torq455 torq455 is offline
Car: 21 Sonata N Line
Default Sonata N Line Log Check - 03-10-2022, 01:43 PM
Hello all! I'm posting here for the first time! I'm not unfamiliar to tuning. The last car I tuned was a somewhat modded 2002 Pontiac Grand Prix GTP (supercharged). After owning a modern turbo for the first time, I see things are similar, yet very different!
Got my first couple of logs. I’m not sure what stock boost typically is on a 2021 Sonata N Line, but I was expecting to see boost to be fairly steady around 20psi on map 2. I don’t know how accurate the boost gauge is in the car, but it looks like stock boost is 15 psi, and the app gauge shows about 17 psi. Is this correct, or is there some tweaking needed?
I didn't bother to gap the plugs, however the car runs well! It stopped feeling as if it was surging, like it was starving for gas! Thanks!
Car: 2020 Kia Forte GT
Default 03-10-2022, 02:55 PM
Log Map 0 to find out what the stock boost levels are.
Unless something has changed Map 1 is +4 psi over stock.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Burger Motorsports Water Methanol (45/55 mix)
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Default 03-10-2022, 04:12 PM
I wanted to do that, but time, and traffic didn’t allow for that. I was more interested in the other maps! ��
Default 03-10-2022, 11:01 PM
Ok. After researching more, I’ll get a log of a 3-4 gear run from 2,500 rpm. Disregard the other logs.
Default 03-13-2022, 01:44 PM
So stock boost is about 13psi. Got a map2 log. Annnnnnd I’m gapping my plugs now. I had something interesting happen on my last run. Around 100 miles an hour, It went to shift, and it was like it got confused on what to do. It felt like it had half the power, started surging, and was maintaining 6500 RPM instead of shifting at 6,200 RPM. Seem like the clutches were slipping. It wasn’t the rev limiter.
Default 03-14-2022, 10:34 AM
If you get slippage on map2 then map1 is probably a better fit... That's more of a concern in cold weather.
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 03-14-2022, 10:44 AM
In your csv file, or if you bring up the BMS software to look at your log, you will see ECU PSI. That is your stock boost. You will also see Target, that is what's added to ECU. Boost is the total combined.
Default 03-25-2022, 11:38 AM
Any thoughts on the most current log that I posted? I’ve seen AFR drop to the low tens. Is that an area that fuel can be taken out of, or should it be left alone?
BiPolarXpres's Avatar
BiPolarXpres BiPolarXpres is offline
Car: 2021 Hyundai Sonata N-Line
Default 05-14-2022, 06:30 AM
Any new logs or updates?
Default 05-14-2022, 01:40 PM
None. I’ve been having issues with dataloging for couple of weeks now. It connects fine, and displays the info. When logging,it will stay connected between 5, and 15 seconds, then it closes the app, and doesn’t store logs. I started a new thread for that too, which I still have yet to receive any input.
Default 05-14-2022, 09:16 PM
I can only recommend three things to help. One, reinstall the app. Two, make sure the coms thing under the hood is touching no metal. Three, check the wires and pin connections again. Hopefully no frayed wires and such. Sounds like something in signal and communication and that’s kind of where my brain goes.
2021 Sonata N-Line | JB4 | SXTH intake | Custom 3” Exhaust | Megan Racing Coilovers | Konig Ampliforms | Firestone Indy 500 | Broken Driver Mod
Default 05-17-2022, 06:58 AM
Already reinstalled the app. Didn't think about the com. Maybe something moved. Pins, and wires are good. I did recently install firmware version 21/24 T14. Maybe that's the culprit.
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 05-18-2022, 07:47 AM
Is the clutch slippage a concern? Haven't heard this before.
2021 kia K5GT.
Default 05-18-2022, 09:45 AM
No. I believe it may have been a learning thing. ECM calculates load, amongst other parameters to time clutch engage/disengage. I speculate that with the sudden addition of the extra power, it wasn't sure how to handle gearing vs. clutch engagement. It's not the actual clutches slipping, rather the ECM not controlling them properly. Only did it bad once. Then had only two minor weird events after. Been fine since.
