JBoe JBoe is offline
Car: M240i
Default 01-17-2020, 07:04 PM
Conanpr… here's some screenshots of my settings. Please take note that I'm using M1 (100%Meth) and have a BEF (Back End Flash) installed. Not all setups are the same, so ensure you use these for guidance only. Start a separate thread in the support section for one on one assistance from Terry/BMS.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (2Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 45... 19-20psi)
Conanpr Conanpr is offline
Car: BMW 340I
Default 01-18-2020, 11:33 AM
Thank you. Will do.
Dominic 88's Avatar
Dominic 88 Dominic 88 is offline
Car: Bmw F30
Default 01-19-2020, 10:49 AM
What is 6 cyl logging value 70 stand for?
Thank you
Car: M240i
Default 01-19-2020, 06:55 PM
Thank you
It's a spoof for IAT (Inlet Air Temp) and forces it to go lower during full throttle pulls. It's a sliding scale and makes up for our cars IAT sensor location. Our IAT sensor prior to the TB (Throttle Body) so it doesn't see the cooling effect of WMI (Water Methanol Injection) or, in my case, M1 (Pure Methanol) injection.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Dominic 88's Avatar
Car: Bmw F30
Default 01-19-2020, 08:14 PM
Oh great. This is what l am looking for.
Just a quick question do l have to set FUD bit2 spoof IAT or just enter 70 on 6 cyl?
I am running quite same mods with you.
Millions thanks sir.
Car: M240i
Default 01-19-2020, 10:03 PM
Nope... That's something different. Even if your setup is close to mine, you should start your own thread and post your logs. BMS will guide you on the tuning. Copying my settings may not be advised after they review your logs.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
B58_M240 B58_M240 is offline
Car: M240i
Default Is Bias 100 Meth 100?? - 02-08-2020, 09:10 PM
JBoe,
I'm PWM for meth control as well, and I've noticed that meth flow doesn't get above 60 at WOT, even though I have Bias set to 100. I clearly see the ramp up and I've logged partial throttle at set min PSI and I see that flow doesn't match Bias setting at any point. I see 100 flow with PWM off, so I'm sure logs have shown 100. Do you happen to know if logged 60 is full flow when using PWM with bias at 100? Or perhaps, signal scaling should be set to 100 for fuel bias to set flow to 'true' 100? Or, lastly, is it possible to set bias over 100?
Side note, tuning meth has improved timing a lot, for me. I think you mentioned this as well. Seems I'm looking for a sweet spot at this point.
Car: M240i
Default 02-08-2020, 10:27 PM
I generally log on a y-scale of 50. I adjusted to 100 and reviewed, but both show my Meth adjusting properly to 100% as set. To see what's really happening you should look at the csv file in excel. It should be showing accurately there.
I'm on V15 firmware. If you're on older firmware, I'd recommend upgrading and relogging to see if that corrects the readings. If it doesn't, then email Terry directly and he'll assist.
Feel free to post your log here and I can review as well...
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Car: M240i
Thumbs up 02-09-2020, 07:07 PM
Very good point, thanks a million. I didn't think about the scaling and I'll definitely check that.
Car: M240i
Default Not the scale - 02-10-2020, 12:19 PM
Just checked xls file and meth flow isn't 100. I'm really curious as to how this is expected to work. I'm sure BMS knows. See attached log.
Dominic 88's Avatar
Car: Bmw F30
Default 02-10-2020, 03:17 PM
Update firmware first brother. Then get some log again.
Car: M240i
Default 02-10-2020, 08:31 PM
Did a run tonight with Meth Scale set to 70 and flow went up to 70.
I'm not interested in FW update, at this point, I just want to know what settings do. I'm not wanting meth to flow at 100 either. With trims below 25, timing seems to suffer. This is why I want a more precise control of meth flow. I'm not fond of flipping switches to see what happens, but sometimes it goes that way, I guess.
Car: M240i
Default 02-12-2020, 07:11 PM
Meth Scale has to be set to 60. That doesn't change and could make things malfunction. If you don't want to upgrade firmware then you'll probably be stuck with the issue. Email Terry directly... I had issues until I upgraded to V15.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Car: M240i
Default 02-12-2020, 07:55 PM
I put it back, but it is completely mind boggling how we have a setting that is adjustable, but shouldn't be touched. Drives me crazy!!!
I'm happy where it is, but now that I know v15 'fixes' the issue, I'll be prepared for it to break what I want.
Car: M240i
Default 02-12-2020, 10:32 PM
Some settings are adjusted on different applications. Our application requires them to be set a certain way to work. It is what it is... Lol.
Definitely contact Terry as your setup isn't where it should be for proper PWM adjustment. At least it's not appearing to be. Either way, Terry will get you set right within a few emails.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Car: M240i
Default 02-13-2020, 08:31 AM
Thanks for the input. I may load up v15 this weekend. Did you have a chance to look at the log I posted?
Car: M240i
Default 02-13-2020, 02:04 PM
I did, but only towards PWM. It's not showing properly, but that's not to say that it's not working properly. When I was on V14 it looked similar, but was working. Especially in the low end, where I was excessively rich. V15 didn't change that, but did graph properly. Terry helped with a custom BEF change that corrected my tip in fueling. All has been right ever since.
Check out my E85 thread. Those logs will show me on V15 with the same BEF Terry provided and using PWM. Of course it's with E20ish fuel, but that's affecting timing more than anything.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Default 02-13-2020, 03:50 PM
Just post a current log here if you want me to check it out.
Car: M240i
Default 02-13-2020, 10:41 PM
It's in post #35 above.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Car: M240i
Default 02-14-2020, 09:08 AM
Thanks for the reply!!
I loaded v15 this morning, but rain came in early. I'll try to get a good log when things dry out.
Default 02-19-2020, 10:59 AM
BTW I'm not always on the forums so if you need more direct help and I'm not around you can always email in to support.
Car: M240i
Default 03-02-2020, 11:43 AM
Just wanted to post a follow-up. I'm experiencing severe over-boost since loading v15. I'm thinking of going back to v14. I can't get a log good enough to make adjustments. The only settings I have changed were Fuel Bias for WMI. I'd like to hear any ideas that might make v15 work the same as v14 (my log is in this thread). To recap, this started with WMI value of 100 not being 100.
Gonna get this!!!!
Car: M240i
Default 03-02-2020, 10:20 PM
Gonna get this!!!!
We understand what you're saying, but need logs to truly evaluate. Best thing you can do in this situation is to email Terry directly. He's more active on emails, but he'll still need a log.
Until you're provided guidance, drive in a boring manner staying under 1/2 throttle. Then you're on the stock mapping and all should be well. It won't be long to get dialed in, but patience and restraint are your friends during this period. Lol... Those are hard for us all, but worth it in the end.
AFE Drop-in Filter
Muffler Delete
CA 91 Piss Gas...
E85 (2Gal/Fill)
BEF (Race_WMI)
Default 03-03-2020, 04:22 PM
Gonna get this!!!!
You should know the drill by now. Want help, add a JB4 log to your post!
Car: M240i
Default 03-04-2020, 03:42 PM
Yes, of course. Trying to get something useful without breaking...
