(#176)
Stimey's Avatar
Stimey Stimey is offline
Car: 2017 Maserati Ghibli S
Default 09-30-2019, 08:41 AM
Originally Posted by ChrisUCF99
The back sensor isnít the easiest but I got it done in 30 mins.
Thanks and I just bought. I have a friend that has the ultimate garage with a lift etc. Considering I had rotator cuff surgery 3 weeks ago he agreed to install. Next project is crack Android Auto to mirror my phone so I can see gauges on the head display.
Default 09-30-2019, 09:48 AM
Stimey's Avatar
Default 09-30-2019, 09:57 AM
Originally Posted by Whooopasss
Speedelement san jose did a dyno day. This is what we got for the Ghibli s q4 with jb4 set to map 2 and 91 oct.. no other mods
sport mode, manual 3rd gear pull.. mustang dyno
Isn't this like somewhere between 436 and 448 HP at the crank? If so that is extremely impressive.
Mmarmolejo Mmarmolejo is offline
Car: Maserati Ghibli
Default LOG DATA - 10-03-2019, 11:28 AM
I just installed the JB4 on my Base 2015 Ghibli yesterday and I'm trying to get some logs. The pull has to be in what gear? Thanks
Default 10-04-2019, 10:23 AM
No specific gear. You can just get a log at full throttle, just make sure it's for a few seconds at least
Stimey's Avatar
Default 10-04-2019, 11:05 AM
Can someone tell me where the two small wires on the OBC connection connect to?
Default 10-04-2019, 12:13 PM
Hello I just installed the JB4 in my 2015 Maserati Ghibli a few days ago and everything was fine. I saw here in some posts people running 93 octane with 3 or 4 gallons of e85 with no issue. I filled up yesterday and added 2 gallons of e85 and topped off with 91 octane, now the vehicle has what it sounds like a misfire. Have you had anything like that? I'm running MAP 1
Default 10-04-2019, 02:26 PM
Do you have a CEL or a code?
Default 10-04-2019, 03:20 PM
I have a flashing CEL
Default 10-04-2019, 03:47 PM
Sounds like you misfired. Check the codes if you have bluetooth add on device or data cable with laptop.
Default 10-04-2019, 04:05 PM
I did check with the BlueTooth but does not find any codes.
MorganBence MorganBence is offline
Car: 2015 maserati ghibli
Default 10-07-2019, 10:26 AM
Hey all, I have downloaded logs but not sure how to post on here. I can't do it through Photobucket and I don't see anywhere on here to attach the excel log file. Any help would be appreciated.
Default 10-07-2019, 10:38 AM
Go advanced, then you'll see a paperclip icon.
Attach the CSV file so we can evaluate.
Default 10-07-2019, 10:39 AM
Car still has CEL and still flashing?
Default 10-07-2019, 10:42 AM
Here are 2 pulls on map 1 in manual mode. Please let me know if I can go to another map. Thanks!
Default 10-07-2019, 02:57 PM
for anyone who is going to install.
the only part that can be tricky is the sensor that is at the back of the engine. What worked for me is to use a screwdriver to pop the yellow tab open, then put one finger on the sensor and pull from the wires. When we did it that way, it came out with no problem. Now, getting the new sensor plugged in. Slightly bend the wires to configure it in the right position when you feed it down where the existing wire used to be. It will take a little patience to position it just right to get a finger down to push it in.
Going through the firewall for the OBD was simple. It is a little cramped under the dash so it too will take a little patience. We taped the wire to a screwdriver and just fed it through. It makes it so much easier if you have 2 people.
I will say, once everything is hooked up, it will definitely put a smile on your face. It is well noticeable!!!
Whooopasss Whooopasss is offline
Car: 2014 Maserati Ghibli SQ4
Default 10-08-2019, 08:34 AM
for us 91 oct guys, can we add e85? if so, how much and what map should we log with?
Default 10-08-2019, 12:13 PM
Thank you for the feedback!
Yes! You can start with a mild blend. Add 3-4 gallons of e85 and fill the rest with 91. You can go to another higher map, but get me some logs so we can evaluate
Default 10-08-2019, 02:50 PM
payam, attached is map 2. Is this where I should stay or should I move to another map? thanks
Any plans for an air intake for the ghibli?
Default 10-09-2019, 12:15 PM
Yes it's still flashing and I show code 0305, I will change sparkplugs on the weekend and see what happens.
Default 10-10-2019, 10:53 AM
Looks pretty good to me! What fuel are you running?
No plans for an air intake system at the moment, I'll look into it though!
That code is a misfire code, so yes the spark plugs will definitely help.
Default 10-10-2019, 11:44 AM
I really hope that works. here is a log I captured before that happened. Can you help me reading this?
Default 10-10-2019, 04:46 PM
Thanks. I'm running 91 pump. So should I stay or use a different map? I'm in southern California as well so if you need a sample car let me know.
Default 10-11-2019, 01:50 PM
Can you post the CSV file.
You can learn more about reading logs here:
Logging Parameters and their Meaning - N54Tech.com - International Turbo Racing Discussion
We suggest map 2 at the most for 91 only. Do you have access to e85 around you?
