(#501)
ga0887 ga0887 is offline
Car: 2016 VW GTI Dsg
Default 08-18-2019, 04:08 PM
The way the traction control works has changed so check to see if the Max boost 1st and 2nd values are set to high. Values now work as the amount of boost that must be cut. ITs a global setting so will affect all maps.
That was it. Cleared out the old values and we're back in business
Thanks for the quick response George!
Default 08-18-2019, 04:50 PM
Happy its sorted.
2021 VW Golf 8 R
chris1210 chris1210 is offline
Car: 2017 Jetta 1.8T Sport
Default 08-19-2019, 03:42 PM
So I'm all up and running - wowwowow, what a difference!! Incredible difference from stock and silky smooth, too.
Quick question on protecting the wiring - other than using zip ties to tidy up the wiring, has anyone used heat protective sleeves to protect some/all of the JB4 wiring?
I live in AZ, so it already gets toasty under there as it is!
Default 08-20-2019, 06:52 AM
Need some help.
Firmware update failed last night stoping the car from cranking.
Decided to remove the jb4 and almost done but I simply cannot get the cars wiring loom repressed from the jb4 plug in ( I got the jb4 plug off the charge pipe just fine).
Anyone have any advice on what or how I release the cars wiring plug from the jb4???
Default 08-20-2019, 08:05 AM
Originally Posted by chris1210
Need some help.
Sent you video with a easy way to remove it.
2021 VW Golf 8 R
pjohn221 pjohn221 is offline
Car: vw
Default 08-21-2019, 05:37 PM
i keep getting CEL misfires (code P0312), it seems I'm getting it every time i switch to Map6. car runs fine tho. and today it threw CEL again with code P0312 and P03015. can't find what P03015 means, any idea what this is?
latest firmware.
MK7.5 GTI
SOLID FARRELL SOLID FARRELL is offline
Car: Mk7.5 GTI Rabbit Edition
Default 08-21-2019, 09:41 PM
New JB4 owner/user here,
Based on the "model specific" mention on your latest firmware Map notes,
Map 3 Peak boost 6psi 93AKI/98Ron recommended
Map 4 Peak boost 6psi (Golf R and Audi S3 7speed DSG specific)
which Maps apply to the following:
2019 GTI Rabbit Edition, DSG
93, Texas heat,
just a K&N panel filter mod wise
(currently Map 2)
From what I understand 1, 2, and 6 are still my Map options based on the latest note specifics.
Confusion aside, amazing product!
Buying another for my wife's car very soon.
Thanks,
Farrell
2019 VW Golf GTI Rabbit Edition (sold) - JB4
2018 Kia Stinger GT RWD - JB4, Intakes, Intercooler, Catback, OCCs, Pedal Controller
quattromaniac quattromaniac is offline
Car: 2018 Audi S3
Default 08-22-2019, 02:55 AM
When can we expect the autotune map?
Default 08-22-2019, 10:54 AM
latest firmware.
MK7.5 GTI
If you using the app update it from this link and lets see what the faults are. The one app version that reads P codes has a issue with faults it shows. https://www.n54tech.com/forums/showthread.php?t=58492
2021 VW Golf 8 R
Default 08-22-2019, 10:55 AM
93, Texas heat,
(currently Map 2)
Thanks,
Farrell
Map 3 will run well on your car even in the Texas heat.
2021 VW Golf 8 R
Default 08-22-2019, 10:56 AM
Its not on the priority list. We will look in to it in the future but the ECU makes so many adjustments as is that over the ready maps there isnt major value in it.
2021 VW Golf 8 R
Car: vw
Default 08-23-2019, 06:31 AM
thanks! i just updated my app on my iphone. right now im running Map 0, we'll see if CEL comes back. thanks!
georgevox16 georgevox16 is offline
Car: 2017 Jetta GLI
Default 08-24-2019, 07:31 AM
Hey George, I was trying to log yesterday and was connected for about 10 mins with the data cable and had full Gauges in the app, but when I returned to the car after running into a store for 15 mins and turned the car back on only the map and boost Gauges are working. The afr, ign, rpm etc. Are all 0 now and it also won't read codes anymore. I updated to the latest firmware and still not working. Any ideas? Thank you.
antsh antsh is offline
Car: B9 A4
Default 08-24-2019, 12:23 PM
Which car is it? I know George says it's rare, but on my A4 I have to set the Future Use D field to 1 or I get the same symptom.
Try setting FUD to 1, turning off the car, and opening the hood for 3 minutes. Close it, and restart the car, see if you get the OBD signal again.
Car: 2017 Jetta GLI
Default 08-24-2019, 01:29 PM
You are my hero! It worked! I can't thank you enough. I must have changed it by accident when I was adjusting map 6. Huge, huge, thank you.
Default 08-24-2019, 01:57 PM
There is a chance that a bug in the firmware is making the value 0 when you update. Need to check that out.
2021 VW Golf 8 R
Car.crash Car.crash is offline
Car: Golf
Default 08-25-2019, 12:39 AM
Golf r 6 speed dsg.
Large intake and air filter
Forge front mount intercooler
Only use 99ron
Iím putting the new software on today.
Should I use map 3 or do I qualify for map 5?
Default 08-25-2019, 03:13 AM
Originally Posted by Car.crash
Golf r 6 speed dsg.
Only use 99ron
Map 3 would be perfect. You can run map 5 too with 99Ron but do some logs to evaluate.
2021 VW Golf 8 R
Car: Golf
Default 08-25-2019, 04:03 AM
Thanks George. Iíll sit on map 3. In too lazy to run logs and mess around.
The plug and play on this is amazing. Fantastic unit.
Zar Zar is offline
Car: Audi s3 2018
Talking 08-29-2019, 10:33 AM
Hi all, nice to join the JB4 funn.
Fist post for me here.
Driving a s3 2018 on map 3 on new firmware, should I go to map 4?
Bolts ons :drop in air filter, hi flow cated down pipe and JB4.
Any tweaks I could add for 1/4 mile, going on track on Monday.
Did 12.64 old firmware map2.
Thanks in advance.
steel234's Avatar
steel234 steel234 is offline
Car: S4 B9
Default 08-29-2019, 10:41 AM
check your fuel, shoot the logs to George and you will see
8W5 CWGD ||@BMS
5F CJSA || Full Stock
A/H Z18XER || @EDS
"What we dealing with here is a total lack of respect to the law" (c) TP 1994
Zar Zar is offline
Car: Audi s3 2018
Default 08-29-2019, 11:14 AM
That was a fast reply
For the log, I just do a 0 - 100km hard pull or standard driving?
Plan on running 94ron.
thanks
Nora2004 Nora2004 is offline
Car: 2017 Seat Leon Cupra 300
Default 08-29-2019, 02:05 PM
Something I've been meaning to ask for a while, when running an absolute map should we set the 6-cyl timing logging to 1? When I used absolute I would never, regardless of gear and load, hit the boot targets set, switched to additive and it hits target 100% of the time?
Just a curiosity thing, although when I've got the meth installed I may switch back to absolute!
Default 08-29-2019, 03:28 PM
thanks
We need to see 3rd gear and 4th it safe to do.
2021 VW Golf 8 R
Setting it to 1 is only needed if you adding more than 9psi over stock. It removes that nanny.
2021 VW Golf 8 R
