bmwchue bmwchue is offline
Car: 2013 328i
Default jb4 EWG connector - 06-08-2019, 11:26 PM
2013 328i N26 EWG
is the EWG connector add on for older jb4 or is it a requirement for EWG equipped vehicles? or is this only for the N55?
i have had my jb4 on for over a year with no issues and just started seeing that there is a add on ewg connector that supposed to connect to the ewg to the jb4. im unsure if i need it or im good to go.
thanks
Default 06-09-2019, 09:58 AM
For the N20 its only needed for 320i models or 328is running lots of boost. You'll be fine without it. It's not even active on map1 or map2.
Car: 2013 328i
Default 06-09-2019, 10:15 AM
im actually running map 6 and 7 using e30 and 50/50 WMI.
Default 06-09-2019, 10:52 AM
Then you need it.
Car: 2013 328i
Default 06-13-2019, 08:15 PM
Then you need it.
Finally installed but it is overboosting alot
I have the blue wire to pin 16 and purple goes to pin 9
map 1 and 2 works fine
as soon as i switch to map 3,6,7 they over boost up to 30psi
in your thread you did say "If using a newer EWG specific board, connect the blue FSB wire to position #14 on the DB25 connector."
but that spot on mine already have a wire on there
is there something i did wrong?
theses are the settings i have back when you helped me out
please help reading logs - N54Tech.com - International Turbo Racing Discussion
bms meth kit blue wire goes to what pin on jb4? - N54Tech.com - International Turbo Racing Discussion
Default 06-14-2019, 08:28 AM
Can you provide pictures of your DB25 connector so we can see what wires and pins are going to each?
Car: 2013 328i
Default 06-14-2019, 10:25 AM
here are the pictures
Car: 2013 328i
Default 06-17-2019, 08:31 PM
please help. Thank you
Default 06-18-2019, 09:19 AM
Your wiring looks correct. Would you be able to get a log on map 2 for us to take a look at your settings?
Car: 2013 328i
Default 06-18-2019, 02:47 PM
hi i was able to get some logs
thank you
Default 06-19-2019, 02:15 PM
thank you
Hmm, can you get me a photo of your JB4 connections for the Tmap and map. Also update your firmware as well.
Car: 2013 328i
Default 06-20-2019, 08:47 AM
here are the pictures of the map and tmap. My firmware was updated the day before i posted the logs.
Default 06-20-2019, 11:09 AM
Looks all good here. I think what Payam is seeing in the log on psi2 is just a bug in the firmware I'll have to check out later.
Car: 2013 328i
Default 06-20-2019, 12:06 PM
So all connections and logs looks good except that I'm still over boosting when on map 3,6, and 7. If I unplug the ewg and run all the maps they are fine. Should I just leave it unpug?
