(#651)
Default 09-20-2018, 12:56 PM
Put the JB4 on map0 and see what stock is, using the same metric.
sym sym is offline
Car: Stinger
Default 09-20-2018, 01:48 PM
Good idea. I'll see what that looks like later tonight.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 09-20-2018, 06:00 PM
Hey Terry, any idea when the next firmware update is coming out? I imagine that you have already perfected a few more pieces of the puzzle. LOL
-MurlinatoR
Connoisseur of all things Kia
Aegisx5 Aegisx5 is offline
Car: 2018 Kia Stinger GT2 AWD
Default 09-20-2018, 08:41 PM
Where does is estimate 0-60 in the JB4 app?
sym sym is offline
Car: Stinger
Default 09-21-2018, 07:26 AM
Tap a log entry. If it was a clear WOT launch from 0 it will show you the 0-60 time. It doesn't show up for all of them.
Did a map 0 run last night. App is showing 0-60 of around 5 seconds. So there's definitely a substantial (0.2 - 0.4) second improvement over stock. I'm pretty sure the issue is with the app, but we shouldn't expect it to give us an accurate number. But it's a decent approximation.
Default 09-21-2018, 08:37 AM
We're always kicking around stuff here. But can't put dates on anything.
Allmanb Allmanb is offline
Car: Kia Stinger GT
Default 09-21-2018, 10:02 AM
I'm ready to break into the 3 seconds 0-60s. I have been logging 4.4 to 4.6 via the app
2018 Stinger GT AWD
JB4 w/ Fuel control wires
Denso plugs .025 gap
K&N air filters
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 09-21-2018, 10:26 AM
Where do I get the 0-60 time on the app.
Car: Kia Stinger GT
Default 09-21-2018, 10:30 AM
Connect jb4, log a 0-60 run, click on log and it will display it (this is on the phone app, if using laptop i am not sure)
2018 Stinger GT AWD
K&N air filters
sym sym is offline
Car: Stinger
Default 09-21-2018, 01:54 PM
Do you have anything to compare it to?
When you're say you're trying to break into the 3s are you almost close or are you looking to make some changes?
Are you AWD or RWD? And 18" or 19" tires?
Default 09-21-2018, 09:59 PM
My 0-60 times via dragy (accurate) are in the 4.4s range. 3s would take one hell of a launch I think.
Metalmania82 Metalmania82 is offline
Car: Stinger GT
Default 09-22-2018, 06:25 AM
Hi Terry, hoping to get you on here for some help.
Just installed my JB4 last night along with the OBD connection and BLuetooth adapter. I'm having issues connecting to the bluetooth. When I try to pair my phone to the device, it does see it as an available device, but when I type in the PIN of 1234, it says cannot connect and to check bluetooth device. When I go into the app and hit CONNECT, it goes through all it's little steps and performs the handshake and then connects. Gauges come up but they all read 0 except for MAP where it reads 1. Went for a ride last night and nothing comes up on the gauges.
I feel like I'm missing something small and very obvious here....!
Default 09-22-2018, 09:06 AM
You don't pair the JB4 mobile to the device. The app manages everything on that.
Does boost appear in the app under heavy throttle?
Mr GT2's Avatar
Mr GT2 Mr GT2 is offline
Car: Kia stinger
Default 09-22-2018, 12:45 PM
Hey guys I know this is a silly question but I'm still new to all this stuff but is flex fuel the same as e85 because that's all I have next to me and I want try that 30% mix like in the first post mention
Car: Kia Stinger GT
Default 09-22-2018, 01:27 PM
I'm nowhere close. Just would be awesome someday. Like terry said. It would take a hell of a launch to do so. Mine is AWD 18s with all seasons.
2018 Stinger GT AWD
K&N air filters
sym sym is offline
Car: Stinger
Default 09-22-2018, 04:19 PM
Yes, flex fuel is E85
Looks like we have the same setup then. I'd really like to get close to 4 seconds without an ECU tune.
@Terry
I've been thinking about the fact that we're using E30 blends. The LHV of E30 is a lot lower than that of high octane race gas, and the AFR stoichiometry would be substantially different as well. Is it a stretch to say that with the right tuning settings we could get a good bit more power out of a high octane race gas? There's Sonoco near me that has this at the pump (https://www.sunocoracefuels.com/fuel/standard), but they also sell containers of several other fuels. I'm thinking this would only be for track days - you know, to make you guys look good
Default 09-22-2018, 08:10 PM
Running race gas instead of the ~E30 won't make much difference, at least didn't in our testing. But spiking the fuel with a gallon or two at the track never hurts just to get octane up a bit.
Mr GT2's Avatar
Car: Kia stinger
Default 09-22-2018, 09:18 PM
OK thanks alot
sym sym is offline
Car: Stinger
Default 09-23-2018, 04:23 PM
@Terry
I ran into a no boost situation for the second time today. The first time was when the engine wasn't properly warmed up (this was about a month ago), but everything was warmed up today.
I was using Map 5, did a decent (but not launch control) pull when getting onto the highway. I don't have a log of the actual event, but here's a sick 10 second 0-60 pull I did before restarting the car.
No check engine lights or other error codes. Any ideas?
Mr GT2's Avatar
Car: Kia stinger
Question 09-23-2018, 07:08 PM
@Terry
OK so I tried map 5 with 4 gallons of e85 from the pump and the rest top off with 93 and everything felt OK no stumbles or anything but the butt Dyno says no difference from running map 2 or 3 and if I'm reading the graph right except for a one time spike its only hitting about 16-17 psi is that what its supposed to be thanks .
Default 09-23-2018, 07:41 PM
@Terry
I've noticed those cars that can still trigger it normally are not pressing gas pedal 100%, they press it 100% but then roll off the gas. Was that the case with yours also? If so I'll need to poke around in that part of the mapping further as I don't often drive our development car like that.
Default 09-23-2018, 07:43 PM
@Terry
Log looks OK to me. Run whatever the lowest map is that gives you the best performance. So if 2, 3, and 5 all feel the same (or measure the same using dragy) then stay with 2.
Mr GT2's Avatar
Car: Kia stinger
Default 09-24-2018, 08:34 AM
OK thanks
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 09-24-2018, 08:45 AM
Are the BMS dyno charts for map 3 and 5 (on 30%E85) really with just an intake? If so, very impressive. Obviously the tune is going to be your biggest "bang for the buck", but has anyone compared just intake/tune vs. adding full exhaust?
How much more is there to be gained? Is the exhaust really that restrictive? I don't care about sound, and I'm paranoid about warranty issues (I know, don't tune then), but I'm not going to even mess with the exhaust if I'm not gonna see significant benefit.
I'm late to this party, so I apologize if this has already been covered. Everyone I talk to added exhaust, intake, and tune together, so can't comment on what the exhaust did on top of map 3 or 5.
Default 09-24-2018, 11:00 AM
Yes, just a JB4 and intake. And the Denso replacement spark plugs. Not sure if exhaust adds much.
