(#76)
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 04-05-2012, 03:48 PM
None have shipped yet. Still waiting parts delivery actually...
prelude2perfect's Avatar
Car: '07 335i
Default 04-06-2012, 07:46 AM
Alright, maybe it's because I haven't had my morning coffee or that I'm just not real educated on the PCV system on this car but I'm a little unclear. I know you said it should be a simple DIY but, you also said it's an Internal pcv valve. Will this require removing the vavle cover or no?
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Stalker
Car: 335I
Default 04-06-2012, 11:37 AM
Valve cover will not need to come off, this will be about a 20 minute job.
stpijb stpijb is offline
Default 04-06-2012, 12:43 PM
Very nice wasnt looking forward to removing the valve cover for this.
Stalker
Car: 335I
Default 04-07-2012, 08:35 AM
I got half of the parts in. I should have the rest available and these going out mid next week.
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Default 04-07-2012, 09:02 AM
Great news Rob
ultimateracing 335 ultimateracing 335 is offline
ultimate racing 335
Car: 335i sedan
Default 04-07-2012, 09:57 PM
Hey Rob can you send me one with Dzennos?
BostonBeemah's Avatar
Car: AW 135i
Default 04-08-2012, 12:19 PM
I may be way off by saying this but I recall VWs that modify the PVC with a block off plate to completely "delete" system. Could this be an option for the n54 so we wouldn't have rediculous carbon buildup on our valves?
RIP 2008 AW/BL 135i
Stalker
Car: 335I
Default 04-09-2012, 10:31 AM
Sure thing.
Stalker
Car: 335I
Default 04-09-2012, 10:32 AM
I'd prefer to run some PCV system personally but that is up to you good luck if you try it.
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 04-09-2012, 11:21 AM
Then you miss the whole point of relieving crank-case pressure.
Car: '07 335i
Default 04-09-2012, 01:50 PM
I assume when they did that they also did a vent to atmosphere OCC?
Best 1/4 ET: 11.4
Default 04-09-2012, 01:57 PM
My question is why cant you close the PCV that runs to the intake manifold off and keep the one that connects to the OCC and then connects to the intake open so everything is drawn through the OCC. The intake should keep enough suction to keep the pressure out of the crank case.
okie335is okie335is is offline
Car: 2012 335is DCT
Default 04-09-2012, 06:48 PM
Just picked up a 2012 335is, saw the threads on cleaning intake valves/ports, looks like Rob is on the right track. Subscribed!
Default 04-09-2012, 08:03 PM
Originally Posted by dzenno
pcv is an important system on a car and disabling it messes with many things discussed in the pcv thread (search)...you really want to improve it not get rid of it
Dzenno but closing the part that runs to the manifold and making the secondary part that runs to the OCC open at all times wouldnt this still do what the PCV is meant to do and vent the pressure out of the crank case. Just instead of it going to the manifold it would go to the OCC due to the intake systems suction.
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Car: E92 335i
Default 04-11-2012, 11:47 AM
You could do this and then weld a venturi bung onto the ********* and route the PCV down to the there so you are always scavenging. Might clog the cats eventually though.
stilov stilov is offline
Car: 07 335
Default 04-13-2012, 04:22 PM
Any update here? Patiently waiting
Stalker
Car: 335I
Default 04-13-2012, 08:43 PM
Got 5 of them ready, hopefully will get them out in the morning.
Car: 07 335
Default 04-15-2012, 09:51 AM
Hey Rob, I have the exact problem TWNEGO has...ocasionally puffing smoke on decel when coming to a stop, sometimes not at all.
I know "everyone" is quick to blame turbo seals, however I think there is more to it than that.
I am hoping it is more of a PCV issue has my turbos boost very well.
Anyway I can get in on the testing? In fact, I'd pay you for the parts to test as well.
(the smoke is a bit embarrassing at times )
Car: 335i 2007
Default 04-15-2012, 11:15 AM
I don't believe is the turbo seals either. Mine started puffing white smoke on decels after I installed the ******* ***. It smokes only occasionally, but when it smokes, it puffs big clouds of white smoke, for example when decelerating to stop at a red light . I agree with you that it is embarrassing. My car quit smoking for a while after I changed the spark plugs a couple of weeks ago, then last week I was bored and changed to map 8 (non-turbo map) and when I changed back to map 3 (the map I normally use) the car started smoking again for a day or two. I don't see the relation of the white smoke with changing maps, however I just wanna to share my experience. I hope this upgraded PCV, that Rob is developing help to solve this
Stalker
Car: 335I
Default 04-16-2012, 04:07 PM
Ive got them ready and packaged, still haven't been able to mail them out though. Hopefully tomorrow, that way about half of you should have them by the weekend.
m1bjr m1bjr is offline
Car: 335i E92
Default UK tester - 04-16-2012, 04:34 PM
Hello Rob,
topical for me.
I pulled my MAP sensor last w/e and noticed a LOT of oil in the manifold and the sensor was gunked.
My first thought was PCV - and here I am after a bit of searching
Can you sell me this mod, I can PayPal and I'll take a chance on it working or not.
Of course I will clean everything and report back - Im a keen spanner monkey.
I dont get through much oil, but whats coming from the breather indicates I have a recent fault here.
Steve UK
Mattgfx's Avatar
Mattgfx Mattgfx is offline
Default 04-16-2012, 07:45 PM
Cant wait to hear how the testing goes on these. Right after a cold start coming to a stop sign ill get a puff of smoke out my exhaust and it smells like oil. I have a BMS OCC and my car only has 28k miles on it. I wouldn't doubt that it might be what you're talking about in this thread. I really hope its something as simple as this.
08 135i | Alpine White | 6 Speed | M Sports pkg |
| Berger Intake | Code 3 intercooler | Riss 3inch *** | Berk Exhaust | Quaife LSD |
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 04-16-2012, 09:08 PM
Does it look any different?
Stalker
Car: 335I
Default 04-17-2012, 06:00 AM
PM replied. Yes I will begin selling them if anyone is interested. I have about 10-12 complimentary units going out for testers so I should be good there but if anyone wants to jump ahead and make the purchase without all data and feedback possibly available that is fine by me as well. I really think there will be no disappointments either way, this obviously is a much more sound unit.
Originally Posted by m1bjr
Hello Rob,
topical for me.
Steve UK
