(#201)
luchocamp's Avatar
Default 10-17-2018, 12:29 PM
Originally Posted by JacquesN55
Ive removed the dual meth. Im going Direct port meth setup. A meth nozzle per cylinder.
I hope you be the first with good results with that new set up ( nozzle per cylinder )
18 BMW XXXX Car in Process
Car: 2011 N55 135DCT
Default 10-17-2018, 10:22 PM
My Friend runs direct port meth on his single turbo e82 dct n55 wit no issues.
135idct 135idct is offline
Default 10-18-2018, 04:16 PM
how much boost he can push on pump 93 fuel
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 10-22-2018, 12:44 PM
Originally Posted by Fmonteiro444
Something weird happened today. I was at about 75mph cruising in 5th, manual mode. I gave it a little more than half throttle to pass someone and when I let off the gas it jerked pretty aggressively. Got a Drivetrain Malfunction for "1F0526 DME internal error: monitoring torque comparison" and hitting the gas did nothing. Tried to clear codes while driving but couldn't. Checked what map I was in and the JB4 said "invalid nap selection" and it magically ended up on Map 1. But when I checked the logs while this was happening it says I was still in Map 6. I had to pull over, restart the car, clear the codes, and switch back to Map 6.
Anyone got any thoughts on this?
This happened to me again twice today during my commute. This time I'm on EWG_15_T5B firmware. The worst part is it disconnects my tablet from the JB4 and I was not able to reconnect.
Terry any help with this?
Not had any reports of it, but I think it's a flash issue. Are you using our off the shelf BEF map or did you modify it?
Using a modified version of your BEF. I can send it to you. But all I've changed is fuel, timing, and fuel scalar.
Happened again on Friday. This time I was in 5th at 80mph part throttle. Tried to pass someone and got Drivetrain Malfunction, gas pedal did nothing, and JB4 went from Map 6 to Map 1. Why is the JB4 switching to Map 1? Attached are two logs after the map switch.
Juan_BIGBOOST_TURBO's Avatar
Default 10-22-2018, 12:49 PM
Check your DM, I sent you some recommendations!
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
Car: 09 E92 SG
Default 10-26-2018, 06:49 PM
Let me know if you find that table.
So I set the jb4 to 30PSI but it's only targeting 26.5. Am I missing something?
Car: 09 E92 SG
Default 10-27-2018, 04:23 PM
Anyone got any ideas?
Default 10-28-2018, 06:59 AM
Whats ure boost safety set to
Car: 09 E92 SG
Default 10-30-2018, 01:49 PM
It was the Boost Ceiling setting in the flash. It was limited to 26.5psi.
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 11-07-2018, 03:20 PM
This thread is getting good! Congrats on your success so far.
tisdrew tisdrew is offline
Car: 2009 e90 335i 6MT
Default 11-08-2018, 08:07 AM
Very interested to follow this thread. Best of luck OP
Car: 09 E92 SG
Default 11-13-2018, 11:28 AM
Quick update. Still trying to dial in perfect boost control. I got the flash settings to target 28psi, and I set Map 6 to 28psi. Its' pretty damn fast. Still need to find a fix for 3rd and 5th gear torque limiters.
Does anyone know why on this particular run my trims flatlined at 25?
Default 11-13-2018, 11:43 AM
Trims stuck at 25 indicate open loop and normally an o2 sensor fault stored that has to be resolved.
henriquecoutobsb henriquecoutobsb is offline
W4NN4G0F457
Car: BMW M235i
Send a message via ICQ to henriquecoutobsb
Talking 01-15-2019, 01:18 PM
I got a kit for myself. EFR 8374 for my M235i.
About the torque limiters: I'm waiting for a solution on next Monday: https://www.facebook.com/xhpflashtool/
Car: 09 E92 SG
Default 06-12-2019, 11:46 AM
So I ended up blowing my motor back in January. I windowed the block, snapped an engine mount, bent and split rods, sent another rod into the head, and split a piston in half. So you could say I fully sent it lol. This happened while cruising at 75mph in 6th gear and attempting to pass someone. Heard a large bang, and smoke just poured out of the rear end. The oil slick was a quarter mile long.
W4NN4G0F457
Car: BMW M235i
Default 06-12-2019, 11:49 AM
Low RPM High Torque?
Car: 09 E92 SG
Default 06-12-2019, 11:57 AM
Long story short, I had the car towed to Billy Mason. I decided to go for the full build. We had to source a new block. Billy stripped it and sent it off to CSS for machine work to close the deck. Motor is finally done and in the car. Billy is currently breaking it in. I'm shooting for close to 800hp on this setup, and I don't think it will be hard to obtain.
Car: 09 E92 SG
That combined with a motor that was abused daily by me contributed to the failure.
Car: 09 E92 SG
Default 06-12-2019, 11:59 AM
I took notice of your world record 10.9 for the F30. I'm looking to steal that!
Default 06-12-2019, 12:00 PM
how much boost u r pushing? i know someone in IG blow his motor at 28psi same kit efr8374, also i run same kit efr8374 but i run only 20psi and map2 for dd
Car: 09 E92 SG
Default 06-12-2019, 12:02 PM
I was running 26-28 daily. Even dabbled at 30psi a few times. Car was stupid fast.
luchocamp's Avatar
Default 06-12-2019, 02:08 PM
All records are made to be broken someday.
Nice parts now. Keep it up.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 06-13-2019, 08:41 AM
Crazy! can't wait to see the results of your beefed up rebuild.
2013 BMW 335xi F30 N55 PWG
Car: 09 E92 SG
Default 08-06-2019, 10:05 AM
Did a quick pull today on pump gas. She moves pretty damn good for just pump at 19psi. Also had the car lowered on street comforts and it rides and handles incredible.
Default 08-06-2019, 01:07 PM
Back on the streets!! Time to really turn it up and make some big power with that turbo
How far have you turned it up so far?
