Victord03 Victord03 is offline
Car: BMW 125i F20
Default BMW 125i F20 Lean? - 04-27-2022, 03:56 PM
Hey Guys, I'm an Owner of a BMW 125i F20 2014 (N20 EWG), i'm from brazil, and the car is running gas (Like a 93RON), and i'm in 2600ft of altitude, and the car is with:
- Injen Intake
- JB4 (with EWG wire)
- NGK laser Iridum New
- Sparks coils Bosch New
I think the AFR is a bit lean, could you please review the log, and give me some tips about what to do? Or the AFR is ok for N20 motors?
The log is made in 4th gear and with all controls turned off.
Thank you!
https****://datazap.****me/u/victordbarra/****vela-e-bobina-trocada?log=0&data=1-4-5-9-11-18-25-26-27
(Please, remove the **** from the link)
Car: BMW 125i F20
Default 05-04-2022, 04:24 PM
Steve/Terry,
Are You there? Could You Help here?
Car: Evo VIII
Default 05-06-2022, 02:47 PM
Looks normal.
Default 05-16-2022, 09:29 AM
Late to the party but as mentioned AFR looks as it should.
Car: BMW 125i F20
Default 05-17-2022, 08:04 PM
Great Guys, Thanks for the help. I thought that AFR should start, under 100% pedal, in 13, and end about 11.5.
I made a Map 6 for extreme uses, that I've got more boost on it.
This one looks great in general? This level of Boost is dangerous?
There is something that should be adjusted? Thanks for the Help Again.
https***://datazap.***me/u/victordbarra***/teste-1105?log=0&data=1-4-23
