Chasebryant88 Chasebryant88 is offline
Car: 2008 535i
Default 535i manual swap - 02-22-2021, 06:42 AM
Hello all I have a 08 535i auto and its failing so I decided to do a manual swap I am a mechanic by trade and have read many threads on 535i at to mt swaps and it seems like a pretty straight forward simple swap but I am needing some help with parts. I have bought a complete manual swap from a 07 335i but im not sure what parts can be used from the 335i and what parts I have to get specifically for the 535i can anyone tell me which parts will fit from the 335i to 535i? The parts I have from the 335 are trans, smfw clutch assembly all pieces inside bellhousing, brake/clutch pedal assembly, master/slave and all lines, clutch switch and plug, trans wiring harness, all shifter parts, trans crossmember, driveshaft, and rear diff what will not work in the 5er and what else might I need? Thanks in advance
