(#2601)
Default 09-11-2019, 01:53 PM
Originally Posted by Metalmania82
Terry, and/or anyone else that can chime in with some knowledge, I've been experiencing some surging at higher RPM's and harder throttle input, as if I were getting on and off the gas repeatedly and quickly. This occurs on Map 1, 2 and 3 and is even more noticeable in Sport mode. I have a couple logs here in regular mode, maps 1 and 2.
I don't see any obvious issues but go ahead and update to the latest v10 firmware so we can rule out the older firmware.
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 09-11-2019, 02:37 PM
Map 1 - 91 Octane
According to the graph, boost was fluctuating a bit.
Also, what should we look for on Trims?
Marcoracing1 Marcoracing1 is offline
Car: Genesis G70 3.3t Sport AWD
Default 09-11-2019, 02:51 PM
Log looks good but it's older firmware so only has timing on 1cyl, not all 6. Update to v10 and relog!
Warm temperature 80 degrees today here is my new log Terry...
Thanks.
Default 09-11-2019, 03:26 PM
Originally Posted by P4RTYH4RTY
Map 1 - 91 Octane
Log looks fairly normal to me. There isn't any adjustment I can suggest for it.
Fuel trims should be level and and drop as fuel enrichment increases.
Default 09-11-2019, 03:27 PM
Thanks.
Looks good to me.
Default 09-11-2019, 03:44 PM
Looks good to me.
Thanks... Will test map3 time results at the 1/4 mile track this week-end
rakker rakker is offline
Default 09-11-2019, 03:48 PM
Could it be wastegate flutter that you're experiencing?
Default 09-12-2019, 05:26 AM
Originally Posted by stock_stinger
settings / user adjustment then scroll down past the blue "flat boost" button, its 9 lines down. it wont show any #'s unless connected to jb4
Do these settings only apply to map 6 or all maps?
Metalmania82 Metalmania82 is offline
Car: Stinger GT
Default 09-12-2019, 05:31 AM
I have no idea as far as that's concerned. My knowledge of how turbos work and how the JB4 or any other sort of tune works is limited.
rboettcher81's Avatar
rboettcher81 rboettcher81 is offline
Default 09-12-2019, 07:56 AM
Did a few passes earlier this week. Car feels great. Launch control with the diff bracket on Map 2, even with all that torque still rips with very little wheel spin (RWD Stinger here).
I'm not sure what the ignition timing is supposed to be @ WOT but everything else seems ok I think?
Default 09-12-2019, 08:09 AM
I think it's a 'global setting'. As for the Map 6 details, they are exactly that, just for Map 6. I think they just lumped all the user adjustable stuff in one location in the app for convenience.
Default 09-16-2019, 12:01 PM
Originally Posted by Jays_stinger
Here is a datalog at idle then a small short distance drive.
Everything look ok?
Thanks Terry.
Unless you are trying to diagnose some specific issue any non-WOT log isn't going to be useful for providing you tuning advice.
Good Morning Terry,
Would you be able to tell if a spark plug is bad from a data log(Parked while iding)? I seem to feel and see the motor vibrating. Doesn't seem right to me..
No we won't be able to. Poor idle is usually a vacuum leak. If a plug was bad you'd get misfire codes.
Default 09-16-2019, 12:02 PM
Looks normal to me.
Default Map#5 - 09-17-2019, 06:14 PM
I Terry,
Do you think I can try map # 5 if I use 94 octane gas + boostane to increase octane up to 105...there is no ethanol 85 in canada?
can I damage something or the system is going to to protect himself???
Default 09-17-2019, 06:29 PM
Yes that should be ok. Not likely to damage anything but when it comes to tuning more boost more risk all else being equal.
Default 09-17-2019, 06:43 PM
it's only for one or two 1/4 mile races ... I made a bet with a friend and he does not believe that a Genesis G70 can roll down 12 seconds and I miss him almost nothing with a time of 12.04 in map # 3 ... after having my little piece of paper I return to map # 2 which is very satisfactory!
Default 09-18-2019, 05:29 AM
Looks normal to me.
Thanks Terry.
Default 09-18-2019, 10:58 AM
Stinger-Performance Stinger-Performance is offline
Car: Kia Stinger
Default 09-19-2019, 01:08 AM
I just got my JB4 with fuel wires installed on my AWD GT, only mods are a DIY CAI and Denso plugs at .022 gap. I'm limited to 91 octane fuel.
Same section of road and IAT was 96 deg and 75 deg ambient at the start of each pull to try to minimize variables.
I need to figure out how to view these logs in graphical form on my laptop but haven't researched it yet.
Attached are two logs, Map 0 and Map 1 0-100 mph with launch control. It didn't feel like as big of a gain as I was expecting after reading everyone's reviews so I'm hoping you can look over the logs and see if everything looks correct.
What I'm curious about is:
-Is it required to engine off/engine on after changing maps to get the change to "take"?
-Whether 10-12 psi is normal for stock/map 0?
-Whether it looks like I'm getting the right amount of added boost with map 1? Seems a little low to me (13-13.5 psi average?).
Whether it looks like I can try map 2? To me it doesn't look like it's detecting knock currently but I could be wrong.
Thanks for your time.
MurlinatoR's Avatar
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 09-20-2019, 10:40 AM
-No. You can change maps while driving.
-Yes. Factory tuning is limited to 12psi peak.
-Yes. I believe each map adds approximately 2 psi.
-Yes. 91 octane is fine for map 2 and could work for 3 possibly.
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
Car: Kia Stinger
Default 09-20-2019, 10:47 AM
Thanks. Mine doesn't seem to take the map change until a power cycle. I put it in valet mode to verify and it stayed there until I turned it off and back on. Searched around and found no mention of needing to do this, hence the question.
Hoping Terry will look at my logs.
Adamdan Adamdan is offline
Car: Stinger
Default 09-20-2019, 11:02 AM
I would wait for terry to give the ok for your map 1 then try out map 2 on 91. I would never even try to run map 3 on 91 without a good octane booster or adding e85.
Default 09-20-2019, 12:21 PM
Map1 looks ok. You can log map2 for comparison.
Car: Kia Stinger
Default 09-21-2019, 12:18 AM
Is there a way to log time in seconds with the ECU's real-time clock so datalogs can be used to precisely extract 0-60 or 0-100 times?
Here are two 0-100 pulls on map 2 with 91 octane, let me know what you see. Thanks.
