rharden rharden is offline
Car: Ford Raptor
Default Firmware update order and other questions - 05-06-2019, 06:27 PM
In the Ford 3.5 EB sticky fire are updates, there are three. Do I need to do them all in order or will just loading the latest #3 give me everything in 1&2 as well? I have loaded #3 successfully.
I have a 2018 Raptor with a Roush CAI and the JB4 with the connect kit. I have changed the plugs to the Motorcraft SP542 iridium (cooler) plug to handle the CAI and the tuner. I run only 93 octane gas. When the JB4 is not on, the throttle seems fine, when JB 4 is on Map 1,2 or 3 the throttle seems to fall flat initially and then come in strong, does the same when in sport mode when in throttle, off and back on. Suggestions? Many thanks
Default 05-07-2019, 10:28 AM
Only need to update to the latest file which is this one:
JB4_F150_3.hex
Can you get a log on map 0 and map 1 so we can see whats going on?
Car: Ford Raptor
Default 05-12-2019, 10:01 AM
Hi Payam
I waited to respond as was having truck in for service and some harsh shifting concerns in sport mode. The dealer did a transmission reprogram (TSB 18-2274), and it appears to have made the throttle more responsive and the shifts faster, seems to have corrected the problem of the stumbling that I alluded to in my original. Thanks
Car: Ford Raptor
Default 06-16-2019, 06:06 AM
Decided I will go ahead and send you the logs - Map 0, 1 & 2; however, not sure how to attach the .csv files within a message? I see where they can be emailed. To recap, I have a 2018 raptor with a Roush CAI and the JB4, and run only 93 octane fuel. On map zero obviously the truck runs as one would expect. On map one I seem to get some Drago hesitation and on map to no throttle hesitation but some wastegate rattle on the top end, or I believe it is that. Wanted to send the logs, can you advise how to do that please. Thanks
Default 06-17-2019, 08:34 AM
You can upload them here or email me directly. Payam@burgertuning.com
To upload the CSV file here, click go advance under the post box. You'll see a paperclip icon, and from there you can attach files.
Kutzkev Kutzkev is offline
Car: Mustang Ecoboost
Default 06-27-2020, 01:30 PM
I am new here with 2.3 Mustang Ecoboost. I want to know how to update the firmware.
I do not see specific files for Mustang. Only Ranger and Raptor.
Default 06-27-2020, 06:09 PM
Just checked, the Mustang uses the same firmware as the Raptor and other EcoBoost applications. Load it up and grab a log and we can confirm it's good.
Default 06-27-2020, 07:28 PM
Thank you. I sent the log to Ando via support. I got it updated but I’m having misfires or an O2 sensor issue. I changed plugs and coils already...
Default 06-27-2020, 09:29 PM
You can attach logs here too. Just drop down to map0 if having issues as the first diagnostic step.
