kinggor555 kinggor555 is offline
Default Just install inlets - FBO E92 N54 with JB4 what backend flash to choose - 01-25-2017, 03:22 PM
Just install inlets. My car is FBO N54 E92 stock turbo with JB4 and 93 octone. May I ask what backend flash map to run? I was running MHD backend pump map.
Thanks,
N54QC N54QC is offline
Car: 07 BMW 335i
Default 01-25-2017, 03:31 PM
Thanks,
Unless you get meth or mix in E85, stay with the pump flash.
Default 01-25-2017, 05:00 PM
Same. Inlets will reduce the PWM required to hit a given boost target and allow the JB4 to target more aggressively up top. But the BEF is independent of both.
Motolawyer's Avatar
Motolawyer Motolawyer is offline
Car: 2008 335i
Default 01-25-2017, 05:27 PM
I am curious about this topic as well, does he have to make any modification to the JB4 (assuming he is using one with mhd) if he is running map 1 or 2 to be optimal?
2007 e92 335i - fbo (mostly)
Car: 07 BMW 335i
Default 01-25-2017, 05:42 PM
If only running maps 1 or 2, more than likely no changes will be needed. If getting into different fuels or having upgraded turbos, that's when other maps will be used and changes will more than likely be needed.
T-Mack T-Mack is offline
Default 02-15-2017, 04:19 PM
Hello everyone. I will soon install IC VRSF 7 ", inlets, outlets and Fuel-it stage1 together with the *** and DCI that I already have. What pressure can I ask for map 6 with 93 Oct and with e40? Will I need T-map 3.5? Do I need really Fuel-it stage1?
Thank you.
byebyev8 byebyev8 is offline
Car: 2007 335i coupe
Default 02-15-2017, 10:30 PM
Fuel it stage 2 and 4bar tmap would be a must if you ask me if u wanna be around the 500whp range.
Default 02-15-2017, 11:41 PM
I will keep the stock turbos and I would get 20 psi across the middle zone. It is necessary 3.5 bar Tmap and fuel-it stage1 or I have enough with both stock?
