(#501)
Default 08-20-2019, 06:41 PM
Originally Posted by stuffle69
ok found it when i click on wmi to modify what do i need to change?
I listed the option in my post above.
stuffle69 stuffle69 is offline
Car: 2019 type r
Default 08-20-2019, 07:55 PM
[QUOTE=Terry @ BMS;643741]I listed the option in my post above.[/QUOTE
You said Outside USA passive delete can be turned on on the WMI page.
Can you explain what that means ?
Default 08-20-2019, 08:16 PM
[QUOTE=stuffle69;643745]
If outside the USA an option there appears for passive delete. If inside the USA it doesn't for legal compliance reasons.
Coldpizza Coldpizza is offline
Car: Civic
Default 08-28-2019, 06:09 AM
Just recently installed a JB4 on my Civic Type R, stock, 93 octane. Log is attached for review!
Default 08-28-2019, 10:48 AM
Looks all normal to me!
Klpaleo Klpaleo is offline
Car: Honda Accord EXL 1.5 Turbo
Default 08-31-2019, 03:42 AM
I changed my mobile phone and want to download again the JB4 mobile app which I had bought and installed in my previous phone. But when I try to download I don't see any option to download it without paying again. Please advise
Default 08-31-2019, 09:32 AM
I think there was some bug on that, ask JB4 mobile directly: JB4 Mobile - N54Tech.com - International Turbo Racing Discussion
BrettsFK8 BrettsFK8 is offline
Car: 2019 honda civic type r
Default 09-01-2019, 11:39 AM
2019 map 1 type r I'm not sure it's a long enough log but here are some logs
Default 09-01-2019, 01:13 PM
Normally you'd just post one or two for me to checkout and generally only if there a need like a problem.
Opened a couple here and they seem normal to me.
Default 09-01-2019, 01:22 PM
Ok so just by a glance running map 2 should be ok?
Default 09-01-2019, 02:29 PM
You can try it if you're on good 93 octane.
luisgfernandez luisgfernandez is offline
Car: Honda accord 1.5t 2018.
Default 09-26-2019, 08:12 AM
hi terry is safe to put a blow off valve using jb4 honda accord 1.5t
DavesXX01 DavesXX01 is offline
Car: 19 CR-V
Default 09-26-2019, 11:52 AM
Hi, would like to add a JB4 to my '19 CR-V but have limited access to 91 octane and will most likely use 87 most the time. I read Map one adds 3.5# boost.
What can I do?
Possible to copy your map 1 to map 6 but lower the max boost added to 2.5 or 3 while keeping your other setting/safety features intact?
Also would like to keep fuel mileage for trips and have the ECO button. Possible to dual map?
Or make the additional boost only apply at or above a certain RPM/throttle angle?
Default 09-26-2019, 05:12 PM
Yes absolutely, that is a common use for map6.. Detuning. Post a log on map0 and map6 set to say 2psi across the board and we can help you dial something in.
Odinist's Avatar
Odinist Odinist is offline
Car: 2018 Civic Si
Default 10-03-2019, 05:53 AM
Do not put a vent-to-atmosphere BOV on these cars!
They're Mass-Air cars, and the MAF is before the turbo. This means that if you have a BOV letting the already-measured air out, your ECU will still be adding the fuel it was expecting to need for said air, causing spikes of very rich conditions when you shift.
It's bad for them.
If you want a WHOOOSH when you shift, get an intake.
Mishimoto intake, resonator delete, Vibrant 1040 muffler, JB4 tuner, Firehawk Indy 500 rubber, Lamin-X fog light covers, Xentec 35w 6000k HIDs, custom d20 shift knob, 20% tint, red "H" badges.
