduled a dealership appt to get it checked out so I will need to remove the jb4.
question, all i need to do to remove it is clear the codes, set to map 0, turn the car off and lock it then unplug everything? Is there anything else i need to do to it before taking it in?
Default 06-15-2020, 01:35 PM
I wouldnt rush off to the dealer ship just yet. Does the car have any hardware mods?
The DTC is 33283 but I cannot find a translation.
2021 VW Golf 8 R
