(#4326)
jayhawk91 jayhawk91 is offline
Car: Infiniti Q50
Default Map 5 Logs - 06-24-2019, 05:13 PM
Hello! Went to Map 5 per your recommendations. Does everything look good?
File Type: csv 2019-06-24 16_13_20_Map-5.csv (941 Bytes, 76 views)
05g356mtt 05g356mtt is offline
Car: Red Sport 400
Default 06-24-2019, 05:26 PM
When logging i think itís preferable to do a long pull starting from bottom of third gear to top of third while WOT. Looking at some of the logs, you didnít go full throttle all the way. Not sure if this will affect how they read it, iím sure someone else can chime in
Car: Infiniti Q50
Default 06-25-2019, 04:50 AM
Okay did 2 pulls this morning in 3rd gear up to about 120. Ambient temp was around 70 this morning. Appreciate the help! I'm trying to learn more about this stuff and I feel like there's alot of mixed messages on different forums about what is the best to do with this car lol
Car: q50
Default 06-25-2019, 06:28 AM
I looked at your 2 longer logs. Looks good to me. Consider fuel wires to help with the AFR.
Car: Red Sport 400
Default 06-25-2019, 11:17 AM
Can someone look at these 3 logs?
Map 6 +4.5 Peak
Default Map 1
Default Map 2
Based on these logs, Default Map 2 seems to be the cleanest?
Default 06-25-2019, 05:36 PM
Map 6 +4.5 Peak
Default Map 1
Default Map 2
I like the map2 log better myself too, prefer to see timing rolling up rather than down at peak HP.
Default 06-25-2019, 05:37 PM
Looks fine to me! Any issues?
Car: Red Sport 400
Default 06-25-2019, 06:17 PM
Thanks for taking a look.
Question about reading ign, from my understanding timing is only being pulled if thereís a sharp drop (iirc 3 or more?) during the pull. If the ign values start very low say 1.5-2.0 and gradually increase towards redline, is that still acceptable?
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Default 06-25-2019, 08:08 PM
What we're looking for are drops that are not mapped out, e.g. in response to early knock. You want to see a smooth slope up as RPM increases. If it looks like a downward staircase instead, you know more octane or less boost is needed.
Car: q50
Default 06-26-2019, 06:30 AM
Map 6 +4.5 Peak
Default Map 1
Default Map 2
really short log, but they look ok, even map 6. Tough to tell, you really need a good 3 gear pull to be sure.
Car: Red Sport 400
Default 06-26-2019, 09:37 AM
Ahh gotcha. Reason I asked is because I had one 3rd gear pull where the ign dropped really low to 1 and then gradually went up as rpm went up. Wasn't sure if that was a bad thing or not.
I was under the assumption a long 3rd gear pull was ideal? I'll do a few more logs from 1st-3rd gear and get back to you. Thanks again
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Car: q50
Default 06-26-2019, 09:40 AM
Don't get me wrong, a higher gear pull is good. But a multi-gear pull will really get the heat going and tell you if you octane vs. boost isn't good as Terry said timing will really drop out.
RandyNester RandyNester is offline
Car: 2018 Q60 3.0
Default 06-26-2019, 03:42 PM
I received the heat exchanger and had our lead tech install it (I work at an Infiniti dealership), but having an issue with electronics. Everything installed perfectly, fluids replaced, etc. When I take it out and drive it I'm having throttle issues. I stomp on the gas and reaction from the engine is immediate as always, but after a blip of 100% throttle, it backs itself down to around 30-35% throttle. There is NO power...feels like it's running on 3cyl. I drove the car to lunch before the install and it ran perfectly, now with the heat exchanger in the car feels like half of the motor is gone. Did we miss something in the install? Is there something in the diagnostics and/or setup in the JB4 to account for the new hardware? Please help!!!
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Rev9 Flowmaxx Axle-Back Exhaust
Megan LDP
PRQ50 PRQ50 is offline
Car: Q50
Default 06-26-2019, 04:17 PM
You probably still have air in the HE
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Default 06-26-2019, 04:26 PM
+1 bleed it properly.
Car: 2018 Q60 3.0
Default 06-26-2019, 04:32 PM
Can you PM me a diagram for proper bleeding so nothing is missed? Or email me at RNester@southwestinfiniti.com
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Car: q50
Default 06-26-2019, 04:45 PM
https://www.amazon.com/OEMTOOLS-2444...y&sr=8-2-fkmr2
The Infiniti dealership should be using this tool exclusively.
Default 06-26-2019, 06:38 PM
We posted a video somewhere of us doing it, I think at the end of the head exchanger install video?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-27-2019, 06:31 AM
If you don't want to pay, How to bleed the Infiniti Q50/Q60 Heat Exchanger - YouTube
But Infiniti should be doing a machine bleed as part of the install
12.64 @114mph
0-60 4.46
Car: 2018 Q60 3.0
Default 06-27-2019, 08:00 AM
Got it!
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Car: Red Sport 400
Default 06-27-2019, 06:57 PM
Map 2 1st-3rd Pull
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Speedy164's Avatar
Speedy164 Speedy164 is offline
Car: 2019 Infiniti Q50 sport AWD
Default 06-28-2019, 05:14 AM
Hello Everyone and Terry, I finally did an E30 Blend filled up yesterday and did some pulls thoughts on logs. Wondering if I can turn it up? Going to the track today and I'm up against 3 cars, I am racing my coworkers one with a stock 2013 Audi RS5 which is 450hp, a Audi A7 with upgraded supercharger pulley, intercooler and tune and he will be running E85, and a 1989 Volkswagen GTI which is putting down 423 wheel horsepower. Here are my Map 6 logs with E30 mix. 2019 Q50 Silversport
Psi settings are
1500-2500- 5.0 psi
3000-4000 - 6.0 Psi
4500-5500- 7.0 psi
6000-7000- 5.0 psi
Suggestions sent my a buddy on Q50 page
Car: q50
Default 06-28-2019, 05:38 AM
Map 2 1st-3rd Pull
Traction issues in 2nd? Looks ok.
Psi settings are
1500-2500- 5.0 psi
3000-4000 - 6.0 Psi
4500-5500- 7.0 psi
6000-7000- 5.0 psi
Hope the races go well! Fuel trims flatline in that 1 log and you're leaning out.
Speedy164's Avatar
Default 06-28-2019, 05:59 AM
Hmm idk first time E30 mix and I have the fuel wires enabled, I did 5 gallons E85. The. Filled the tank with 93 octane. Thank you for the info is there anything I can do about that?
Car: q50
Default 06-28-2019, 06:20 AM
Drop your E content lol. Basically the computer can't hit the richer commanded AFR because the fuel system/trims can't keep up. Many of us max out the fuel trims, but we can still hit the target AFR. 1 other member in the meth thread had the same issue, but between his E content and meth, he has more safety cushion of a leaner AFR.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
