05-13-2022, 11:24 AM
You're not supposed to adjust duty bias, and only supposed to lower FF in increments of 5.
I'd need to see the log myself for any tuning advice.
Car: 2022 Kia stinger
05-13-2022, 11:39 AM
Thanks Terry, once I get this squared away it's back to my traction issue which you did mention to try 6-3-0 boost by gear. Than it's time to activate my wmi.
05-13-2022, 01:49 PM
Yes, boost by gear does wonders for RWD traction! Our diff brace helps too.
05-18-2022, 06:20 AM
I had to go all the way down to 20 FF. Is this normal?
05-19-2022, 01:06 PM
No, but that doesn't mean it's wrong. Most over boost situations are resolved at FF = 40.
Car: 2021 Kia Stinger GT2
05-19-2022, 01:19 PM
How do you know you're overboosting? Is it by simply looking at the logs or when the JB4 triggers a safety?
05-19-2022, 01:22 PM
Car goes into limp mode. I get no codes and my log shows me hitting 20-21psi.
05-19-2022, 01:25 PM
Quick example of using the JB4 to manage boost targeting and specifically "over boosting" that will often lead to a limp mode and/or p0049 fault code. Note this only applies to those with EWG connectors installed. If you don't have JB4 EWG connectors installed, none of these settings will do anything. So add EWG if you need to fix an over boost or other boost targeting issue.
The JB4 is running what we refer to as integrated wastegate control on the 3.3L platform, which means the ECU is doing the heavy lifting on boost control with the JB4 dynamically adding or subtracting from the wastegate position to fine tune it. The JB4 controls the wastegates through a PID controller.
WGDC represents the JB4 offset to the wastegate position, which is scaled roughly 0-100 in JB4 logs = -15% to +15% dutycycle. A value of 50 in JB4 logs means no offset at all. Wastegate position refers to the position of the flapper in the turbocharger turbine (exhaust side wheel) which is used to control how fast the turbocharger is spinning.
FFPID (FF) in JB4 logs represents the "base" offset applied (feed forward), which is calculated based on internal JB4 mappings and user tweaked using duty bias by RPM and FF globally. Default values for duty bias are 50 across the board, and default for FF user adjustable is 50 across the board.
PID Gain represents the gain portion of the PID control loop that governs the WGDC output, with ECU_PSI being the process variable and DME_BT being the set point. ECU_PSI is the boost signal sent back to the ECU, DME_BT is the modeled boost target. This basically governs how far above or below FF WGDC is allowed to roam. The larger the number the more WGDC can diverge from FF. The default setting is 20 and generally doesn't need to be changed.
When ECU_PSI goes above DME_BT as have an "over boost" situation which the JB4 reacts to by lowering WGDC to lower boost. When ECU_PSI is below DME_BT we have an "under boost" situation which the JB4 reacts to by raising WGDC to increase boost. It can only raise or lower WGDC a certain amount above or below FF as set by PID gain.
I left a lot of the details out above but wanted to give a little background for those familiar with tuning and PID control specifically as to what is going on behind the scenes.
This is the important part: The one user adjustable FF is setup as a global scaling and can be raised or lowered by the user to scale the entire boost targeting algorithm. So generally speaking if you're over boosting lower FF. If you're under boosting raise FF. We've designed the system so that some under boost is desirable. We can get in to why that is in another post down the road.
Here is a customer log from a car running modified exhaust. He started with FF = 60 (higher than default). Notice WGDC is close to 90, meaning the JB4 is adding a lot of WGDC. And predictably boost is way over target, triggering a limp mode. Note boost was not high enough to trigger a JB4 safety map as he set his JB4 safety system at 24psi.
In the second log that same customer lowered FF to 40, which brought the JB4 down to a neutral level of WGDC, around 50, and this resolved his over boosting problem all together. Just with that one simple JB4 setting change.
There is a lot more complexity to the system but TLDR: If you're over boosting make sure JB4 EWG connectors are installed and lower FF until you stop over boosting. Some customers need to go down to 35, 30, and even 20. If you get to 20 and its still happening then probably something else is wrong and at that point contact me with a log of the issue so I can help you further.
05-19-2022, 03:39 PM
Another EWG example, both logs running map2. One with FF = 50, another FF = 40. Note was not enough over boosting to trigger a code or issue but you can see the impact FF changes with no other changes.
Car: 2019 AWDGT2
05-20-2022, 03:23 AM
I see a slight increase in overall timing too  good stuff
