(#301)
ceedawg ceedawg is offline
Car: 2015 f30 335i Msport Xdrive
Default 07-10-2018, 05:51 AM
Originally Posted by Newguy123
Excuses are like farts. Everyone has them and they always stink! Itís not anyoneís fault that people buy heavy cars to mod.....
THIS!!
No excuses here, just pointing out common sense!! Hopefully you read and understand the thread.
2015 335i Xdrive Msport FBO BM3 Stg 2 93 oct
[B]1995 Eagle talon TSi AWD Fully Built!!
luchocamp's Avatar
Default 11-10-2018, 07:40 AM
a few months without share progress I was working on customers cars, back now my 2013 335ix ... in a few days will install a double in tank pump and make a little adjustment to wastegate position ... looking to enter into 10s 1/4 mile
18 BMW XXXX Car in Process
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 11-16-2018, 07:34 AM
totally is, thats great
you switched to rs3 ? modded yet ?
335i x-drive 2011 e90 n55
henriquecoutobsb henriquecoutobsb is offline
W4NN4G0F457
Car: BMW M235i
Send a message via ICQ to henriquecoutobsb
Default Any progress? - 12-07-2018, 12:03 PM
Did you make the adjustments? Any progress? I would love to see the times and some logging, if possible.
Just got the 8374 kit and I would really appreciate some technical info. I'll stop my car in January to put it all together.
Already running MMP PI, upgraded Wagner IC, Walbro LPFP, AFE Momentum Intake, AEM WMI, straight pipe exhaust, BM3+JB4 and stock turbo.
luchocamp's Avatar
Default 12-08-2018, 04:30 AM
I had some problems with HPFP and fuel pressure drop.
Ordered following real oem parts chassis and part number but my car has different connector ( probably N55 E90 ) Had to send back to seller and order correct one.
Car runs good up to 20psi using WMI and 93oct.
You are going to love the feeling of a good turbo as the efr8374 ...
W4NN4G0F457
Car: BMW M235i
Default 12-08-2018, 04:54 AM
The problems you had with the HPFP: Are they malfunction or the HPFP needs an upgrade? I am asking because mine is just fine, but maybe I need to start thinking about it...
luchocamp's Avatar
Default 12-08-2018, 08:26 AM
80k miles ... that was the problem
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 12-11-2018, 09:55 AM
What did you order to address the issue, I'm at 84k and you have me thinking now...
2013 BMW 335xi F30 N55 PWG
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 12-11-2018, 10:04 AM
You just buy a new pump to fix the problem.
Default 12-11-2018, 10:17 AM
I guess I'll see, if I need an HPFP pump I'll find out next summer, I'd probably do a TTFS XDI upgrade.
Newguy123's Avatar
Car: 12' 135i
Default 12-25-2018, 11:27 AM
I did and yes. Just got the new pureturbo hybrid turbo installed a couple nights ago. Let the good times roll!
18í Glacier white RS3
#PURETURBOS
#FUELIT
rallyrafa rallyrafa is offline
Car: 535i GT 2011
Default 12-26-2018, 06:47 PM
Hi!
With my settings, can i run a speedtech stage 3?
With 18 max psi until redline?
Will i make at least 450whp?
2011 535i f07 custom pipe after turbo, VRSF CP, K&N CAI, E40+ BEF
Default 12-27-2018, 09:52 AM
ohh your the guy that made a tbread on audizine ?
luchocamp's Avatar
Default 01-03-2019, 08:15 AM
few updates here :
HPFP oem works fine but not allow too much Ethanol. Max I see now is E25
Buy new Fuel It 525 walbro did not see any difference at all vs 450 walbro or stock LPFP pump.
Car is running great E25 127mph or 100octane unleaded fuel 127mph
11.1 - 11.3 sec 1/4 mile
in a few weeks I will try VP MS109 and more boost ....
Car: 2011 N55 135DCT
Default 01-03-2019, 02:16 PM
What boost for ure 127mph and 11.1 to 11.4
Default 01-03-2019, 02:19 PM
Im runing 5962 size turbo at 25 psi on my e82 N55 dct on the bms pump flash. Low timming. Also doing 127 mph exit on the 1/4 mile at the moment. And im 5500ft elevation
Stoolz Stoolz is offline
Car: 11 135i
Default 01-06-2019, 04:12 PM
What were you trapping before? I thought it was more than me and my VTT traps 125?
Do i go big turbo and get 2mph?
Default 01-07-2019, 12:16 AM
Stoolz im using the bms pump flash that gets me 6 deg timing when i boost 25 psi. My WGDC is at 30. So cars timing and turbo is no where near maxxed or where it should be. I will get much more once i put more timing.
Car: 11 135i
Default 01-07-2019, 01:07 AM
Thx Mate,
What's your plan?
Try these things at a lower elevation?
Are the E series tuning gremlins well and truly gone now with MHD?
Thx
luchocamp's Avatar
Default 01-07-2019, 05:16 AM
23~24psi
Default 01-08-2019, 12:52 AM
The m4 flywheel sorted my issues out.
52172 52172 is offline
Car: 2015 335i
Default 03-15-2019, 03:53 PM
BMW N55 Turbofold vs Speedtech manifold
Iím sold on the turbofold alone
W4NN4G0F457
Car: BMW M235i
Default What about this results - 03-15-2019, 04:38 PM
I am not all set. I need a new Port Injection Controller. Ordered from FuelIt already. While waiting, I am riding this...
https://drive.google.com/file/d/1hbk...w?usp=drivesdk
WHP, not BHP.
Car: 335i 6MT RWD
Default 03-16-2019, 04:30 AM
I'm not sure what you mean
Car: 2015 335i
Default 03-18-2019, 09:35 PM
The cast turbofold looks sick.
