SDbboy SDbboy is offline
Car: 2008 535xi wagon
Default Stubborn tiny leak from this area on N54 motor - 04-17-2020, 01:49 PM
I've replaced the oil pan gasket, oil filter housing, and rear main seal and this leak persists. Has anyone experienced a tiny oil leak in this area?
rcpro88 rcpro88 is offline
Car: 535i
Default 04-17-2020, 08:59 PM
Thats not the oil pan thats leaking. I'm not sure what the part is called but its kind of similar to the upper oil pan on my brothers VW.
RealOEM.com - Online BMW Parts Catalog
There is a diagram that shows the block and the lower piece that bolts to the block, then the oil pan bolts to that piece and maybe to the block as well.
DON'T buy VRSF D.Ps or inlets! FBO, E85 Walbro 450, xHP trans flash
Car: 2010 135i
Default 04-18-2020, 09:04 AM
That would be the bedplate/girdle what ever you wish to call it. The gasket there is injected. It's not something you really want tot try and fix yourself. To do so you need to remove the oil pan and then the bedplate and scrape (or chemical) remove the old gasket and then put it all back together and inject the new gasket (anaerobic).
This is where it's described,
11 21 505 Sealing crankcase lower section (N54, N54T)
2010 135i auto,
2020 mods: Speedtech S366, VTT DBBL, PR Coils, dual 450's, etc
Best stock turbo 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best stock turbo 1/4 mile: 11.480 @ 121.79 1.802 60'
Default 04-19-2020, 05:49 PM
Thanks guys. I will pas this info along to my mechanic.
