AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default Who all would like for the JB4 to be able to log AT fluid temps? - 09-28-2015, 11:14 AM
Just curious.
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 09-28-2015, 11:15 AM
+1. Would be awesome to see data point if possible!
AUbeast86's Avatar
Default 09-28-2015, 12:06 PM
20 views and no comments? If you'd like to have this option, please post your interest in this thread.
Trickcruiser's Avatar
Default 09-28-2015, 12:09 PM
I would love this feature to be added!
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 09-28-2015, 12:14 PM
I'd like it as well
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 09-28-2015, 01:29 PM
It would be nice...and even better if I could gauge it with JB4 Mobile!
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-28-2015, 01:48 PM
+1
AUbeast86's Avatar
Default 09-28-2015, 01:55 PM
Thats exactly what I'm getting at
brokenvert's Avatar
brokenvert brokenvert is offline
Guy with the pet snails
Car: 135i vert
Default 09-28-2015, 01:59 PM
I'd like to see it!
Motorsport Photographer, PM for Pricing on Car Shoots - mattkalish.com
135pats 135pats is offline
Default 09-28-2015, 03:39 PM
Yes, that would be lovely.
We have zero hard data as to how the 6AT functions in a high low, high heat environment. We have no clue what fluid temps. we're seeing, what the delta from ambient looks like, cool down time etc.
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default 09-28-2015, 04:14 PM
Can it even be logged with BT? I would LOVE for this especially after installing my AT cooler....
M-Sport 135i - N54 - FBO - E60 - Mfactory LSD - MHD - JB4 - SPX Tuned
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 09-28-2015, 05:14 PM
Totally love this, for DCT it's a really important data set. Especially for the DCT's pushing with higher power levels, Terry knows the challenges with this already.
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 09-28-2015, 05:35 PM
AT Fluid would be great as would OIL TEMP as us E6X performance-minded N54 owners only have "Fuel" and "MPG" in our cluster under the tach and speedo.
I sometimes sneak into the hidden gauge cluster menu to pull up coolant temp, not the same as oil.
The more data and options the better.
Evan
N54 Powered M5 Wagon:
PR3CI5N335i's Avatar
PR3CI5N335i PR3CI5N335i is offline
Need4Speed
Car: 2010 E90 335i M-sport
Default 09-29-2015, 12:19 AM
Awhile back Terry mentioned that he was thinking of adding this into the JB4 but I don't think any progress has been made since. Maybe if there's enough of us interested he'll start working on it.
dh58 dh58 is offline
Default 09-29-2015, 04:46 AM
Would love it!
AUbeast86's Avatar
Default 09-29-2015, 05:50 AM
I've been monitoring it though INPA and my initial observation is that there is an extreme amount of heat soak from the engine at idle with the trans in neutral alone, much less when the system is under load. However, I'm sure heat is also being generated by the turbine and stator in the torque converter and the AT fluid pump. Here's what I've seen so far...
I removed the stock AT oil cooler (its a heater actually) and installed my own AT cooler design (that I might offer as a kit on my site) using a Setrab core and an Improved Racing 165F tstat. My initial concern was that I would not be able to adequately fill the trans with fluid per the procedure due to not having that heater in the system. Well, it turns out that there is a $hit ton of heat soak from the engine. Within 15 minutes of idling, the trans fluid temp easily hit 45C (fill temp is 30C-40C). Getting heat out of this system is paramount to building margin into the life of your transmission especially at these power levels. 2 runs at No-Fly or any high speed run and you're significantly cutting into the life of your gear box.
All the literature I've read on AT failure consistently states high fluid temps as the #1 cause, particularly with this ZF trans. Also what is very consistent is that the most ideal trans fluid temp is 165F-175F. With the stock AT fluid system being tied to the engine coolant, your AT fluid will never be in that range due to the fact the water tstat is set around 215F-230F, not to mention the amount of heat soak from the engine.
The failure modes go in this order...
1) High fluid temps kill the valve body solenoids (electronics no likey heat)
2) the valvebody cannot hold the pressures required due to the failing solenoids
3) the failed mechatronics cause premature and accelerated friction disc wear leading to catastrophic failure
This is why we need to be able to monitor trans fluid temps. I strongly feel that the majority of the trans failures on this platform are very much tied to extreme fluid temps. Everyone knows that heat robs HP and kills mechanical and electrical systems. Only with adequate monitoring and cooling can we really begin to see where the actual mechanical limitations of this gearbox really are. As of right now, heat is killing us. One could also deduce that this is also happening in the MTs as well since they are surely experiencing the same heat soak from the engine.
As of right now, I'm manually collecting my trans fluid temp data though INPA, which is a HUGE PITA.
Terry, hook us up. You know it can be done.
AUbeast86's Avatar
Default 09-29-2015, 06:34 AM
Yep. That's the intent of this thread.
ajsalida ajsalida is offline
Car: e92 335xi
Default 09-29-2015, 07:14 AM
+1 would love to see this.
jdm5596 jdm5596 is offline
Car: 335xi
Default 09-29-2015, 07:25 AM
of course!!!!
Default 09-29-2015, 09:24 AM
Begood69 has our Vm kit with level 10 torque converter and valvebody. He upgraded and added his own trans cooler with fans. Seems to be helping him a lot. Hes been doing 30 psi runs on his 6466 without issues. So I believe trans fluid heating up is a big deal. Can be a great solution.
sk55 sk55 is offline
Car: 335xi coupe
Default 09-29-2015, 09:29 AM
+1 on monitoring AT temp.
also if we could monitor engine oil pressure that would be great too.
Car: 09 E92 335i
Default 09-29-2015, 09:31 AM
I am curious about this, how high of a temp does the transmission fluid get during a multigear pull?
But I agree, transmission temp would be great for the AT guys...
AUbeast86's Avatar
Default 09-29-2015, 10:14 AM
I'll be logging this data manually as well for now but my assumption, based on how fast engine oil temps climb during high speed pulls, is that the AT fluid is probably in the same range if not higher since there is no real cooling.
The engine oil has its own cooler and the coolant has the radiator. The stock AT heat exchanger is about the size of a softball, behind the radiator/FMIC and is directly tied to the engine coolant, whose tstat is 215F-230F. Based on this, you can only assume that the transmission fluid is experiencing thermal runaway during high speed pulls. This is not good.
Default 09-29-2015, 10:42 AM
Makes sense to add it. We'll have to look in to it.
AUbeast86's Avatar
Default 09-29-2015, 10:47 AM
AWESOME!! Thanks T!!
