(#3176)
Default 05-10-2020, 01:54 PM
Log it and lets see if it works as expected.
We left the format the same as BMW and VAG models when using a similar setting, raw timing in cyl1 (which includes cyl1 learned corrections) since you always need to know what the net advance is, and then degree learned correction under cyl2-6. On low grade fuel you'll see high learned corrections and on high grade fuel low learned corrections. If we coded it up properly.
Bbest6693 Bbest6693 is offline
Car: 2019 Kia Stinger GT2
Default Low Boost - 05-10-2020, 02:40 PM
Hello Terry,
This is my first time with the JB4 hooked up.
I have a lot of good logs from map0 and map1.
Yesterday I experienced a code 061B for the first time. Today I also got one. It turns off the engine but leaves accessory power on.
Today I deleted the code again and tried map 0 then 1 then 2. Seemed somewhat normal. Then on the way back tried map 2 and were at very low boost. Let me know that you think. Thanks!!
Injen intake, denso5346@0.022, VT snorkel, bms fmic, jb4 with ewg and fuel wires connected. 5300 altitude with 91 octane.
Default 05-10-2020, 03:08 PM
Originally Posted by Bbest6693
Hello Terry,
Injen intake, denso5346@0.022, VT snorkel, jb4 with ewg and fuel wires connected. 5300 altitude with 91 octane.
That code is a known issue with the v3.7 JB4 mobile adapter.
Update your app here: Rev 3.7 Connect Kit App Compatibility Updates - N54Tech.com - International Turbo Racing Discussion
Also update the JB4 to v16 firmware, and both of those will take care of it.
Default Its Fun Again! - 05-10-2020, 04:06 PM
You're the man Terry. Thanks!
Both fixes worked. Plenty of boost, none of the codes.
Default 05-10-2020, 05:34 PM
Looks normal to me!
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 05-10-2020, 07:35 PM
So noticed when trying to do a pull Map 4 switched to Map 0. I'm running the latest iOS version and v16 of the firmware. Is there any reason why it would do this? Seems that maps 2 has been fine when doing the same thing.
paul.k.whyde paul.k.whyde is offline
Car: Stinger GT1
Default 05-11-2020, 05:16 AM
Anybody out there having bogus app gauge readings with coolant/trans temp and pedal? Mine randomly jumps from normal op coolant 210-215 up to 21,000 for a few seconds then back to normal readings. Trans does same. Pedal shows 145-165 when I'm probably only pushing around 25-30%. Thanks.
Default 05-11-2020, 07:57 AM
Check last safety in the app to see why it changed to the safety map.
Default 05-11-2020, 07:58 AM
There is an issue with the v3.7 mobile adapters corrupting log data a bit. Will be fixed next app update.
khancerto's Avatar
Default 05-11-2020, 08:03 AM
Ok I'll check that out next time it does it. Currently that area is blank.
khancerto's Avatar
Default 05-11-2020, 08:48 AM
Ok i checked and it showed as Boost over safety. Currently it's set at 24.
Default 05-11-2020, 10:52 AM
For the 4bangers you may need to raise the safety. Capture a log and we can check it out. You may need to go up to 26psi.
khancerto's Avatar
Default 05-11-2020, 08:47 PM
So looking at this one, I guess I hit 26.5. Probably should set it to 27? How high is unsafe high?
Jays_stinger Jays_stinger is offline
Car: Kia Stinger GT
Default 05-12-2020, 08:31 AM
Hi terry.
Quick question...
I updated to the newest firmware v17. I tried to set up the wiper blade to be able to switch maps. I followed the instructions on how to do so. Setting would not save and would tell me to check WMI setting.
I then enabled (WMI Pump PWN) and clicked saved and wiper blade map switch controls worked.
Just wanted to see If its ok to keep (WMI Pump PWN) enabled even if I dowt have WMI.
Thank you.
Default 05-12-2020, 08:49 AM
I'd have to see the screen shot but if you got it saved one way or another then you're fine.
Car: Kia Stinger GT
Default 05-12-2020, 09:09 AM
Thank terry.
I will post a screen shot later on.
I've always had issues like before with FUD settings. I would try to save settings and they just wouldn't save. After a couple firmware updates I was finally able to do so.
Car: Kia Stinger GT
Default 05-12-2020, 09:57 AM
I got a screen shot. Hope you're able to see it.
Default 05-12-2020, 12:33 PM
There is a check on that form to require a few selections so you could also just go back to the defaults of min boost = 10psi or virtual sensor offset = 150 so it satisfies that requirement.
Mangeski Mangeski is offline
Car: 17 2.0T stinger
Default No spark plugs yet - 05-13-2020, 10:13 PM
I bought the jb4 and also the 6 spark plug kit only to just figure out those spark plugs dont fit in my 2.0T. With everything hooked up except my mobile app, will the Jb4 be on still or will I have to unplug it until I get my plugs?
khancerto's Avatar
Default 05-14-2020, 09:12 AM
So is there any information for understanding custom mappings, how to set them up, or if anyone has any custom maps figured out for the 1.6T on the Elantra Sport? Been running Map 4 with no problems but would love to know if there are ways to tweak it to better suit the car specifically.
Default 05-14-2020, 09:23 AM
You'd read/evaluate the logs but for the smaller engines generally speaking our OTS maps seem to be the best fit. It's just a matter of finding the optimal map for your fuel and modifications, which the datalog will help you do.
Default 05-14-2020, 09:24 AM
No just leave the JB4 on map0 until you sort out the plugs.
khancerto's Avatar
Default 05-14-2020, 09:37 AM
So am I safe for running this map based on this log?
Default 05-15-2020, 06:31 AM
Ok. Thank you
Tanktodd Tanktodd is offline
Car: 2018 Kia Stinger
Default 05-15-2020, 08:47 AM
Can someone tell me what page the v15 IAT wire relocation is on. Haven't been able to find it.
