(#251)
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 04-08-2015, 06:29 PM
I asked you to explain D in your own words. You refused. So I wrote a few sentences explaining how it works.
Then I asked you to post a log "showing how you use D to reduce the PID output when boost exceeds the sensor range". I quote it because I don't want any of my engineer friends to think that nonsense came from me. You posted a video(???) of some log without relevant data elements, with no narration or explanation. I have no idea what I was supposed to get out of it. Post the log and we can continue the discussion.
I have zero interest in your "secret sauce". I have 40 customers who used to run your tuning I could ask for a BIN if I cared. I don't. It's irrelevant to me or anything BMS offers because we would never tune a car like that.
The log vid I posted did it not show abs 36.2 PSI in the final post shift gear ? Is not the stock TMAP sensor abs limit 36.2 PSI ? Wasnt the boost in the log reduced to abs 35.* PSI so it wouldnt attempt to exceed the TMAP sensor limit to trigger a throttle closure ? Next time ill ask if you want things explained in a kids 3D book. You never requested specific parameter logging. I used what was available that was obvious.
I projected the future error outcome of an "undesirable boost amount" that would exceed the TMAP sensor limit and made the adjustment to the D Factor to counteract the "undesirable error", before it happens, and to prevent the D-Factor from going null if boost exceeded the TMAP sensor.
This was simply illustrated in the before and after logs in the vid. I didnt have to see the error value in the log to know where to counteract it cause I already knew where in the table to adjust to prevent it from happening.
2011 E92 335is w/DCT
2007 E92 335i 6AT
Default 04-08-2015, 08:47 PM
What the hell is a "log video"? POST A LINK TO THE ACTUAL DATALOG. Again, useful parameters: boost, set point, RPM, throttle, duty cycle, and if your logging supports it the P, I, and D factors added in to the duty cycle output.
If your set point is lower than the sensor can read then the PID will still function. Just with less responsiveness as set point approaches the sensor range. So for example if the set point is 20psi and the sensor range is 21psi, then your maximum error will be 1psi whether it's actually 1psi or 20psi.
What is your normal profession outside of or before you were tuning? If you say engineer I'm going to shoot myself in the head.
Darkcyd335xi's Avatar
Darkcyd335xi Darkcyd335xi is offline
Car: e92 n54 xi
Default 04-08-2015, 08:52 PM
lolz
cky751's Avatar
cky751 cky751 is offline
Car: '09 135i
Default 04-08-2015, 09:07 PM
2009 M sport 135i: BMS DCI|jb4 g5iso|N54 Perf 3" DP|Wagner rep. FMIC|RB PCV & cap|ngk|CDV delete|BMS STCS| e40
DV135i's Avatar
DV135i DV135i is online now
Default 04-08-2015, 10:30 PM
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 04-09-2015, 02:31 AM
More flaming in this thread than slipping DCT clutches...
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 04-09-2015, 07:52 AM
this thread derailed rather quickly
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Car: 09 E92 335i
Default 04-09-2015, 08:20 AM
Not sure why is it so difficult for some of the flash turners to post the actual log...
But anyway, these kind of threads are always fun to read
boost junkie boost junkie is offline
Car: bmw
Default 04-09-2015, 08:27 AM
Sometimes I wonder if BuraQ is actually Shiv in disguise.
Default 04-09-2015, 08:32 AM
lol Shiv was often disingenuous and from time to time dishonest but he could throw together a technical argument with the best of them. There is really no resemblance.
sudo4re's Avatar
sudo4re sudo4re is offline
Car: 2011 335is
Default 04-09-2015, 12:43 PM
Meh, this thread reminds me of the TFT inlets thread where almost everyone was bashing Brian May for thinking outside of the box and for trying something new and different from the accepted conventional wisdom of the many so call "experts". Once the inlets were proven to be the next best thing since sliced bread, these once vocal naysayers now are among the first to copy the idea/product and cashed in on the action. I'm sure as more of Wedge's/Buraq's customers get a chance to hit the track this summer and turn in ET's, there probably will be a rush to copy or try their unconventional way of tuning too.
I don't drive fast, I just fly low...
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-09-2015, 01:40 PM
Originally Posted by cebrailbakan
when will mhd be released?-
I will open the currently closed beta next week, so anyone can get the Flasher without invitation.
Originally Posted by 1///M
When will mhd be available for the 1m
I will start working on 1m support next week. So it's a matter of weeks. If someone has a spare 1M to donate maybe that can accelerate things?
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 04-09-2015, 03:02 PM
Hi Terry, I currently run a bb race flash....will I see any benefit from re flashing using the MHD race flash?
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 04-10-2015, 03:19 PM
If it weren't so , MHD wouldn't be created.
Do more with less !
Default 04-10-2015, 03:22 PM
I've been getting that question a lot. The short answer is maybe. If you're an automatic running high boost levels, feeding higher torque to the trans may help shifting. If you're an MT running higher boost levels, having a higher reported load may reduce the bog tendency. There is also some addl tuning flexibility within the software that I think will help with post shift automatic timing in our JB4 back end maps. But that said, compared to BB, it's basically a more convenient way of loading a flash map.
Default 04-10-2015, 10:14 PM
We've found a bug with the MHD JB4 specific option where the maps trigger a false 30FE and 3100 code sometimes around 5800rpm for no reason. Dropped Martial a note and we'll be working on resolving it.
*** Looks to be fixed in latest release.
Car: vw passat
Default 04-11-2015, 04:59 AM
just reviewing some previous logs where i had prior to the mhd specific flash and it seems the timing was higher. with the bb e85 back end flash i used to target 12-13.5 degrees of timing, these new mhd e85 flashes only target around 9. any reason?
darkrom darkrom is offline
Car: 135i N54
Default 04-11-2015, 07:25 AM
Super bummer for another delay, but I'd rather have a delay than issues. Thanks for doing all the testing. Thanks for building MORE maps for us....for free. Just in general...thanks buddy!
Default 04-11-2015, 09:22 AM
You can open the timing map within tuner pro for the details. This is the e85 map.
Default 04-11-2015, 09:24 AM
Martial made a change that may should resolve it. But I'm not sure how to read the software version number within the app so he can chime in on when its been uploaded and ready for testing.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 04-11-2015, 11:03 AM
The MHD app was just updated on my tablet. Time to flash.
Default 04-11-2015, 11:07 AM
He's also going to add a passive version number to the app splash screen to make it easier to identify when updates happen.
Car: 135i N54
Default 04-11-2015, 12:03 PM
If my OEM battery is 1-2 months old, brand new right from the dealer, do I still need to use a charger for the initial install/read? I would just do it, but I'll have to go buy one just for this. If its not needed I wouldn't be using it for anything else, but if I really should have it, even with a new battery...I'll get one to do it right.
Car: bmw
Default 04-11-2015, 12:44 PM
A battery charger is a good tool to have anyway.
Car: vw passat
Default 04-11-2015, 02:08 PM
i wuold never even think about editing or even act like i know anything about that table. just was looking at my logs from january on the bb e85 flash and the timing was 12-13 degrees and looking at the logs today with the mhd e85 flash they were 9-10 degrees. i thought you usually shoot for 12-13. i dont know if more timing means more power.if less means safer? know everyone used to knock wedge for his 15 degree tunes.
again not knocking anything just noticing differences on my logs.
and i must say thanks to Terry for being so helpful and answering probably 100 emails in the last week and sorting through all the problems with me and reviewing and checking the logs i sent him and resolving everything with the new MHD stuff. that means a lot. i hope i was some help to you getting the bugs worked out.
