Black9 Black9 is offline
Car: EcoBoost Mustang
Default EcoBoost Mustang and Turbosmart - 12-23-2019, 08:49 AM
Have a 2015 Mustang with full bolt ons running map 3 with 93 octane, I’m going to run e30 in the spring but in the meantime I’m thinking of adding a Turbosmart Wastegate with a 7 or 10 lb. spring.Do I need to send logs in for a tuning adj. or does the JB4 make its own adjustments with either map3 (93 octane) or the e30 map?
Default 12-23-2019, 04:26 PM
As long as you keep the wastegate to factory spring, then it will be fine. I don't see a reason to do that though. I would just put the e30 and run map 3 or 5
