(#601)
emiliof emiliof is offline
Car: Mini F56 Cooper S
Default 07-18-2019, 03:47 PM
Sure thing:
MAP 2
psi_curve[0] = 30 '1500
psi_curve[1] = 35 '2000
psi_curve[2] = 40 '2500
psi_curve[3] = 45 '3000
psi_curve[4] = 50 '3500
psi_curve[5] = 60 '4000
psi_curve[6] = 60 '4500
psi_curve[7] = 60 '5000
psi_curve[8] = 55 '5500
psi_curve[9] = 50 '6000
psi_curve[10] = 40 '6500
psi_curve[11] = 35 '7000
MAP 1
psi_curve[0] = 20 '1500
psi_curve[1] = 20 '2000
psi_curve[2] = 25 '2500
psi_curve[3] = 35 '3000
psi_curve[4] = 40 '3500
psi_curve[5] = 40 '4000
psi_curve[6] = 40 '4500
psi_curve[7] = 40 '5000
psi_curve[8] = 40 '5500
psi_curve[9] = 40 '6000
So Terry if I want to create a gentle map at low rpm and then adding more boost at the top end, like an hybrid version between map 1 and 2, I could make something like this, right? Of course the values are just an idea to show the concept.
psi_curve[0] = 15 '1500
psi_curve[1] = 15 '2000
psi_curve[2] = 15 '2500
psi_curve[3] = 20 '3000
psi_curve[4] = 25 '3500
psi_curve[5] = 30 '4000
psi_curve[7] = 50 '5000
psi_curve[8] = 50 '5500
psi_curve[10] = 45 '6500
Assuming that:
1. these values represent additive values for boost based on a decimal psi scale
2. If 1500 is below 10, then they will be additive values, and if 1500 is over 10 they will be absolute values
So in order to achieve an additive +5psi map with low torque, I do need to write these values under 'Map 6 Boost' like
1500= 1.5
2000= 1.5
2500 = 1.5
3000 = 2.0
3500 = 2.5
4000 = 3.0
4500 = 4.0
5000 = 5.0
5500 = 5.0
6000 = 5.0
6500 = 4.5
7000 = 3.5
Is is correct?
Default 07-24-2019, 10:24 AM
You could try that but the key is always to log and evaluate to ensure it's doing what you expect.
Those values represent additive values.
echacon echacon is offline
Car: Cooper S F56
Default 07-25-2019, 12:05 PM
JB4 is compatible with 7-speed DCT mini's?
Car: B46 F56S
Default 07-25-2019, 11:22 PM
BootMod3 released support for B48. Will we be seeing a BEF one day?
Default 07-28-2019, 09:40 AM
Waiting for MHD to release it but I'm sure it won't be too long now!
Car: Cooper S F56
Default 07-29-2019, 04:45 AM
JB4 is compatible with 7-speed DCT mini's 2018/2019?
Car: B46 F56S
Default 07-29-2019, 04:56 AM
Awesome. I quite like the way you programmed this file to switch to Map 8 and switch back automatically. You don’t need to make any adjustments to that.
Is it possible, when you get some time, to help out with the code read?
Code read not working is super annoying. Having to switch dongles, open Carly, and that is very time consuming compared to JB4 app.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 08-02-2019, 12:28 PM
Originally Posted by johntotah94
Awesome. I quite like the way you programmed this file to switch to Map 8 and switch back automatically. You donít need to make any adjustments to that.
Seems I canít determine if meth is flowing or not; John does that work for you and btw code read does work when you have an error and deletes. When you check next time it gives you an invalid read as message on hex6.
Augustor Augustor is offline
Car: Mini Cooper S F56
Default Firmware Version - 08-10-2019, 01:05 PM
please help, I did the firmware update but before I had version 48/5 // 5 and now I have version 48/4 // 5, could you tell me which one is the last one and how to get it?
Car: B46 F56S
Default 08-10-2019, 04:28 PM
Yes. My meth works properly and displays properly.
Do you have a BMS Meth Kit? FSB Wired to correct pins?
Jay1312
Default 08-12-2019, 09:28 AM
Yes bms kit and connected. meth works for me when meth trigger set to 1. What maps are you running John? Have you tried the meth map3 with additive or you using map 6custom tuning on top of flash?
Car: B46 F56S
Default 08-12-2019, 01:10 PM
I was using Map 1, 2, 3 before the flash switching around. Now I use Map 6 at 0psi to control meth and trigger safeties on top of my flash.
Default 08-22-2019, 07:46 PM
The MINI B38/B48 JB4 is a new CANbus enabled tuning system offering a lot more features & function than our previous Stage1 system. The CANbus data allows us to provide more comprehensive and dynamic tuning, advanced features like code read/delete, in dash map switching, boost targets by gear to improve traction, an in dash boost gauge, and much more.
JB4 Interface: Latest Interface Download. When updating your interface you may need to first go to "add remove programs" and "remove" your previous JB4 interface.
If you need directions on how to connect a laptop to your JB4 to update firmware or how to datalog Click here.
MINI JB4 B38/B48 Map Guide:
Map0: Disable JB4 all together
Map1: 4psi peak over stock
Map2: 6psi peak over stock
Map3: Progressive WMI map (under development)
Map4: Stock tuning with JB4 active for logging and in dash gauges
All other maps: Not defined, do not use
'OBDII In Dash Menu
Exhaust Valve Mode:
Toggle between flap open, flap closed, and OEM operation, by pressing the button for 2 seconds and letting go. The left blinker will flash for valve open, right blinker for valve closed, and both blinkers for OEM operation. The valve setting is persistent and will remain in effect until you change it. If you hold the button too long you'll jump in to the in dash menu system below.
Dash mode: By pressing and holding the BC button you'll enter dash mode. The left blinker will turn on and the tach/speedo will drop to zero. To toggle through menu systems press and release the BC button. Note as the speedo modes with each BC press it will not necessarily align with speedometer needle position. The speed = 0 starting menu is for maps with the current map being shown by the tach needle. To change a setting when on the menu you want to change press and hold the BC button. The right arrow will light up and now pressing the BC button will move the tach needle to let you change settings. When the needle is aligned with the intended setting, for example to change to map2 then speedo=0, tach=2000rpm, you'd press and hold the BC button. The blinkers will flash twice and the in dash menu system will close. When you go back in to the menu system you'll note the map has been updated.
'0 map menu, map shown on tach (tach shows Map)
'1 Active Sound MUTE. (OFF tach = 0, ON tach = 1000)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000)
'3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
'4 Delete fault codes
'5 1st gear boost limiter. (Tach = boost cap / 3)
'6 2nd gear boost limiter. (Tach = boost cap / 3)
'7 3rd gear boost limiter. (Tach = boost cap / 3)
Default MINI B38/B48 Settings:
Attachment 64400
Any news about new firmware?
